Question about Sunfire True Subwoofer Mark IV Subwoofer
My subwoofer makes loud, sharp popping noises at random intervals when in use. Otherwise, the sound is performing as expected. Any ideas on what the problem is?
    President:
  • 1,114 Answers
Pull the board out of the cabinet and spray it with "Tuner wash" can be found at any electronics store like Radio Shack etc. make sure you spray it on the volume and crossover point controls. Beware, Tuner wash can eat thru vinyl and any writing on the plastic. Pull off what you can and tape off the rest if necessary. After spraying it down, work it into the controls by turning them up & down. The spray will evaporate quickly. If you still have an issue, post a comment and I will help you troubleshoot further.
Posted on Jan 04, 2011
  • Luis hernandez Feb 13, 2011
    I f you are having problems contact ECP Electronics in Eagleville, PA, they can rebuilt the power amplifier and signal processor boards all the capacitors in this sets are going bad due to age but is dangerous to do it your seft beacause the power storage in the big capacitors in the power supply.
Car exhaust is puffing out smoke in intervals
Sounds like its misfireing or possibly bad gas
Mar 18, 2013 | 1998 Ford Mustang
Fridge makes a fairly loud popping noise at intermittent intervals...otherwise works fine and maintains wine temp as set....makes this noise approx 10-15 times a day....unable to determine any set pattern...
What you are hearing is the new refrigerant going through the system. The old Freon 12 did not make that noise but the new stuff does. Nothing to worry about, it is normal. Thank you for using Fix ya and I hope you found this info helpful.
Jun 23, 2011 | Magic Chef MCWC30MCG Compact Wine Cooler
My refrigetator randomly makes a loud popping sound like a fire cracker. I hear it more at night but can't I'm not sure if it's just because the kids are sleeping and the house is quieter. It is a loud pop...
If it's cooling ok, they're probably normal sounds. Modern refrigerators can make many noises, most people aren't home long enough to hear them. A popping sound could be defrost water hitting a hot defrost element, or refrigerant making noise in the cooling lines. If it's working ok, ignore it.
Good luck.......
Jul 27, 2010 | Refrigerators
How do I stop the beep when food is ready (it beeps if you don't remove at the food after intervals)? Sharp R-340
I too have Sharp microwave that constantly beeps at approximately one minute intervals if the food you have been heating isn't removed. It is loud, persistent and extremely annoying. I've opened the machine to try and find the loud speaker but cannot find it (it could be built in to the circuitry?). Any help on this would be appreciated. It's a very unfortunate design flaw on what is otherwise a very good and easy to use microwave.
Jun 10, 2010 | Sharp R-340 Microwave Oven
I have a Rockford PL2-110 and intermittently I get a loud popping noise out of nowhere. the sub sounds good the majority of the time but occasionally it will make the noise more and more often. any ideas?
Have you double checked the wiring ( + to + and - to -)? When hooked up correctly, a sub should push outward when bass hits. If your wiring is correct and your amp isnt too big for the speaker then its about to go out.
Jun 29, 2009 | Rockford Fosgate Punch Stage P312 D4 Car...
Intermittent, random, loud popping noises.
you have a problem with your amp. most likley the finals are passing dcv intermitently to the load.
May 28, 2008 | Audio Players & Recorders
Subwoofer "thumping" w. no audio feed
You need to check your ground connection. If there is a bad ground there will be feedback to the amp and it will just sit there and loop back with the Thump, Thump, Thump sound. I had to wire my amp's ground all the way back to the negative battery terminal. It was a pain but I have never had a problem since :)
Feb 12, 2008 | JBL SCS125A System
you should check the outline ctrl..for a mic...it could produce a noise...if you have your speakers connected to pc...check the position of the plugs and the volumen of mic put in down...
Nov 24, 2007 | RCA RT2760 System
Sunfire True Subwoofer Mark IV Subwoofer Logo
752 people viewed this question
Top Sunfire Audio Players & Recorders Experts
shaun taylor
woodzowl307
Joseph Hoffmann
Are you a Sunfire Audio Player and Recorder Expert? Answer questions, earn points and help others
