Question about Sennheiser Audio Players & Recorders
I have not used the headphones for at least three days. Even though the headphones are on "off" they continue to keep charging and have been for a couple of days. What is the reason for the constant charging??
  • 731 Answers
My Sennheiser HDR 140 headphones charge whenever you hang them on the charger. The charger will "trickle" charge them to keep the batteries fully charged. If you find when you use it the batteries discharge quickly it's time to replace them.
My batteries are about 2 years old and I still get about 8-10 hrs of use before needing to recharge
Posted on Jan 04, 2011
I have a new one touch phone, and the "battery low" keeps coming every day, even though I keep charging it to full. any idea?
what do you mean keeps coming every day?? Or do you mean to spell that you charge your phone everyday and some way somehow your phone does not charge or does not charge fast enough
Dec 31, 2016 | One Touch Cell Phones
Headphone jack not working
I find that there is a problem with your headphone speaker.
Try with some other headphone, even if it is not working, then you need to take it to the service center.
Cheers,
Mr.Maduraikaran.
Jan 10, 2012 | Acer Computers & Internet
Headphone jack not functioning properly
This is the normal way for this laptop ..leave it always with the headphones on selected in that list ..cause if the main speakers don't work well there is no point in using them ..This way you will run whatever yo will plug in ..speakers or headphones..The only setting difference in headphones and stereo out ..is that for headphones will but the speakers of the laptop when plugged in ..This way it will even help you if the speakers are making weird noises cause they are damaged ..
Dec 22, 2011 | Computers & Internet
I'm using a "ACER aspire
There should not be a problem provided the notebook is used with the battery on occasions and charged up again when the battery level drops to approx. 25% level.
Jun 15, 2011 | Acer Aspire 5742Z-4200 Notebook
Well there's not much more to tell the charge port and the charge connecter seem to be losing the embrace to one another unless I find a position where it will stay on and keep charging but it's...
if there is any corrosion in your connections using a pencil eraser to clean the contacts could help. Just take an eraser (like on the back of a #2 pencil) and erase the corrosion from the contact points, both on the headset and on the charging dock. Once the contact points look like new, give it a shot ... this might clean up the power connection and help you out.
If the connection where the headphones meet the charging dock has a spring in it (usually on the charging dock side of the connection) then you might have a worn spring. Sometimes pulling on the spring loaded connector (VERY Gently, to stretch it back to where it should be) can help ... but this is a last resort method as if you pull too hard you can pull the connection too hard and disconnect it inside the dock.
If neither of these works, you will probably have to either bring it to a repair shop and see if they can help, or buy a new charging dock (though if the problem is on the headphone side a new dock might not resolve the issue. If you are able to find a position that you can sit the headphones on the dock that will still charge the phones, you probably just have a dirty or loose connection, though.
Jun 07, 2011 | Logitech ClearChat Pro USB Headset
Even though I keep putting new AA batteries in my Cannon PowerShot A540 - from one day to the next it reads "Low Battery". It didn't used to do this. Anything I can do/have checked out?
Please dear
listen before buying battery concern about the quality of batteries and they must be rechargeable and lethiam battery.
If you use no rechargeable batteries or after buying but didn't no charge then i will request you please charge your battery up to 6hours. thanks
Apr 10, 2011 | Canon PowerShot A540 Digital Camera
I keep getting "charging paused. a battery to hot
You might need a new battery. I have a new phone with my old phone's battery and I'm still having that problem. To get it to charge, I usually take the battery out and put in back in. It usually only charges normally for a few days before happening again though.
Mar 29, 2011 | Samsung Cell Phones
LG Viewty battery discharges quickly .....
Charging duration does not connect to battery lasting duration in any way.Optimal charging time is 3 to 4 hours.your battery will drain soon if you keep your touchscreen pressed continuously in your jeans pocket.Keep bluetooth switched off. Reduce the brightness of your mobile display. Play music threw headphone rather than using loudspeakers.
Jul 19, 2009 | LG KU990 Viewty
My logitech headphones dont turn on anymore.
Quote from LOGITECH official site:
In rare cases, the FreePulse Headphones may loose synchronization with the receiver. If this occurs the following steps will re-establish the connection by putting both the headphones and the receiver in discoverable mode (actively searching for another bluetooth device it can connect to).
Putting the headphones in discoverable mode:
Press and hold the power button (located next to the charging port on the right earpiece) on the headphones. The LED on the button will go through three states in this order:
  • Blinking Red
  • Off (continue to hold. the LED will be off for several seconds)
  • Alternately blinking red and blue. (The headphones are now in discoverable mode and you can release the button at this point. The headphones will remain in this state for 30 seconds).
Putting the receiver in discoverable mode:
Press and hold the power button (located on the side of the receiver opposite the headphone jack).The LED on the button will go through three states in this order:
  • Blinking Red
  • Alternately blinking red and blue. (The reciever is now in discoverable mode and you can release the button at this point. The reciever will remain in this state for 30 seconds).
Re-establishing the connection:
To re-establish the connection between the headphones and the reciever, put the headphones and the receiver in discoverable mode at the same time. It will take a few seconds for the two devices to establish the connection. Once the connection has been established the LEDs on both the headphones and receiver will glow solid blue.
Do this and Freepulse will be pleased.
Aug 15, 2008 | Logitech FreePulse Wireless Consumer...
Loss of power
I have always assumed this has to do with the level of the signal coming in.
I have had these headphones for a few years, getting them at a discount outlet for cheap, and have been quite pleased with them.
The light on the front indicates 3 things.
1) no light = not transmitting and not charging
2) green light = transmitting
3) red light = charging
When there is sufficient signal to transmit, the green light comes on.
If you are getting the signal from a Stereo, the line output may NOT be enough to keep the transmission on.
There seems to be a sensor, that figures out if htere is an incoming signal to transmit. I have toyed with the idea of locating that and disabling, so it would always transmit what is incoming, even if a low signal! But I don't have the know how.
As is, I use the headphones with my PC and generally it finds the signal strong enough to continue to transmit.
.. Thanks... Andrew
PS..The toughest thing about these haedphones, is going to be finding NiCad batteries to keep them working. If you go in the store these days, you can find lots of NiMetal Hydride, and NiCad are gone from the shelves!
Jun 13, 2008 | RCA WHP150C Consumer Headphones
876 people viewed this question
Top Sennheiser Audio Players & Recorders Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
