Question about LG 60PK550 TV
I am trying to connect my Denon AV surround receiver to my LG 60PK550 TV. I connected the cables to the receiver and to the back of the TV identical to how I had it connected to my Sony TV. However, when I turn off the speakers on the TV, like I had to with the previous TV in order to get the speakers to produce sound, it doesn't work. Is there a special setting on the TV I don't know about to make sound come from my external speakers?
  • LG Master
  • 2,192 Answers
LG 60PK550 only outputs the audio via the optical out port on the back of the TV the HDMI ports don't have arc capabilities
Posted on Jul 03, 2017
SOURCE: LG 42PC5D Sound Lag
I have the same issue. The audio seems to be okay through an antenna input, but not through an outside source input. There is about a 100ms audio lag, and the video is processed about 50ms faster than normal, making a total audio lag of about 150ms. To fight this I run any audio source through a separate receiver/stereo. The problem is now cut back down to the 50ms video lag difference. I am going to try putting video signals through the receiver too, maybe to induce some lag there and even things out even more.. Using the digital output does not help any (I've tried it), any audio is still processed by the tv and therefore slowed down.
Posted on May 11, 2008
shbuckler
  • 126 Answers
SOURCE: DVI-->HDMI cable causes tv speakers to hiss and pop
DVi to HDMI. ? hmmmmm
I recon you spend £49.99 and get a DVI & Audio to HDMI Converter. This will resolve the issue
Posted on Dec 25, 2008
SOURCE: connecting lg tv to two external speakers
Yes,
depending on how many speaker you intend to run will determine the type of amp you will need.  Set the output on the source unit to optical out.   Connect the optical cable to the amp.  Connect the speakers to amp.  turn them all on and select the iput of the source unit on the amp and enjoy.
good luck
chachig
Posted on Feb 11, 2009
  • 257 Answers
SOURCE: Screen is black even though the green light is lit
Tv has power supply board inside defective. This board needs replaced.
Posted on Aug 18, 2009
  • 65 Answers
SOURCE: I want to connect external
You don't necessarily need a receiver. You can use powered monitors (speakers). Powered computer speakers would also work. I have the 32" and use Beringer powered monitors using a standard 3.5mm audio cable to connect to the TV. Works well. Optical interface is available and would probably perform better but I doubt I would notice the difference.
Posted on Jan 03, 2011
How to connect a denon avr-e400 receiver to a televion
If the DENON has an HDMI output, and your TV has an HDMI input, then use a HDMI cable. Then, use the TV's remote-control to select "source" (or "input") as 'HDMI 2' or 'HDMI 3' (assuming that you have been using 'HDMI 1' to watch TV).
Feb 08, 2015 | Denon AVR-E400 7.1 Channel 4K and 3D Pass...
No picture with cable to denon AVR-589
Long and painful answer!!! However, in the end, you need to bypass HDMI thru your receiver and go direct to the TV. Connect Digital Coaxial or Optical for audio to your receiver. Your version of HDMI in your receiver is not compatable with today's HDMI version. Yours is 1.1a and the current version is 1.3b going to 1.4. If you want detailed info as to "why", just google "HDMI 1.1 problems" you can read for hours! Sorry for the bad news! However, it is what it is. Hope this helps. If you need further help with setup, post a comment and I can give you further help.
Feb 28, 2010 | Denon AVR-589 Receiver
How Do I Connect My Dell Laptop to a Demon AV Receiver
use a 1/8in stereo to two male RCA plug to connect from your computer headphone out to an input on the Denon such as AUX or CD
Jan 25, 2009 | Denon AVR-587
Tv built-in dvd player wont play thru surround sound
goto your menue setings and slect sround sound and set up to external sound system.
Jan 10, 2009 | Toshiba LCDTV/DVD Player 19HLV87
Back speakers with av denon 1908
Plug your rear 5.1 speakers into the surround speaker connections. Be sure to use the AVR 1908 set up menu to set rear speakers (not an amp assign). Hope this helps.
Jan 03, 2009 | Denon AVR-1908
use your t/v audio out with RCA cables to your reciever input like(vcr in, dvd in, dtv in)
Dec 20, 2008 | Yamaha HTR-5930 Receiver
Surround sound
Hi
Your receiver is capable of video conversion, so there should be no problem using your component cable.
Does your TV accept component, or only S-Video? If you can run component to your TV, the best quality signal path would be using a component cable from your Verizon box to your receiver, and component from your receiver to your TV.
Make sure you have set up the video input correctly, so that it is set to accept the incoming signal on the correct sockets.
Mar 21, 2008 | Audio Players & Recorders
Loss of sound on the Denon AVR 2807 a/v surround receiver when I turn on and off lights in my house
Finally the problem was with the HDMI cable. When I pushed it in on the TV set the problem disappeared. It seems the connections must be quite firm on the HDMI cables otherwise anything may interfere to the sound.
Jan 06, 2008 | Denon AVR-2807 Receiver
LG 60PK550 TV Logo
81 people viewed this question
