Question about Hotpoint HTS16HBR Top Freezer Refrigerator
My freezer makes cubed ice, crushed ice but it will not make water.Is the hose clogged or something?
  • 1,772 Answers
Hello and sorry to hear about your problem.
90% of the time you will have 2 issues, the water lever switch has failed or the main water inlet valve has failed. I suggest you call a service company.
I have tried to help you. So please help me and Vote/Rate this response. Thanks and good luck.
If you live in the Denver Area, I can help you.
Posted on Jan 04, 2011
Maytag MSD2651KES delivers crushed ice but no cubed
There is an metal arm that extends out behind the ice bucket that moves up and down when you press the cubed/crushed ice buttons. You need to take the ice bucket out and check the hardware. It's possible that some ice has managed to form in the unit and are blocking the motion. Remove any ice and check if the arm moves freely when you press the buttons on the refrigerator. Similarly, you should check if there is ice blocking the forward and back motion of the plunger in the freezer that bar sits on. This plunger is right next to the auger motor.
http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Refrigerator-Parts/Model-MSD2651KES/3048/0165000/W0703730/00013 has a picture of the ice bucket parts.
Dec 06, 2013 | Freezers
When I choose either cubes or crushed on my icemaker, my unit only crushes the ice. I already had the water inlet control valve replaced and there are plenty of cubes in the bin. It is a dispensing issue...
this manufacture makes 2 seperate style ice buckets one in the door and one in freezer with a large ice bucket and auger screw that turns... first we will explain the one up on a shelf in freezer side up top... if you pull your ice bucket completely out of freezer... there should be a small bar coming out of rear toward bottom of ice bucket assembly now put it back in where you got it but this time watch where the rod goes... there is a solenoid in the rear of freezer actually called cube/crush solenoid and what this does is if switched to crush will raise that rod and activate the teeth in bucket to crush ice... if not will let ice fall out in whole piece...this solenoid sometimes gets hung or will freeze ...make sure with your finger you can move it freely and then watch it with some assistant pushing the switch for you does it go up when the handle is hit... the ice bucket in door works the same way except the componets are in the door and a little harder to access... repost with any questions if this doen not help you out...good luck to you
Jan 19, 2011 | Whirlpool Refrigerators
Ice maker will only make crushed ice and no cubes, what could be the problem
Open the freezer door.
Pull the ice bin forward about 3 inches.
Push the ice bin to the rear of the freezer until it seats and locks in place.
Then try to dispense cubes.
The ice bin can become dislodged from its locked position and the crushed ice solenoid activates automatically.
Sep 17, 2010 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Have a gs201eta ww refrigerator ice maker problem Unit makes ice, light works and water dispenses from the door. However ice cubes and crushed iced does not dispense from the door. The dispenser motor...
The fridge gets its cold air from the freezer through a vent between the freezer and fridge. the fan in the freezer blows air through it. there is a flap you adjust with the fridge temp. control.
Make sure it's opening and closing when you adjust the fridge temp. try to chec in the user guide.
Hope helps.
Jul 07, 2010 | Refrigerators
Fridge Freezer model KA58NP90 Ice maker problem
What is most likely your problem is the crushed ice solenoid. This solenoid, which is located next to the auger motor behind the ice bucket, is failing to actuate when you request cubed ice. Its "home" setting is crushed, and actuates to allow cubes past the crushing mechanism in the bucket. To be certain its the problem, remove the ice bucket, and tape the door light switch in the closed position. actuate the ice dispenser lever, for both cubed and crushed ice. you will see a square hole next to the rotating fork, when you select cubes, it should open. If it does open, there is something wrong with your ice bucket, perhaps the arm is broken, or the door inside bucket is off its snap in type hinge or broken altogether. If it doesnt open, replace the solenoid
Expert Refrigerator Repair Service in Chicago and Suburbs
Mar 20, 2010 | Freezers
Just got Neff ice cube, crushed ice maker and ice
Will probably find the freezer fan has failed.Push in the door switch on left hand front of freezer with the door open & you should here fan running,if not new fan required.
Jul 01, 2009 | Neff K3965XO Side by Side Refrigerator
Can't make ice cubes only crushed ice
This happened to me. If you pull the ice bin out you will see a metal bar that extends from the front to back on the bottom of the bin. Find the square hole in the back of the freezer. Stick you finger in and slide the white plastic square up or down.
The switch you are moving is the toggle from crush to cube.
Jun 02, 2009 | Frigidaire FRS3R5EMB Side by Side...
Ice maker only makes crushed ice, no cubes I have the same problem... The same switch works fine for the crushed ice and water setting but will not dispense cubed ice. It only gives crushed.
hi.
I slid out the tray, found the lever in the back where the rod went in, pulled it down, reinserted the ice tray, and IT WORKED! At first I thought I broke the lever, because I had to hold it down with a knife while I was inserting the tray, but it just must have been stuck.
chek these sites
http://forum.appliancepartspros.com/refrigerator-freezer-repair/23620-ice-maker-only-makes-crushed-ice-no-cubes.html
There is an opening next to the auger that dispenses the ice. In there there is a lever that must move up and down. It actually seats the metal rod on the bottom of the ice maker and controls cube or crushed. Make sure the lever is down (cube position) when you return the basket to the freezer. I had to hold it down while I slid the rod into the opening. Cubes again. http://www.applianceblog.com/mainforums/showthread.php?t=783
if satisfied plz rate this answer
all the best
regards
May 27, 2009 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
GE Side by Side only dispenses crushed ice
remove the ice cube tray assy, remove all the ice, save the cubes, wash the assy with warm water dry the assy, be sure the lever in the rear of this ice cube assy is moving and spring loaded, move the lever and it should snap back and return if so you know the unit is ok(the cube assy), now with the assy still out of the freezer close the freezer door and select crushed ice and push the pad where the glass normally hit to activate the ice cubes,if the operates and you here a thump and snap and hum most likely your ok,if not you could have a defective auger motor assy,but if you here all the sounds as decribed oped the freezer door and select cubed ice push actuator on despensor door with the freezer door closed, reopen and install the ice cube assy tray bucket assy,push it in firmley, and try it with some ice in the bucket you should be fine,if not replace auger motor assy..
nbcrca:)
Apr 11, 2009 | GE Profile PSW26P Stainless Steel Side by...
The water dispenser in the door suddenly stopped working
Try checking the hose that goes from the freezer to the water pipe it is hooked up to, it may be clogged. If you aren't sure if it is clogged just go to home depot and buy a new hose kit witht eh spout, it cost no more thna $20. This happened to me and when I replaced the old hose and spout with a new one it worked fine.
Jan 14, 2009 | GE Profile 20.7 cu. ft. CustomStyle...
Hotpoint HTS16HBR Top Freezer Refrigerator Logo
37 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
