Question about Kodak EasyShare M575 Digital Camera
New camera. Used it for a few days over Christmas, now battery won't charge. Have tried via 3 differeent computers, and via the wall adapter overnight. Nothing. Is there some simple step we're missing?
    Master:
  • 340 Answers
Have you use your USB communication transformer to connect your kodak camera to your PC? This USB communication transforme is designed to charge your Kodak camera battery in your camera.
Posted on Jan 04, 2011
  • jaded200 Feb 09, 2011
    I have the same problem..and yes, the battery is in the camera and connected to the PC via the USB.
I have a Nikon finepix s6000. I just got it for Christmas as a present. A week a go I turned the camera on and it turned itself off with the lens still sticking out. I googled and ordered a new battery, a...
You should still be covered under the Nikon Factory Warranty.
You can stop paying to try to fix this yourself by simply contacting Nikon and let the solve the problem for you. That is what they are paid to do - and this service is built into the price paid for the camera.
Contact Nikon directly at: 1-800-NIKON US (1-800-645-6687) 8AM-12AM EST, 7 days a week.
Mar 02, 2013 | Cameras
Laptop won't startup on power or battery
Step 1:
Take the battery out, plug in the charger and see if the laptop works. If it works, the battery may be the problem. Check the AC Adapter
Check to make sure the adapter is plugged securely into the wall outlet, connected firmly to the adapter box and to the back of your laptop. Most AC adapters have a little light in them on that rectangular box in the middle of the cord that lights up when it's getting electricity. If that light isn't on, try a different outlet. Check your fuse or circuit breaker box and plug a different device into that outlet to make sure there is power to it. If it still does not light up, your adapter could need replacing. Also check the adapter box for signs of warmth, as it will generate heat when it's plugged in. No heat means no power.
Remove the Battery Sometimes it's as simple as a seated battery. Remove the battery entirely and clean out any dust, lint or hair that may be clogging the connectors and preventing a proper connection. Reseat the battery securely and make sure the little locking pins that hold your battery in place are securely fastened and there is no movement. Unplug your laptop while it is running. If it still works, the battery has been charging. If it shuts off, or doesn't hold a charge very long, you have a bad battery. Unplug your laptop while it is off, then try to turn it on. If the battery is bad, your laptop probably won't turn on at all. Turn off your laptop's screen-saver when testing its battery. The screen-saver will conserve the battery and not give a clear time frame for how long your battery can really last. Click the battery icon on your laptop when it is unplugged. It can tell you how much battery life you have available. This icon is usually located in the bottom right corner of your screen and will provide the percentage of battery power you have left. Keep track of the time it takes to go from 100% charged to 1% charged. If this takes less than an hour, your battery is probably beginning to fail. You can also try this every week or two to see if your battery holds a charge for shorter periods. Factor in the amount of time you have used your laptop. Most laptop batteries last 2 to 3 years or about 500 charges. Wait a few days before determining whether a new laptop battery is faulty. New batteries sometimes take a few charges to build up to their maximum run time.
Feb 07, 2013 | ASUS F3SV-B2 Notebook
HTC battery wont charge
If the cell phone battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Dec 04, 2011 | HTC Desire Cell Phone
Camera was low on battery. Took a couple of pictures with no problem then got it home to charge the battery and the camera is dead. Won't turn on or charge. Tried plugging it in directly with the...
1. Check if the battery is positioned and seated well in the camera.
2. If OK, and problems persists, exchange the battery and recheck.
3. If that does not help, your camera needs probably to be repaired.
Aug 05, 2011 | Olympus SP800UZ Digital Camera
I have sony cybershot dsc 10 digital camera but it dsn't power on batery charge is full
Please make sure that the Battery in the Camera is fully charged.
Please check if the issue is with the battery charger. Make sure that the Charge Lamp in the Battery Charger is lit when connected to the Wall outlet.
You can try recharging the battery pack for almost 6 hours as initial charging.
If you've another battery pack, try using the same to check if the issue is with the Camera or with the battery.
You can also try turning on the Camera by connecting the optional ACL-S5K AC Adapter. This Adapter can be used for turning on the Camera, it cannot be used to charge the battery pack. For charging the battery in the Camera, the supplied battery charged needs to be used.
If the Camera is not turning on using both the AC Adapter and new battery, then the Camera may require service.
Thanks for using FixYa.
Jan 10, 2011 | Sony Cyber-shot DSC-H10 Digital Camera
I have sony digital camara but it dsn't power on batery charge is full
Jan 10, 2011 | Sony Cyber-shot DSC-H10/B Digital Camera
I have sony digital camara its not power on plz help me
Jan 10, 2011 | Sony Cameras
Will Not charge
It happens, one of the cell in the battery went bad.
Try new battery.
Mar 19, 2009 | Kodak Easyshare M893 Digital Camera
Kodak EasyShare M575 Digital Camera Logo
88 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
