Question about Whirlpool GU2400XTP Built-in Dishwasher
I have a Whirlpool GU2455.... dishwasher. Top spray arm is not spinning. Lower arm appears to be moving but slowly. Dishes on the top rack do not get cleaned. They are wetted, but the arm doesn't appear to be moving to allow all of the dishes to be cleaned.
  • Whirlpool Master
  • 43,501 Answers
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
heatman101
Posted on Jan 04, 2011
Hi, the dishes on the top rack of our Whirlpool Quietmaster III do not dry completely, but the bottom dishes are fine. We have to re-wash the upper rack dishes; they have spots on them. Ron.
Make sure the top spray arm is turning! check for blockage in the jets at the very end of the spray arm, or that the spray arm has not split. Put the arm in a known position, and check it has moved after a few moments. Remove blockages or replace the arm if necessary.
These machines dry only by the last rinse being in hot water, then the plates drip dry. Are you using rinse aid? this helps the water to disperse without spots.
Jan 30, 2018 | Whirlpool Dishwashers
Whirlpool Gold Dishwasher - GU2700XTSB The top rack of the dishwasher is not cleaning. The bottom rack dishes clean fine. There are no clogs in either the bottom or top spinner arms, the plastic tube...
Dishwasher
How to Buy
Dishwasher Residue and Film on Dishes
heatman101
Jan 20, 2011 | Whirlpool GU2700XTSB / GU2700XTSQ /...
My dishwasher sprays water up into the dishes but the little spray arms don't move when the water sprays up. The arms move by hand when I touch them. What could this mean for my dishwasher?
When my wife started complaining about her dishwasher not getting the top rack clean this is what I found and I wrote a tip about it...
Dishwasher Spray Arms not Spinning
heatman101
Aug 31, 2010 | Whirlpool Dishwashers
The top rack of dishes are not getting clean. I
you need to check the upper wash arm for blockage from debris,if this is not the case,then you need to replace the water conduit from the lower sump area to the top arm,after time the water erodes the plastic conduit especially where it connects at the arms and water gets by these areas and can no longer build pressure to spin the wash arm
Apr 19, 2010 | Whirlpool DU1055XTS Built-in Dishwasher
Dishwasher lower spray arm falls off
These parts can be replaced easily and reasosnably cheaply for example the top spray arm is about £20.00p. But you need the back water feed tube as well as the lower spray arm which should come as one package. (depending on model i'm going by bosch). You shouldn't have to pay more than £30.00p + p&p. Hope this helps.
May 19, 2009 | Dishwashers
Dishwaher does not clean, upper rack
The top rack is not cleaning because of low water pressure from the wash motor to the upper spray arm.
Assuming the top spray arms are clear of debris, remove the lower spray arm to access the wash motor. Remove the 4 torx screws and the filter (accumulator assembly). Remove the torx screw and the inlet protector that covers the chopper assembly. Make sure the chopper is not broken (broken chopper will fill with debris and block water flow). While holding the chopper blade, reach inside the "D" shaped opening on top of the motor and spin the wheel/motor by hand in each direction to make sure either the chopper gear or the motor gear that drives the chopper is not broken. Replace the chopper if necessary (part # 8268383). If the motor gear is broken, replace the sump and motor assembly (part # 8535150). Remove any debris from the sump area in the process.
You don't have to shut the power off to the dishwasher because the door will be open, but if you feel more comfortable, do so.
Mar 13, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
Top spray not functioning in dishwasher
Assuming the top spray arms are clear of debris, remove the lower spray arm and lower feed tube to access the wash motor. Remove the 4 torx screws and the filter (accumulator assembly). Remove the torx screw and the inlet protector that covers the chopper assembly. Make sure the chopper is not broken (broken chopper will fill with debris and block water flow). While holding the chopper blade, reach inside the "D" shaped opening on top of the motor and spin the wheel/motor by hand in each direction to make sure either the chopper gear or the motor gear that drives the chopper is not broken. Replace the chopper if necessary (part # 8268383). If the motor gear is broken, replace the sump and motor assembly (part # 8535150). Remove any debris from the sump area in the process.
Mar 09, 2009 | Whirlpool 24 in. GU2500 XTP Built-in...
The upper rack doesn't not appear to get all the dishes clean. Why does this happen?
You don't have to because the door will be open, but if you feel more comfortable shutting off the power to the dishwasher, do so.
Mar 05, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool GU3200XTP dishwasher - No spray on upper rack
Sounds like the hose assembly that attaches to the rear of the upper rack has come undone. just pull out the upper rack and reconnect it.
please rate my answer as a fixya! thanks.
Feb 14, 2009 | Whirlpool 24 in. GU3200XTP Built-in...
Whirlpool GU2400XTP Built-in Dishwasher Logo
340 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
