The heatsink keeps the CPU from getting too hot and the fan cools the heatsink. These fans are temperature controlled by the BIOS firmware. When there are problems that need to be fixed(updated) Dell creates a new BIOS flash firmware which can be found on their website. Make sure your BIOS version is the latest. You can see which version you have while the laptop is booting, press F2 to get into that BIOS. My D600 ran hotter than I expected until I updated the BIOS firmware.
I had A16 for my D600.
The fan were running fullspeed all the time.
Anyway to tweak/hack to solve the problem...??
Thanks
You need to clean the dust off the radiator inside that cools the CPU, (you have to open the laptop) DO NOT BLOW AIR IN THE CASSING'S VENT becaus dirt will back up and clogg the fan, an other thing that could help is to re-paste the CPU (TAKE OFF THE CPU HEATSINK AND INSTALL NEW THERMAL PASTE)
The thermal sensor is built in the CPU, just to make sure that the readings are OK you could try booting witn a UBUNTU 10.10 live CD and check the temp again (I've seen it befor) some times the software that reads the CPU sensor can be off a lot, in UBUNTU just ADD TO PANEL the CPU TEMPERATURE ICON and verify if it reads the same thing, if not then dont worry if it does than it could be a defective sensor, try mesuring it with an electronic thermometer directly touching the heat sink
good luck!
Don't worry most laptops nowadays run hot. your CPU will shut itself down long before damage occurs. try elevating your laptop to promote air circulation or place it on a cooling mat.
Be careful if you set it on your lap, some people have had minor burns from laptops setting on their laps for prolonged periods.
I mean steady 85.5c steadily all the time...
I had another same model but i run juz around 40C while idle n the fast wont run high before 60C...
I already clean the dust n new thermal paste....
Still having the same prob.
Can any1 tell where's the temp sensor located???
I already update the Bios to the latest A16. But still the same. Haiz...
