Question about Toshiba Computers & Internet
I have a yellow triangular warning symbol on the 6To4 Adaptor driver with an error message of code 31. How can this be fixed ?
  • 114 Answers
Code 31 usually indicates a driver error, try reinstalling the driver.
Posted on Jan 04, 2011
Dell error code 31
Open Control Panel and then Device Manager (or System, then Device Manager).
Look for a yellow balloon, this should show you which device is giving the Code 31 error.
Then you need to fix the problem by re-loading the driver.
Mar 04, 2015 | Dell Computers & Internet
Microsoft isatap adapter driver
goto device manger from my computer properties and hardware with yellow caution i symbol have something wrong
Jan 11, 2014 | Gateway Computers & Internet
What is the driver for microsoft 6to4 adapter #8
Hi Friend,
6to4 adapter is a component used for transmitting IPv6 packets trough IPv4 network correctly.
In some scenarios, there will be a code 31 or code 10 error appearing beside this component. A possible reason is, the network adapter doesn't support this feature. You may update the driver for your network adapter or chipset, and then try to Uninstall and reinstall the this component.
To Uninstall the component, right-click the item in Device Manager and select Uninstall.
To reinstall the component, in Device Manager, Action - Add Legacy Hardware - Next - "Install the hardware that I manually select from a list" - Network adapters - Microsoft - Microsoft 6to4 Adapter - Next - Finish the wizard.
If the steps above doesn't solve the problem, your network adapter is not a supportive one for this component. You can completely ignore this error, if there isn't IPv6 network deployed in the environment. The error won't affect your system.
To remove the error message, please right-click the Command Prompt and run as administrator, type the command netsh in 6to4 set state disable, press Enter. The component will be disabled and hidden.
Regards
Chiranjeet
Sep 17, 2010 | Computers & Internet
6 to 4 adapter no working and 1 Sat adapter #2 adapter not on, so I cant connect to internet, how can I fix this
I would like to bring to your notice one of the issue that came across with a Vista based PC of a EU who reported in his mail that in "Device" manager their are 6 to 4 adaptor is listing by name itself and for this he is unable to install any drivers as it is showing that the drivers are not installed for it. Even though EU is able to browse the internet.
Normally the above issue is related to TCP/IP transmission protocol that uses by Vista. As Vista by default support IPv6 TCP/IP protocol for data transmission over the network. 6to4 adapter is a component used for transmitting IPv6 packets trough IPv4 network correctly. If the drivers for this component is not properly installed or corrupted there will be a code 31 or code 10 error appearing beside this component. You may update the driver for your network adapter or chipset, and then try to uninstall and reinstall the this component as mentioned below. I am enclosing a snapshot of the issue along with the mail so that you can also have a clear idea of the issue.
=======Uninstalling 6to4 Adaptor==========
1. Click on Windows icon, and enter device manager into the Start Search field.
2. Right Click on all 6to4 adaptor and select uninstall from the droplist.
=====Reinstalling 6to4 Adaptor===========
2. From the device manager window select "Action".
3. Select "Add Legacy Hardware".
4. Click on Next.
5. Select "Install the hardware that I manually select from a list".
6. Select Network adapters from the window.
7. Select "Microsoft" from left window.
8. From right window select "Microsoft 6to4 Adapter"
9. Click on next and finish the wizard.
After performing the above steps issue shoule get resolve. If the issue persist then, I request you to disable this device in device manager. By disabling this it will not effect your internet browsing or your wireless conectivity, as Microsoft also confirm this in their database. In order to disable this device perform the below said steps.
1. Click on Windows icon.
2. Select Accessories.
3. Right click on "Command" prompt.
4. Select "Run as administrator".
Once the command window open, type the below said command.
After typing the above command press enter key on the keyboard.
After performing the above steps restart the PC.
Apr 05, 2010 | E-Machines eMachines Desktop PC
Device manager problem!
It sounds like Windows is not recognizing the digital signature of the drivers. If they are the current Dell drivers, you can simply ignore the flags.
If you are bothered by them, you can try removing the device from the D.M. and re-installing to try to resetting the digital signatures. (this may not remove the flags)
Mar 26, 2010 | Dell Inspiron 1501 Notebook
Hello, i have a hp notebook which code 31 error on
http://support.microsoft.com/kb/932520
Microsoft says to Ignore the problem, and the adapter will continue to work correctly. If the message is really annoying maybe you can try turning off IPv6.
Control Panel\Network and Internet\Network Connections
right click your network card>properties
uncheck the IPv6 box
that'll turn off IPv6-then just disable the adapter driver
Feb 23, 2010 | HP Pavilion dv6000z Notebook
6t04 code 31
To solve this problem with 6To4 adapter device with code 31, make sure you do the following:
1). Make sure you have all the updates installed for vista, such as, Important and Recommend updates.
2). [Right Click] my computer icon, and select (properties).
3). Select (Device Manager).
4). [Right Click] on the 6To4 icon, and select (Update Driver Software).
5). Click [Browse my computer for software drivers].
6). Click [Let me pick from a list of device drivers on my computer].
You should see the Microsoft 6To4 adapter listed?
If not you must uncheck the [] box show compatible hardware.
7). Then scroll down the list of Manufacture until you find (Microsoft), NOT Microsoft Corporation!
8). Click on (Microsoft) as the Manufacture and scroll down about two clicks, you should see 6To4 adapter.
9). [Left Click] on Microsoft 6To4 adapter and (Click Next), it should load the drivers as normally.
Dec 04, 2009 | Dell Inspiron 1545 Notebook
Why is my 2 month-old HP laptop showing a yellow exclamation for 6to4 adaptor and indicate ''this device cannot start (Code 10)? should i do something?
The driver is not working for the item in question what is yolur make and model for the laptop you can go to hp website and download the correct driver and the problem should be fixed. If you wish please contact me at http://www.nittron.com and i would be happy to help out more
Nov 09, 2009 | HP Computers & Internet
6to4 adapter not working...
Check the device status under the Device Manager. if the status of the device was just "drivers were not installed..." you may simply click on update driver button on the same window. If the error is code 10 or device could not start, the problem has something to do with the hardware. call the manufacturer of your laptop and check the warranty if it is still covered.
Jul 16, 2009 | Enterasys Network adapter
Computers & Internet Logo
114 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
