When I turn on my tcl airconditioner it seems to work for 1 minute then I either get an error message e0 or e5. I've only used the airconditioner half a dozen times & it's 12 months old. How can I fix this? Thanks
  • 2,133 Answers
E-5 with blower motor mechanism locked.Please rotate your blower motor manually, if it's hard, replace bearings or motor.
E-0 means communication error between indoor to remote.Replace new batteries in remote and try.
Posted on Jan 04, 2011
Runs 20 sec stops reads F1E5
Error Code/Message - Oven - F1 Error Code - F1 E5
Control displaying F1 E5:
There may be a problem with the Oven Control, or the associated wiring.
Power unit down by turning off the circuit breaker(s) for one (1) minute.
Power unit up by turning on the circuit breaker(s).
Monitor the oven for one (1) minute to ensure the error code does not display again.
Verify oven operation.
Oct 23, 2015 | KitchenAid KEMS309BSS Combination...
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
on Apr 24, 2015 | Kitchen Ranges
Tip
F5 - E0 Door Switch
Two digit codes:
Regards.
on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Fix f5 e 1
F1 - E0 EEPROM communication error 1. Disconnect power for at least 30 seconds.
2. Re-apply power and observe for at least one minute.
3. If code re-appears, replace control board (also called ERC or clock).
Note: Applies to all F1-E... codes except F1-E3. F1 - E1 EEPROM checksum error F1 - E2 UL A/D error(s) F1 - E4 Model ID error F1 - E5 Calibration shifted F1 - E6 Latch signal mismatch error F1 - E9 Stack overflow F1 - E3 Wiring harness cavity size does not match previously stored value The "Cavity Size Select" jumpers in the wiring harness indicate a cavity size different from that which the control was previously configured for. Check the jumpers in the harness to make sure they agree with the actual oven size.
Jun 05, 2015 | KitchenAid Architect II Superba EQ Series...
My tcl split ac works for 5 min, then gives e5 code.
E5 s a communication error between the indoor and outdoor units. It is stated in the service manual that the wiring between the indoor and outdoor has probably separated at one end of the terminal block. Most of the time however, it is usually a failure of either the indoor or outdoor electronic boards. A multimeter and knowledge of how to read "communications voltages is required. The machine will continually assess itself electronically to make sure all components are working properly. If after a given amount of attempts to communicate with the outdoor unit the machine still cant "talk" to the other 1/2 , it will show an E5 error and shut itself down. You could try switching off the power at the isolator or meter box for at LEAST 15 minutes and then turn back on to see if it resets. This sometimes works. Do not, just switch off and switch straight back on again.
Mar 24, 2015 | Heating & Cooling
KitchenAid KHMS155LSS when press "bake potato" button,start flashing error F3
Question: Error Code - Oven - F3 Error Code - F3 E0 Answer Product Symptom:
Error Code/Message - Oven - F3 Error Code - F3 E0
Control displaying F3 E0:
There may be a problem with the Oven Temperature Sensor, or the associated wiring.
Jul 31, 2014 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Error E5 for Pye airconditioners
Re boot it. Unplug for a few minutes, then plug in again.
Jan 30, 2014 | Dryers
I'm looking for an enigma split system airconditioner manual-I have an error message E5 with no compressor activity
E5 Communication errorbetween outdoor and indoor. Check output (call) from your indoor unit to out door unit by Volts meter. If no power in out door, you have to check setting of temp whether it's 23 and less than that and also mode in "Cool".
If power is there in out door and fan only running means compressor is tripped by overheated
Dec 16, 2010 | Heating & Cooling
On the PC785, I tried shorting the JP1 & JP2 solution.
Hello sir; If you repeat same shorting procedure still don't work then you have to check heater lamp or thermos fuse brown.
Aug 28, 2009 | Canon Office Equipment & Supplies
Heating & Cooling Logo
549 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
