Question about Toshiba e-Studio162D Copier
HELLO I HAVE A HORIZONTAL LINES IN THE COPIER, I REPLACE THE IMAGINE DRUM AND THE DEVELOPER, BUT THE LINES STEEL THERE, I CHECK THE FUSER BUT THE RED DRUM IN THE FUSER ASSY DOSENT LOOKS EVEN, I WANT TO KNOW IF IS POSSIBLE TO RESET THE IMAGINE DRUM MEMORY. I MAKE 3 TESTS, 1ST COPY IN WHITE PAGE, THE RESULT IS A CLEAN COPY, 2ND COPY WITH THE TOP COVER OPEN IT LOOKS OLMOTS COMPLETELY DARK, 3ERD I COPY A NORMAL DOCUMENT BUT THE INBOUND IS GRAY, ITS POSSIBLE TO CHANGE THE QUANTITY OF TONER CHARGE ON A COPIER? WHAT CAN I DO?
    Problem Solver:
  • 5 Answers
Check charge strip, charge corona... wash it with water for me it works
Posted on May 31, 2012
5 Suggested Answers
  • 31 Answers
SOURCE: e350 misfeed on print/copy 2nd page
Does this happen from all cassettes or only one? What are you getting for a jam location??
Posted on May 23, 2007
Bubbabear64
  • 2794 Answers
SOURCE: How to change developer on Toshiba 2060 copier?
Changing the developer is a procedure for service technicians to do.  You might want to ask that question on copytechnet.com.  There are Toshiba service technicians on that can help you with that.
Posted on Sep 13, 2008
  • 51 Answers
SOURCE: IN NORMAL COPY FUNCTION I GET A GRAY THICK LINE AT
sounds like drum and exposure adjustment. Analog machine...could be charge corona or transfer corona are dirty or tired
Posted on Apr 06, 2010
  • 132 Answers
SOURCE: just been given this 1360
open the machine and lift the red fuser cover and check the exit sensor make sure that that the flag moves easly then makr sure the registration sensor flag moves easy as well the sensor is located at the black roller in the bottom of the machine there is a cutout in the plate you should be able to see the flag if not it is stuck in the open position the figure 8 is a paper jam error
Posted on Mar 07, 2011
Why printer leaves horizontal streaks?
It might need a drum replacement or a fuser replacement.
May 30, 2015 | Samsung SAM CLP315 COLOR LASER PRINTER
Please wati mesage on power on on bizhub 164 machine
Sir/Mam Have you had the developer and drum replaced recently, or does the screen say Replace PC Drum? There are certain house chores the copier does before "Ready to Copy" it is waiting for them to get done, so that equals "Please Wait". One big item is making sure the developer and toner are properly mixed inside the image unit underneath the drum or next to it depending on the series. Might want to have the developer replaced and drum/cleaning blade normally done all together, then run the F8 procedure/Developer Charge, and make sure the counters where cleared. Did you recently replace the drum and the developer if so did you clear the counters for the drum and developer, FIRST? IF not then the copier thinks the new drum and new developer are old. The copier works on the counters that is how it knows it got a new drum and developer. Get new developer and a new drum and have it installed correctly. Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade. (DO NOT USE A VACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. Then reinstall and RUN F8/Developer Charge. Make sure the fax line and Ethernet cable is removed can't print anything until the F8 is run. Or you will start all over again with new developer and a new drum.
Jan 16, 2014 | Konica Minolta bizhub 200 Printer
Horizontal lines are occurs in the print
could be drum,fuser or optics. stop copy under drum. if lines replace drum cartridge. you can see fuser through left door. teflon would be damaged on heat roller.
Nov 03, 2012 | Canon imageRUNNER 400S Copier
Dark display on hp 4600 color laserjet
This could be a faulty Formatter board. Can you swap it with a good one?
Mar 02, 2010 | HP LaserJet 4600dn Color Printer
My e-studio 45 has 260,000 copies and says it needs maintenance. It works well. Do I just replace the drum or does it need other parts like a fuser too?
Hello sir; When it said need maintenance, it means need PM( periodical maintenance) that including drum, drum blade ,developer, corona wire, etc. the fuser and pressure roller depend on condition.
Feb 01, 2010 | Toshiba e-Studio 45 Black and White Copier
I am experiencing lots of horizontal lines, changed the toner but still getting them?
clean inside of the printer and transfer roller , drum unit and shake the PU unit and check .........
Nov 17, 2009 | HP LaserJet P3005dn Printer
I have three horizontal lines across the printed document
Here is the print defect information from the service manual.
1. Toner Cartridge.
The circumference of the photoconductive drum is 3.75 inches (94mm). The circumference of the developer roller is 2 inches (51mm). If a defect appears in the print image at these intervals, assume the defect is associated with the Toner Cartridge. Replace the Toner Cartridge.
2. Fuser Assembly.
The Fuser Roller’s circumference is approximately 2.5 inches (63mm) for the LJ4, and 3-1/8 (79mm) for the LJ4+/5. If a defect
appears at this interval, assume the defect is associated with the Fuser Assembly. Clean the Fuser Assembly rollers. Replace the assembly if necessary.
3. Dirty Roller.
Any dirty roller along the paper path may result in a pattern of
repetitive print image defects. Examine and clean rollers along the
paper path.
We have the full service manual download available for $6.95 if you need it. We also carry all repair parts for your printer.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of PC and printer support/repair
Jun 29, 2009 | HP LaserJet 4 plus Printer
Docucolor making lines
Hi!
Have you tryed to switch drums (magenta - yellow)? There may also be a problem with developer. If it is not your Magenta drum, it might be the fuser as well - if you pull out your fuser and look on that outside area, you may see a bunch of squiggly lines on it. If so, replace it. If neither your drum replacement or fuser replacement does it, then it is the developer which needs replacement.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 29, 2009 | Xerox DocuColor 12 Printer
Mita DC-1860 horizontal streaks after new drum
You say 'horizontal", but I imagine your paper is actually travelling 'laterally' or or sideways through the machine right? That means that the lines are actually running vertically based on the paper direction.
Is that 2" wide line visible on your drum?
Drum cleaning blade has likely failed....it should ALWAYS be replaced with a new drum.
Feb 25, 2009 | Office Equipment & Supplies
Horizontal Striping Problem on a Dell 5100cn
As you have just replaced the drum you may have a faulty drum unit put old one back in a test if lines go way then return drum to store and get a replacement. If they do not go the check the toners and the fuser unit.
Thanks J
Jan 21, 2008 | Dell 5100cn Laser Printer
Toshiba e-Studio162D Copier Logo
262 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
