Question about Samsung HT-TQ85 Five DVD 5.1 Channel Home Theater Audio System System
I have a Samsung LA32A550P1FXXY 32 inch LCD (series 5?) and a Samsung HT-C550/XSA home theatre. Most of the time when I play a DVD, I have to disconnect the ANYNET function, as it will play the sound without any voices. Any reason why?
  • 3 Answers
SOURCE: Samsung DVD plater HT-X30
Try to burn your cd with CD-R 650MB/74 mins.and play: i believe it will work.
Posted on Jun 13, 2008
SOURCE: showing "Disc Error" While playing DVD's
HEY I HAVE THE SAMSUNG HT DS100 DOES IT HAVE USB PORT CAN I USE MY PEN DRIVE
Posted on Aug 09, 2008
  • 20 Answers
SOURCE: samsung ht-z310 home theatre audio problem
IS THE ONLY CONNECTION BETWEEN YOUR TV AND THE HOME CIMEMA RECIVER THE HDMI ? AS TTHE HDMI WILL ONLY PASS INFO FROM THE RECIVER TO THE TV AND NOT VICE VERSA. IF THIS IS THE CASE YOU NEED TO CONNECT THE TV VIA EITHER OPTICAL/DIGITAL OR PHONO LEADS FROM YOUR TV TO AUX INPUT ON THE RECIEVER
Posted on Oct 03, 2008
All,
I submitted an earlier request trying to determine why surround sound wasn't coming through all speakers when playing my TV.
Looking further into the Samsung site I found out that you MUST connect the optical cable from the home theater unit to the CABLE BOX and not to your TV to get surround sound...I'm currently in the office but will change the connection once home...try connecting to your CABLE BOX instead of your TV and it should resolve the problem.
Posted on Mar 23, 2009
SOURCE: Samsung HT-BD2R 7.1 Channel Blu-ray Home Theatre System
If your television has RCA style audio/video output you can use an audio RCA cable (red & white connectors) and simply plug from the 'output' of your television into the auxilliary input on the back of the HT-BD2.
Then select AUX on the HT-BD2 remote, whenever you wish to listen to the television audio.
Posted on Mar 30, 2009
Samsung home theatre HT-X30,
The DVD player may have failed.
Dec 19, 2013 | Audio Players & Recorders
Samsung ht-c550 dolby pro logic II mode does not work.
1. Go to the DVD input.
2. Select menu
3. Settings
4. Audio
5. ASC
6. Turn OFF the Auto Sound Calibration
7. Exit the menu
8. Go to the DVD input and retry the pro logic II button and switch to MATRIX.
(Also you have to enable the "matrix" setting each time on all of the inputs you use.)
Jul 07, 2010 | Samsung HTC550 Theater System
Dvd player wont play burned movies
most of the movie if download from the net protected my different formating keeping people from burning and selling coppies. as long as your dvd play dvd is working fine. I got lots of those downloaded movies from a friend myself some play and some dont. I bet you if you go through most of your copy dvd some will play and some dont. Your sysytem may read some dvd VS mine may read some of your's that you system dont reads, you will not find a unit" DVD" will deformat the protection copy rights. I have 850.00 unit almost top of the line still wont read lots of copy DVD.
Jun 04, 2009 | Samsung HT-DB600 System
Connect home theatre to 32" lcd to ps3
Depending on the year of your model of VIZIO your digital optical output may be tied to the DTV input only. Meaning the only time you will have audio coming out of the digital optical output is when your using the tuner and your on a digital channel. If your television is newer and the digital optical output is in white on the back of the television than it is tied to HDMI and the DTV Tuner and you will pass audio through the digital optical output when using HDMI or the Digital Tuner.
Now to get connect the HT: Normally you would run a digital optical cable from the source device to the home theatre system. Meaning if it was a PS3 you would run a optical cable from the Digital Out on the back of the PS3 to the Digital In on the Home Theatre receiver. If it was a DVD player than you would run the optical cable from the DVD player to the HT receiver. If you have a newer VIZIO and the optical output is in white and not black than you can run HDMI from the PS3 to the VIZIO and then run a optical cable from the VIZIO to the Home theater receiver.
You will have to adjust the audio setting in the PS3 to run audio out of the HDMI port if it is set to run audio out of the Digital Out or AV out. Also, if your going to run audio from the PS3 to the HT receiver through the Digital Out then you need to change the audio setting in the PS3 to Digital Out.
1. Select (Sound Settings) under (Settings) in the home menu.
2. Select [Audio Output Settings].
3. Select the input connector on the audio device.
Channel numbers and audio formats that are supported vary depending on the connector in use. AV is 2 ch. only, Digital Out is 2 ch. & 5.1 ch, and HDMI is upto 7.1.
Apr 05, 2009 | Vizio L32 32 in. LCD HDTV
The audio will not play through the tv from the home theatre unit
because you do not have the dvd player hooked up to the tv, if you want it to play through the tv then you need to have the dvd player connected to the tv.
Mar 21, 2009 | Samsung HT-Z310T Theater System
Samsung series 6 tv & Samsung 2:1 home theatre problems
if you got all the lead you should have fibre optics which connects from dvd to tv and then set your dvd to digi in. you should get the sound. i have same cinema system and i have done the same
Jan 13, 2009 | Samsung HT-X20 Home Cinema 600W Theater...
Audio video converters
click on this link if you cannot just copy and paste to your browser and go to the site. Dynex makes the converter you need to go from composite video to s-video.
http://www.bestbuy.com/site/olspage.jsp?skuId=8470139&st=composite+video+to+svideo&type=product&id=1184768166778
Nov 04, 2008 | Samsung HT-X20 Home Cinema 600W Theater...
Apr 03, 2008 | Samsung HT-X40 System
Showing "Disc Error" While playing DVD's
the disc tray is not leveled properly, i had the same problem too and samsung repair centre just adjusted the tray.
Apr 29, 2007 | Samsung HT-DS100 System
Samsung HT-TQ85 Five DVD 5.1 Channel Home Theater Audio System System Logo
133 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
