I am looking for a parts break down and a heat deflector for an Armstrong G63-100 furnace
3 Suggested Answers
tborn6
  • 700 Answers
SOURCE: Furnace doesn't reach desired temperature
On the thermostat if its a manual on then pop the cover off and look for a small dial with numbers on it. Take and move it tpoi a higher number than whats it is set at. Its called a heat anticipater and is supppose to make it so that the unit does not oveshoot or under shoot like what your experiencing. If its a digital oine then you are going to have to configure the setting in the insdtallers menu.
Posted on Dec 21, 2008
  • 288 Answers
SOURCE: sequencers keep breaking down on RUUD heat pump
the control voltage for the sequencer should be 24 volts. that needs to be checked. also the sequencer is a switch that allows current to pass through them and are rated at particular volts and amps. If you are having and overcurrent situation, then it may burn them up. this one is tricky because and overcurrent should burn up the fusable links at your heating elements first. I would have these voltages checked and make sure only one sequencer per heating element. the low voltage side may be wired in series but the line voltage should be parallel or not sharing the 240 volts
Posted on Dec 15, 2009
Is 32c a normal temp for an exhaust on a force air high efficiency house furnace? This is the air temp that goes outside after heating the plenum. Is there a lot of heat going up the "chimney"??
Any furnace providing heat where it should and has little to no heat from its exhaust is doing a GREAT job ;-)
Our high efficiency gas furnace was installed with a PVC pipe as a 'chimney' which bothered me to no end until I found the surface temp of that plastic pipe only barely warm to the touch- that is a home run!
Jan 09, 2015 | Emerson Lennox Ducane Armstrong Furnace...
Armstrong eg6g75dc104
it should be on the inside of the door look for flash codes there is no code book you just have to know post code and what it says on the door and I can help
Nov 12, 2013 | Heating & Cooling
I have an Armstrong SX Ultra 90 propane gas furnace that the fan motor will not shut off ,the thermostat is on auto.
Hit the side of the furnace. Some times there's a sensor inside that gets locked up from a dirty filter.
Oct 19, 2013 | Emerson Lennox Ducane Armstrong Furnace...
Furnace burners won't ignite
Assuming this is a gas furnace, when the thermostat calls for heat the pilot heats an igniter to produce voltage that opens the burner gas valve. In your furnace, the igniter may have failed and the burner can't fire up
Mar 09, 2013 | Sport & Outdoor - Others
Heater heats but shuts off
Try the fan in the ON position on the thermostat, do you mean the fire shuts off or the blower?
a395e602-38d7-412e-a553-23ee69e9350b.png89346502-1e77-4384-8244-ea6d6788bd04.png09d1472e-35ed-4d26-be81-011af0d56f26.png
Jan 15, 2013 | Emerson Lennox Ducane Armstrong Furnace...
How do i order armstrong ac parts?
Here is a tip that wrote about how to buy heating and air conditioning partsonline.
How to find Air Conditioning, Heating and Furnace parts online.
heatman101
Jun 14, 2011 | Heating & Cooling
I have a armstrong gas furnace and I would like a wiring diagram for it it is a model mg73140
http://www.armstrongair.com/armstrong-links/
from here select the particular furnace that you have this is the only resource the is avail. due to the furnace being a Lennox made furnace
Mar 07, 2011 | Heating & Cooling
Armstrong furnace G1D91AU075D12B shuts off before thermostat setpoint ex. if thermostat is set to 70, furnace shuts off at 65 you can then turn stat off and back on and unit will start up again. since...
If your heat anticipator in the thermostat is bad or set at the wrong amperage, it could do just as you describe. If the air filter is dirty or the ducts are restricted, the furnace could shut down on high limit. I would check the air filter and replace if necessary. Make sure all registers are fully open and last, change the thermostat.
Jan 08, 2011 | Heating & Cooling
Ignition problem with furnace
hi igniter could be in the wrong postion or its not heating up all the way down or its got a crack in it
Jan 22, 2010 | Heating & Cooling
Heating & Cooling Logo
44 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
