Question about Acer Computers & Internet
Wont letme get in main menu says this feature reqires removable media such as floppydisk or usb flash drive please insert floppy disk or connect usb flash drive
    President:
  • Acer Master
  • 2,246 Answers
Check your hard drive connetor, is your hard drive connected properly
Posted on Jan 04, 2011
Can;t remember administrator password now locked out of computer can't change it or anything how do I get in there to get rid of old passwords and change it? Help !
Hello Angel,
seems you are locked out of Windows, the best resolution at the moment is to download Hirens disc 15.2 . burn it to a cd/copy to flash. insert it to the pc and restart, hit the F12 key to bring up the boot menu, (systems vary with this). then select the appropriate device, in this case the USB pen drive if you chose to use that option, this will open up hirens selection window. choose Darik's con boot and follow the onscreen prompts to get back into windows. this program can change your password or let you gain access to windows and edit it from there as an administrator.
Jan 24, 2015 | Gateway Computers & Internet
Feature requires removable media floppy disk usb flash drive please insert connect
This sometimes happens when you want to add, modify, or uninstall a software and the process requires the presence of the original media. No media , no modification.
Dec 08, 2013 | Computers & Internet
I FORGET MY PASSWORD ON MY GATEWAY NOTEBOOK COMPUTER
download and install nt offline password remover from here: offline nt password remover there is a tutorial on how to use the program on the website. good luck!
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Dec 05, 2013 | Gateway M305CRV Notebook
It seems like your keyboard and mice need some driver to work with some extra function. The best way is to donwload the specified driver from manufacturer`s website and install it to make all things function properly.
Oct 01, 2013 | Mitsumi Computers & Internet
Bat bios checksum problems solve
Step 1:
Update ASUS BIOS b> Insert bootable floppy disk or USB drive. Copy the updated BIOS file to floppy disk or USB drive.
(Note: BIOS file and boot files should fit on a floppy disk. If the BIOS file is too large to fit with boot files, consider using the EZ Flash method described below.) Insert the motherboard support CD into optical drive. Copy AFUDOS.EXE from CD to a floppy disk or USB drive. Reboot. When the DOS prompt appears, type the following: afudos /i[name of BIOS file]For example, "p4c800b.rom" might be the name of the new BIOS file. "afudos
/ip4c800b.rom" is the command that will install it. Wait. Your monitor will display the update's progress with a series of messages: "Reading file," then "Erasing flash," then "Writing flash." The "writing flash" message will be followed with a percentage counter that tells you how far the write has proceeded. The final message will be
"Verifying flash." DO NOT switch off or reboot at any point in this process or you will ruin your motherboard. After the update is complete, the utility will return to the DOS prompt. Remove your floppy disk and reboot. Enter the BIOS Menu and load "Setup Default." Save and reboot. You're finished. b> Update Using EZ Flash Copy your new BIOS files to a floppy disk or USB drive. Reboot. When the system is at POST, press "Alt" + "F2" to enter EZ-Flash. Alternatively, on late model motherboards you may press "Delete" to enter BIOS setup, then access EZ-Flash from the "Tools" option on the navigation bar. (Select Tools > ASUS EZ Flash 2 > YES) Wait for your system to check current BIOS information. Insert your floppy or USB with the new BIOS file. Select the drive letter with the BIOS update file, then select the file. Wait for your system to check the update file. After the file check is finished, click "Yes" to update your BIOS. Wait. Let the update procedure run until it finishes. Do not switch off or reboot or you will ruin your motherboard. When the update is finished, remove the floppy or USB drive and reboot. Enter the BIOS Menu and load "Setup Default." Reboot. You're finished. b> Update Through the Internet If it isn't installed already, install the ASUS Update utility. You can either download it or use the copy on your motherboard's support CD. Close all Windows applications if any are running. Launch the ASUS Update utility from the Windows desktop by clicking "Start>Programs>ASUS>ASUSUpdate>ASUSUpdate." The "ASUS Update" main window will then appear. Select "Update BIOS" from the "Internet option" drop-down menu. Click "Next." Select the ASUS FTP site nearest you, or choose "Auto Select." Click "Next." From the FTP site, select the BIOS version that you wish to download. Click "Next." Start the update. Wait for it to complete.
http://support.asus.com/technicaldocuments/technicaldocuments.aspx?root=198&SLanguage=en-us
Feb 05, 2013 | ASUS Eee PC 900 Notebook
Im having problem logging in to my computer it a acer 5532 5535 model every time i try reset my password it say this feature reqires removable media such as floppy disk or connect usb flash drive
It's looking for a disc or device you've previously setup security with... in this case you don't have that or you'd know what it was asking for.
You may be in for a reformat/reinstall of software on your machine if you can't remember the password. Acer or Microsoft aren't likely to tell you how to get around the password, for obvious reasons, but you might try it and see if they have another undocumented option you might try.
Good luck!!!
:o)
Jan 04, 2011 | Computers & Internet
What do you mean by insert a disk removable disk
Insert a removable disk, means to place in the appropriate drive one of the the following:
a. floppy diskette
(Usually a 1.4 meg floppy disk) Rapidly becoming obsolete
b. CD disc
c. DVD disc
d. Blu-ray disc
e. Thumb drives
Removable Disk
Also known as removable storage and removable media, a removable disk is a type of media that enables a user to easily move data between computers without having to open their computer.
Hope this helps!
Oct 03, 2009 | Electronics - Others
Resetting Admin password
go to setup>and go to maintanance -->there is a option restore default>select that and after some time do power cycle>and rste me solved if its helps
or
go to your user accouny and change your password
Jan 28, 2008 | Acer TravelMate 2300 Notebook
Computers & Internet Logo
91 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
