Question about Cyberhome Televison & Video
When I try to watch ANY DVD, after loading, the screen says "bad disc"
    President:
  • 173 Answers
Sounds like you need to clean the optical lens on the inside of your player. You can do this the easy way and purchase a dvd cleaning disk or you can remove the cover of the dvd player, there will be a couple of screws on the side and a couple on the back. Once you have done that, open the cd tray and unplug your player from the outlet. Now take some cu-tips and a small amount of rubbing alcohol and lightly dip a cu tip in and look inside your player. You will see a small glass bubble inside the middle of the carriage that will be the optical laser reader. Gently swab off the optical lens a couple of times with each cu tip dipped in a small amount of alcohol. It would a good idea to also purchase a can of compressed air and blow your system out to make sure it is clean of dust and dirt. Make sure you blow the system out before cleaning the optical lens. Let dry for about 2 minutes before plugging back in and replacing the cover. Now try and play your dvds. You might also want to clean each dvd before placing them in your player as an added help. I hope this helps and let me know if you are still having problems because it could be a defective part and I will be able to let you know what it is with a few more questions and the answers you give.
If you do not mind please rate my help, I would really appreciate it. Thanks
Posted on Jul 09, 2008
Every DVD I inserted tried to load and then showed a
"bad disc" error. Left dvd tray open (out), removed the power cord and the cover. I used compressed air to remove all dust and a q-tip with a very small amount of rubbing alcohol to clean the optical lens. Plugged the electric cord back in the wall outlet and played 5+ DVDs in a row without any "bad disc" errors at all.
Posted on Sep 08, 2008
Turn Sound ON, now it's "Q SOUND OFF""
follow this steps and fix it. God bless you
  1. Check if the TV and Amplifier (if connected) is turned on and set correctly.
  2. Check if the TV, DVD player and Amplifier are connected properly.
  3. Make sure the TV, DVD player and Amplifier volume are not set to Mute.
  4. There will be no sound output during Reverse Play / Pause / Step / Slow / Search.
  5. If the DTS soundtrack is enabled in the DVD Disc Menu, but you are using Stereo Analog audio, the sound will not work. Try switching the soundtrack to Dolby 5.1 or PCM mode in the Disc Menu.
Jul 09, 2013 | Televison & Video
When trying to watch DVD the DVD player does not read the disc and shows the "smart navis" screen. the model is; Wharfedale 3210dvx does not see disk
Hello.
Please verify the disc maybe not compatible with your DVD player, or maybe damage on it. please try another disc. besure that the disc has no rashes;.
Mar 31, 2008 | Televison & Video
Tip
How to rip Blu-ray DVD to Nexus S and watch Blu-ray DVD movies on Nexus S The...
How to rip Blu-ray DVD to Nexus S and watch Blu-ray DVD movies on Nexus S <br /><br />The approach for Android has never been one that focused heavily on the media side of things, and that's not really been upgraded for Android 2.3. <br /><br />There are a couple of tiny tweaks, but if you're looking to get a dedicated media phone, this handset (screen aside) isn't going to give you pause compared to something like the iPhone 4. <br /><br />Video on the Google Nexus S looks superb thanks to the WVGA Super AMOLED screen, rocking a full 800 x 480 resolution count. <br /><br />At full power, the brightness is definitely acceptable for viewing in most situations - we pulled it out on the street and managed to watch footage no matter what the conditions (although we wouldn't recommend it). <br /><br /><b>Media specs:</b> <br /><br /><b>Video:</b> <br />HD(720p@30fps) video playing, Video recording D1 (720x480)@30fps, mpeg4, H.264, H.263 <br /><br /><b>Audio:</b> <br />MP3, AAC, AAC+, eAAC+, AMR, AMR-NB <br /><br />We have a lot of Blu-ray DVD disc collections, and we tested to rip Blu-ray DVD to Nexus S for playback. The following is detailed guide: <br /><br /><b>Step 1. Free download and install this <a href="http://wannasoft.com/Pavtube-Blu-Ray-Ripper/">Blu-ray to Nexus S Converter</a></b> <br />Click "BD/DVD ROM or BD/DVD Folder" to load Blu-ray/DVD disc or Blu-ray/DVD folder files. It will decrypt the Blu-ray DVD disc automatically when loading disc. <br /><br /><img src="20101210204139723.jpg" /> <br /><br /><b>Step 2. Set output format for Nexus S</b> <br />Click the drop-download list of "Format" to choose output format,and then follow "HD Video"&gt; "MPEG-4 HD Video (*.mp4)". <br /><br /><img src="20101139443704.jpg" /> <br /><br /><b>Step 3: Adjust video and audio parameters</b> <br />To get 720P quality Mp4 for Nexus S, you are allowed to click "Settings" button to optimized the output file quality by adjusting video and audio parameters. The codec, aspect ratio, bit rate, frame rate, sample rate, and audio channel are all adjustable in the following interface. <br /><br /><img src="20101139443215.jpg" /> <br /><br /><b>Step 4. Start to <a href="http://wannasoft.com/Pavtube-Video-Converter/">convert Blu-ray to Nexus S</a></b> <br />When the above mentioned steps are done, you can click "Convert" button to start converting Blu-ray movies for Nexus S. Once the conversion is completed, you can mount your Nexus S onto your computer via USB, then copy the generated Mp4 file from PC to your Nexus S. <br /><br />In this way, we can enjoy Blu-ray DVD movies on Nexus S with high quality. <br /><br />For Mac uesrs: <a href="http://wannasoft.com/Pavtube-Blu-Ray-Ripper-for-Mac/">Blu-ray to Nexus S Converter for Mac</a>
on Jan 21, 2011 | Samsung SGH-S5230 Cell Phone
Won't complete the load disc process
Loading may mean it is not seeing the disc---A dirty or bad optical pickup is possible if you get this error with every disc.
Jun 06, 2012 | Audiovox D1812PKG 8 in. Portable DVD...
When I put a dvd in it says "loading" for a good
Try cleaning the laser lens. Either opening the unit and cleaning with a cotton bud, or try a lens cleaning disk.
Oct 24, 2011 | Televison & Video
After recording a program on a DVD+R disc, the TV screen says "Disc Finalize Processing...." and nothing else works. I can't stop it, watch it, finalize it, or power off.
The DVD burner in your DVD-VR is defective. Get it replaced at a service center.Is is not able to read the lead in lead out information from your disc. Try playing one of the disc you have written on another DVD player.
Mar 10, 2011 | Samsung DVD-VR375 DVD Recorder/VCR
I load a disk, "loading"
The laser head has been covered by dust and it no longer recognizes the return beam - you will have to clean it : use one of those cleaning disks. If the problem isn't fixed completely then the dust has been baked on the laser lens and the player is dead - unfixable, time for a new one.
Jan 12, 2011 | Cyberhome CH-DVD 300 DVD Player
Screen says loading dvd- movie never begins
Sounds to me like the laser has gone bad. What you are seeing is video that is the start screen. The unit is trying to read the disc to play. You could try to tap the unit on the side to jolt the pickup assembly as maybe its stuck in a spot but don't hit too hard and use a disc that you don't mind if it gets scratched. It probably won't scratch the disc but just in case. The Laser can go out even thou its only a year old they are made very cheaply now.
Hope this helps some.
May 07, 2009 | Televison & Video
Televison & Video Logo
274 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Electro Med Services...
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
