Question about LG enV3 VX9200 Cell Phone
What file system and allocation unit size do i choose for a Kingston micro SD card to format to my LG EnV3? and should i use "quick format", or no?
  • 3 Answers
Anytime I can't get a sdcard to be recognized by a cell phone i use a pc and
for windows:
start->run-> fdisk or diskpart and clean the card ENTIRELY
in linux/UN*X/bsd:
man fdisk, ofdisk or cfdisk
still dosen't work I'll try "Basic" partitioning/ primary partitions of sizes starting from the full size and go down by half each successive attempt. ex 8g, then 4 gb, then 2 - simply because some older phones DON'T see bigger partitions.
Posted on Feb 02, 2011
  • 437 Answers
HI blaznblasian in this case you should use quick format for the kingston micro sd card. the file system is to move information off the phone. Verizon uses scan disc with most of it phones. This is all a personal choice now.
I’m happy to help further over the phone at https://www.6ya.com/expert/ronald_e152e07e272e4f27
Posted on Jan 04, 2011
Cange file system RAW in FAT
SD cards take on a multitude of formats.
For a card that needs to work on operating systems such as Windows 98, ME or XP Home Edition, it must be converted to a File Allocation Table (FAT) format.
Also, some devices, such as a GPS unit or MP3 player, may require a FAT-formatted card.
Insert the SD card into your computer's card reader.
Click Start, then "My Computer."
Right click on the drive representing your SD card and click "Format."
Choose the memory capacity that fits what the SD card's capacity is.
If the exact option isn't available, get as close as possible.
Choose "exFAT" from the "File system" option.
Click "OK" and confirm you want to format the drive.
Hope this helps.
Nov 20, 2012 | Computers & Internet
Tip
MICRO SD CARD WILL NOT FORMAT
If you cannot format an SD card on your PC or external device, retry choosing the exFAT format from the drop down menu (File system box) on windows, then format your SD card using this choice, then format again using fat32 format, this just worked for me and saved my SD card from the bin
1. Double-click My Computer, or Computer (for Vista and Win7)
2. Right-click the drive letter associated with your memory device, then select Format.
3.Select File system format drop down menu to be exfat.
4. Select quick format.
5. Select start.
6. When formatted, repeat steps 3 to 6, but this time select Fat32.
What is exFAT format?
exFat is short for Extended File Allocation Table. exFAT is a file system designed and used by flash drives.
exFAT is not used and was not designed for formatting hard drives. It is only recommended in flash memory storage and other external devices only.
on Nov 02, 2017 | Miscellaneous
Sandisk ultra sdhc card won't record in my canon digital camera. i get a memory card error
All you have to do is
Step One
To save data, use EASEUS Data Recovery software (free version - 1GB of data recovery). how:
1. Download and install EASEUS Data Recovery
2. Insert micro SD
3. Open EASEUS Data Recovery, choose Complete Recovery - Next
4. Select the drive micro SD - Next
5. Save the data to the hard disk (max. 1GB)
6. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4, 5)
After all data is secure, do the process repair micro SD
Step Two
The first alternative - use the software HP Drive Key Boot Utility
Using the HP Drive Key Boot Utility, for Win XP
1. Download and install the software HP Drive Key Boot Utility
2. Then, double click the file cp006049.exe - select Install.
3. Insert micro SD
4. Then, open the program "HP Drive Key Boot Utility" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
5. Remove the micro SD from the USB port, then insert it again.
6. Quick format micro SD (FAT file system)
7. Restore all data, to the micro SD.
Using the HP Drive Key Boot Utility, for Win Vista or Seven
2. Then, double click the file cp006049.exe - select Extract
3. Insert micro SD
4. Then, double click file hpdkbu.exe - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
The second alternative - use software HDD Low Level Format Tool
1. Download and install HDD Low Level Format Tool
2. Insert micro SD
3. Open program HDD Low Level Format Tool, select micro SD - continue
4. Click S.M.A.R.T - click Get Smart Attributes
5. Click LOW LEVEL FORMAT - click Format this device
6. Wait until the process is complete - press OK
7. Remove the micro SD from the USB port, then insert it again.
8. Quick format micro SD (FAT file system)
9. Restore all data, to the micro SD.
I hope this information helps.
Oct 15, 2011 | SanDisk 2GB microSD Memory Card
I have locked my memory card and forgotten the password. Format card also requires password and my laptop cannot read it. Please help.
All you have to do is:
Step One:
2. Choose Complete Recovery - Next
3. Choose the drive micro SD - Next
4. Save the data to the hard disk (max. 1GB)
5. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4)
After all data is secure, do the process of removing the micro SD password
Step Two:
3. If you are using Win XP, double click the file cp006049.exe - select Install.
4. If you are using Win Vista or Seven, double click the file cp006049.exe - select extrack.
5. Then, open the program "HP Drive Key Boot Utility or hpdkbu.exe" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Finish.
6. Remove the micro SD from the USB port, then insert it again.
7. Quick format micro SD (FAT file system)
8. Restore all data, to the micro SD.
2. Select micro SD - Continue
3. Click S.M.A.R.T - click Get Smart Attributes
4. Click LOW LEVEL FORMAT - click Format this device
5. Wait until the process is complete - press OK
I hope this information helps. Thank you for using FixYa!
Oct 11, 2011 | SanDisk 2GB microSD Memory Card
When I enter my memord card in nokia 311 it say the operation is failed and the memory card is not formatted.how to remove virus from my memory card and replace my music and Image.
Step One (save data)
When do the data recovery process, you can find the cause of damage to the micro SD.
Cause of the damage the virus infected (solutions: see method 1)
When saving data, be careful, do not recover the virus file. You must choose the proper file for the recovery.
Cause of the damage bad sectors (solutions: see method 2)
Damage to the partition table (solutions: see method 1)
Micro SD write protect. Characteristics: (solutions: see method 3)
1. Micro SD can be opened, the data can not copy and paste (from the micro SD into a computer, or from computer to the micro SD). When the format, the message "Removable media write protect".
2. Micro SD can not be opened, and when the format of the message "Removable media write protect".
Step two (repair micro SD)
Method
Using the HP Drive Key Boot Utility, the first way
4. If you are using Win Vista or Seven, double click the file cp006049.exe - select extract.
5. Then, open the program "HP Drive Key Boot Utility or hpdkbu.exe" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
Method 2
Method 3
To write protect a micro SD cases, 40% probability of success.
Using the HP Drive Key Boot Utility, a second way
1. Open the program "HP Drive Key Boot Utility or hpdkbu.exe" - Next - select drive - Next - select Backup / Restore - click Restore - From filename, click Browse - Look In. Find the file initrd.img
2. If you are using Win XP, the location of the file in C: \ Program Files \ Compaq \ hpdkbu \ flash \ initrd.img - Next
3. If you are using Win Vista or Seven, the location of the file in the folder where you extract the files cp006049.exe. After the file is found, press Next
4. This process, will take a very long time, so you wait. This way you do for a capacity of 2GB. This involves when, the first way did not work. If the process runs smoothly, the chances of success, but if the process is running very slow, the possibility of failure and immediately stop the process. If you are unsure, or afraid to make mistakes, you should not do it this way.
5. After the process is complete, remove the micro SD card from the USB port, then insert it again.
Oct 02, 2011 | SanDisk 2GB microSD Memory Card
It says there are no NAND files on my mp3 but on wen i look ay my information its on there
Did you attempt to format the player when it is connected to the computer ? If you are not familiar with the format procedure - it shortly goes like this :
1) connect the device to the computer, the same way you do to transfer songs. 2) Make sure you backup all the songs to the computer before proceeding. 2) Go to "My Computer" 3) Right click on the device, then "Format..." 4) In the "File System" selection, make sure you select "FAT". If that's not available, select "FAT32". 5) Make sure that under "Allocation unit size" you choose "Default allocation size". 6) Make sure that Quick Format is NOT ticked. 7) Click "Start" - this may take a few moments, and your player will be cleared of any songs. For the test, try to put a new song that you haven't put before and see if the player detects it.
(If you had problems with the format - it goes like something in the attached video, just pay attention to the options I remarked about)
If that doesn't work, make sure you remove the SD card from the player (if it has any SD card at all).
Good luck and let me know if it worked !
Mar 05, 2011 | Cameras
I have a NS-DV4G Insignia mp3 player which has an error message of "NAND File System Fail, Format File System!!". I had recently downloaded a video which seemed to slow activity until finally all...
utube.png You-Tube video "G8CDvoodIX4" placeholder (do not delete) utube.png
Good luck !
Jan 18, 2011 | Audio Players & Recorders
How do i go about formatting my kingston sd card, step-by-step?
Insert card into card reader. Find which drive letter the card is in. Right click on that drive. You will see an option that says format. A warning will tell you anything on the drive will be errased. Once sure you have the right drive click OK.
Nov 28, 2009 | Kingston 4GB Secure Digital High Capacity...
Sansa mp3 player could not detect micro sd add on card
Anything over 4GB is a Micro SDHC card, not a Micro SD card. It is a completely different type of card format on the inside, and despite the compatible size and shape, it will not work on devices labeled only as Micro SD card compatible. The Sansa e200 and up (e250, e260, ect.) are NOT COMPATIBLE WITH MICRO SDHC CARDS (Micro SD cards that exceed 2GB in capacity).
Dec 16, 2007 | SanDisk Sansa e260 MP3 Player
LG enV3 VX9200 Cell Phone Logo
362 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
