Question about Asko D1706 Built-in Dishwasher
The water stays inside the dishwasher after the wash
  • Asko Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems -
Water will not drain out
heatman101
Posted on Jan 04, 2011
2 Suggested Answers
gary1121
  • 332 Answers
SOURCE: dishwasher not emptying
either the pump is not working or the discharge hose is clogged, if you have an air gap on the sink take the hose off and hold it down see if the water comes out by tself if so the pump is bad if not the drain is colgged take out the bottom tray you will need a 1/4 inch nut driver take the plastic screen cover plate off clear it of debris, there is a sharp metal blade in there so be careful, after cleaning it out turn on to rinse and see if it drains if not you will need to either replace the dishwasher or the pump, dollar for dollar new dishwasher time
Posted on May 30, 2009
Low water level
Try to unstick the float. The float tells the DW how much water is in it at any given time. It is shaped like a mushroom on the bottom of the DW basin. Gently pick it up and set it back down. Does it seem free? Try the cycle again.
Jan 10, 2014 | Samsung DMT400RHS Builtin Dishwasher
Fridgedaire dishwasher will not start a cycle. The green "clean: light stays lighted up and it will not reset the system. I have to turn off the breaker and then turn it back on. then the...
Hello
Ensure the Frigidaire dishwashing machine is fully connected to a power supply. Shut the dishwasher door firmly and select a wash cycle. Press "Start" to begin. Check that the "delay start" option was not selected.
  • 2 Verify that dishwashing detergent is placed in the dispenser and choose a longer washing cycle for heavily soiled items. Do not overload the dishwasher, as this may prevent proper cleaning.
  • 3 Check the household water pressure, which should be between 20 and 120 PSI (pounds per square inch). A water pressure gauge can be obtained at most home repair stores or hardware stores.
  • 4 Turn on the hot water at the sink closest to the dishwasher prior to starting the dishwasher to raise the water temperature inside the dishwasher. Check the hot water temperature, which should be at least 120 degrees Fahrenheit for proper cleaning.
  • 5 Check the spray arms in the dishwasher and move dishes that may be blocking the water spray or preventing the spray arms from rotating properly.
  • Read more: Frigidaire Dishwasher Wash Cycle is Not Working ' eHow.com http://www.ehow.com/how_7877923_frigidaire-wash-cycle-not-working.html#ixzz1Xow3qbbv
    Sep 13, 2011 | Dishwashers
    I have a Bosch SG145M55GB dishwasher which is not letting out teh water. The motor works because dishes are being washed, but water is staying in teh dishwasher. I assume its teh pump, but how do I get to...
    The drain outlet could be blocked. First take the drain hose off under the sink and check the spigot is clear . Then check the sump in the dishwasher for blockages. After that you will have to get inside of the base and remove the drain pump to see if there are any stoppages. Good luck.
    Feb 15, 2011 | Dishwashers
    Water staying in machine after wash completed
    Hello. Generally, the problem is debris in the drain pump or in the drain line which goes from the base of the machine up into the drain under the kitchen sink. Begin by removing the lower panel on the front of the dishwasher and disassembling the drain line there. Be prepared for about 3 cups of water. Then REmove the pump and visually examine it on the inside. If you don't find the debris there check the entire drain tube, and the connection area under the sink. J.
    Jul 28, 2010 | Neff 24 in. S5443X2 Built-in Dishwasher
    Maytag washer, quiet series 200 can't get it to brting water ect
    check your water supply from the tap to the dishwasher
    Jun 28, 2010 | Dishwashers
    Dishwasher not emptying
    May 30, 2009 | Westinghouse 24 in. MDB421 RF Built-in...
    No water is getting to the top row except from above nothing gets underneath
    It sounds to me that there is not enough water moving around in the dishwasher, When the wash is half way through open the door and see how much water is inside. The drain hose may be too low and as the unit washes the water may be syphoning out . If so make sure the drain hose is at least half way up the back before it travels down
    May 21, 2009 | Whirlpool 24 in. DU1100XTPS Built-in...
    Soap Not Mixing
    Inside the soap holder there is a small spring and sometimes that comes under causing it not to open during the wash. If that is fine and you are using liquid soap try pulling a cople glasses of hot water on the latch and give it good clean because it soemtimes gets jammed up. Anymore questions give me a shout.
    Jul 30, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
    Asko D1706 Built-in Dishwasher Logo
    305 people viewed this question
    Top Asko Dishwashers Experts
    John Tripp
    John Tripp
    Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
