Question about Refrigerators
I have a kenmore coldspot 106.73842301. The freezer is not "freezing". Is the control the same as the one in the refrigerator or is there another one directly in the freezer. I have the temperature in the refrigerator up to "5" and it still does not seem cold enough. Please assist. best, tom
  • 117 Answers
SOURCE: I have a Kenmore coldspot side by side- not cooling properly
Setting it to 5 is what the manufacturer recommends. If you set it to 1 and the frig is still not cold, then you probably have a faulty cold control (thermostat)
http://tclaundryrepair.com/home
Posted on Feb 19, 2009
Sea Breeze
  • 4654 Answers
SOURCE: Kenmore Coldspot 106.9552610 not cold enough
Inside the fresh food compartment look for an opening that will allow you to turn the defrost timer clockwise slowly. When you hear it click the refrigerator should go into defrost. If the timer is bad it will need replaced. Let me know. Below is a photo of timer.
Part number 6
Posted on Feb 27, 2009
  • 572 Answers
SOURCE: Kenmore Coldspot model 106 - Snowing in freezer!
its not defrosting. check heater operations. bimetal near heater. check defrost timer
Posted on Feb 08, 2010
cj2176
  • 520 Answers
SOURCE: Kenmore Coldspot Ice Maker Modle #106 56622500 I
these have to be in correctly to lock back in and allow the unit to function. Try removing the bin again and be sure there isn't any small pieces of ice trapped anywhere. Also make sure there aren't any broken pieces from the bin. Hope this helps. Good luck.
Posted on Aug 18, 2010
SOURCE: kenmore coldspot model 106: top freezer leaks
Have you tried adjusting the freezer temperature to a higher level? This worked for my Kenmore. It will take a couple of days to quit leaking.
Posted on Dec 19, 2010
Kenmore coldspot model #106.74203402 is constantly freezing liquid, meats and eggs in the refrigerator. Any ideas as to why this is occurring?
Most likely cold control thermostat but also check damper that controls air flow between fridge and freezer.
Aug 30, 2017 | Kenmore Refrigerators
Kenmore elite coldspot model 106.74219400 freezes in the fridge never gets above 5 or 10 degrees and it never shuts off.
there is a flap in the refrigerator side usually near or behind the light bulb the freezer side is thermostatically controlled with the compressor being controlled. On the refrigerator side the cold air comes from the freezer side. when this flap is open the refrigerator will cool continuously, Check the flap or the duct assembly
here is an illustration of the part
http://www.repairclinic.com/Kenmore-Refrigerator-Model-10674219400-ID-927868-Duct-Venting-Parts
Apr 14, 2013 | Kenmore Refrigerators
Why is the bottom vent in my kenmore coldspot fridge freezing
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 26, 2011 | Kenmore Refrigerators
Refrigerator not cool, freezer ok
Either the freezer continues to freeze up (most likely due to low refrigerant, due to a leak), or there is an obstruction between the freezer and the refrigerator (refrigerators get their cooling from the freezer).
Given that it works after you defrost it, I'm going with low gas. Call a professional to see if the leak can be fixed. If the unit is more than 10 years old, just get a new one.
Aug 22, 2009 | Kenmore Refrigerators
Kenmore coldspot 10656929600 ice dispenser flap
probably will have to take dispensor apart to see what the problem is there, front cover should pry off from bottom
Jul 07, 2009 | Refrigerators
Not cooling or freezing
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
djk
Jun 10, 2009 | Kenmore 52632 / 52634 / 52639 Side by Side...
Kenmore Coldspot Side by Side Model 51559101
I also have the same refrigerator model 106.56566400 and periodically when the power goes off in the house the refrigerator & freezer will stop cooling. Try pushing the on/off button located inside the refrigerator to the left of the digital temperature controls. Hold the button down, this turns the unit off, then press it again to turn it back on. This basically resets the refrigerator, and most of the time works to get the refrigerator cooling again. Try this first before calling a repair man.
Nov 22, 2007 | Kenmore 52632 / 52634 / 52639 Side by Side...
REFRIGERATOR OR FREEZER IS NOT COLD OR WILL NOT FREEZE
Check freezer... for Frost build up and if Fan is blowing, Check condenser... To make sure clean, and the fan is blowing by compressor, Check Recirclating Vents in refrigerator... to make sure theres no blockage, CONTROLS ...should be in the middle setting,
Sep 11, 2007 | Kenmore 22.0 cu. ft. Side-By-Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
