Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
We have a Whirlpool refrigerator model ET1MTKXKQ07. We have recently had a problem with water pooling inside the refrigerator. We know that the drain line must be stopped up, because there isn't anything in the drain pan. Where is the drain line? It isn't in the back of the refrigerator.
    Genius:
  • 1,267 Answers
There is no drain line as the only water that goes into the refrigerator is the water that goes into the ice maker. The out side water only goes into a glass or spilled on the floor.
I suspect that your inlet water solonoid is not reseating properly after the ice maker signals it to close. It opens by an electro magnet and closes by spring pressure. You may have to have it replaced. The ice maker rotats and hits a micro switch that sends power to the solonoid that snaps it open and is held as long as the switch is depressed. when the cam on the rotating vane passes the micro switch lever, the switch goes back to normal taking the power off of the solonoid, and spring pressure snaps it back in the closed position. This cam is timed to just fill up your ice tray.
Posted on Jan 04, 2011
Water leaking from whirlpool gold refrigerator
When refrigerators leak water it usally is a sign that the defrost drain found inside the rear of freezer and behind the rear panel of freezer has become clogged with ice or gunk. Sometimes the pan below refrigerator has a crack and allows water to leak onto floor. Please click here=> Leaking Refrigerators Just What may Be HappeningYou will at times see water build up inside freezer bottom especially on bottom freezer refrigerators. This will take a little reading over to understand what may be happening. Click Here=> Leaking Refrigerators
I will be here should you have questions, Thanks Sea Breeze
Feb 16, 2012 | Whirlpool GX5FHTXVA Bottom Freezer French...
Whirlpool Refridgerator + ET1FTTXKQ02 - Water leakage!
Try defrosting it, if this doen't work then do the following and ur problem will be solved..
BLOW AIR THROUGH THE DRIAN HOSE IN THE BACK OR BOTTOM OF THE FRIDGE FIND THE END OF THE DRAIN HOSE USE AIR COMPRESSOR .....
Goodluck,
Please don't forget to rate me as fixya..
Feb 03, 2008 | Whirlpool ET1FHTXM Top Freezer...
I have a whirlpool refrigerator, model GR9FHMXPQ. I got it about 4 years ago. When it was delivered, it had several pieces of styrofoam lodged in the inside ceiling of the fridge section (below the freezer...
You need to remove all of the styrofoam packing material.
Any insulation material would be installed inside the body of the fridge/freezer. The packing material is there so anything inside the compartment (like metal shelves, plastic holders, etc. don't bounce around during shipping and either scratch up the interior, or break. That is all that it is there for.
Apr 25, 2017 | Whirlpool GR9FHMXPS Stainless Steel Top...
Fridge and freezer are working just fine. But, I keep getting pools of water inside my fridge. These pools stay to the back of the fridge on all levels and they sometimes turn to ice. I notice ice layer...
Your defrost drain is most likely blocked with ice or sludge. Now when your refrigerator goes into defrost it pours into base of freezer or just anywhere it can to pool up. Click Here=> Leaking Refigerators, just what may be happening Click here also=> Leaking Refrigerator's? Please let me know if you still have questions, Thanks, Sea Breeze
Mar 19, 2011 | Whirlpool Refrigerators
Refrigerator leaks water on the inside underneath the freezer
The start device on some models of refridgerator for maytag and whirlpool have been recalled. If your appliance was manufactured in the last 5-10 years you may be having an issue with this component. Mine recently caught on fire at this device that is located near the compressor. If you would like to be a part of the petition for a recall on this appliance contact me at jboooor@hotmail.com
Jun 09, 2010 | Whirlpool ET1FTKXK Top Freezer...
Water is dripping down the back of the refrigerator inside and pool in the bottom of the refrigerator. Whirlpool/ freezer on top ET-1CHMXKQ02. Freezer is still working and icemaker is still making ice.
Defrost drain tube is clogged. Have to clear this by removing back wall inside freezer and removing the ice build up inside the defrost tray and tube. Very very hot water and hairdryer will help with this process. hope this helps.
Jan 28, 2010 | Whirlpool 21.6 cu. ft. Top Freezer...
Small pool of water underneath Whirlpool fridge
There may be a water filter built in. Look for access lower front panel below door. recommend replace every year. They will leak when neglected.
Nov 06, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool drain clog
yes it is most likely the drain that is plugged and or frozen up. to repair this you will need to remove the rear access cover inside the freezer compartment clear all the ice from the drain pan and flush hot water thru the drain hole located in the drain pan. this is a fairly easy repair you can do youself. the hardest part will be removing and reinstalling the rear cover. good luck peyton.
BTW I use a turkey baster or large syringe filled with hot water to flush the drain line with.
Jul 04, 2009 | Whirlpool ED2FHEXMS Side by Side...
Water pools under the veggie crisper
yoor problem is with the drain, when your refrig goes into self defrost the water melted from the defrost needs some where to go. There is a drain for this purpose....it is normally a tube that leads from the rear of freezer to pan by compressor. when this gets blocked the water has nowhere to go except into the freezer vent and down the bottom of the refridge compartment. you will need to clear the blockage in the drain tube...if you are still haveing a problem i can tell you how.
Jun 21, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Own the same model, the icemaker and the dispenser work properly but the leak is top center of the refrigerator compartment.
Nov 08, 2007 | Whirlpool ET1FHTXM Top Freezer...
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
137 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
