Question about Brother MFC-7820N Printer
Scanner will not scan it goes about half way and then stops and i get message that scanner can't be found and code cc031 then cc027
5 Suggested Answers
SOURCE: Scanning error - cannot scan error code 2,155,0 ???
I had the same problem with a new Canon MP970. Printed ok, but couldn't communicate with the scanner - error 2,155,0.
Canon phone support didn't help, and suggested it was a firewall problem. I uninstalled, and re-installed, turning off firewall, virus software, and everything. No luck. Tried several USB cables, no luck.
Then I uninstalled again - as well as a couple of old drivers and software associated with two now deceased printer/scanners.
This time I plugged the (same) USB in and turned on the device, using Windows' own hardware install wizard.
Now it works fine (at least for now... touch wood).
So - the problem might be either conflict with other printer/scanner devices installed, or with Canon's installation software.
Posted on Aug 02, 2008
EcoPcKing
  • 76 Answers
SOURCE: dcp-115c usb cannot be found (CC027)
sure..some printers need to be plugged directly into wall socket for scanner to work..try that first..
Posted on Nov 21, 2008
SOURCE: brother dcp-7020 can't scan and get cc027 error
Ok I know how to fix this issue, this involves going into the registry editor, also only available in windows XP, so be careful!
Click START -> RUN and type in REGEDIT
Go to HKEY_LOCAL_MACHINE -> SOFTWARE -> BROTHER -> CONTROLCENTER -> (version number) -> (model number) -> DEVICEINFO
Look in the right hand window for ENABLEWIA, if the value is set to 0, set it to 1.
Reboot your computer, should be fixed!
Posted on Dec 05, 2008
  • 1479 Answers
SOURCE: HP L7650 Scanner Could Not Be Initialized in Leopard (Not Found)
If you're using Vista, this happens all too regularly with HP printers. I've had a few where I have to uninstall everything then re-install to make things work.
Two weeks later the same thing, same process.
Try downloading latest drivers from HP and see if that helps. HP don't admit there's a problem.
Don't seem to have this problem with Epson printers tho.
Posted on Oct 02, 2009
Scanjet 4600 is stuck halfway through scan
About 2,970 results (0.68 seconds) Search Results
    HP Scanjet Scanners - Scanning Stops at the Preview ...
    h20564.www2.hp.com/hpsc/doc/public/display?...na...
    Hewlett?PackardWhen attempting to scan from the front panel of the device, the Scan Preview window displays normally but does not show the document or picture being ...Missing: 4600
    Scan stalls half way through and never finishes - HP ...
    h30434.www3.hp.com > ... > Scanning / Faxing
    Jan 11, 2011 - 7 posts
    More times than not, the scan stops part way through (example attached) and then (after several minutes) displays the messages below:.Missing: scanjet ‎4600
    issue Scanjet 5590 windows 7 Business 64 bits - stop during
    Jan 19, 2010 - 10 posts
Feb 05, 2016 | Office Equipment & Supplies
Tray lifts to meet the rollers then drops back down. Error message 'No page was found in the feeder'
Clean the 'black dot' in the centre of the paper tray. There is an optical sensor under that. The tray will lift even without paper, but will go back immediately.
If the scanner stops after 3 pages, check disk space in your computer. If you are scanning in TIFF uncompressed, it takes lot of space. For color and Grey try JPG format, for mono TIFF G4 is the ideal option.
S. Mohan, Chennai, India
Mar 02, 2012 | Canon DR-9080C Path-Through Scanner
Brother MFC8460N was working great and now today the scanner won't work. Printer and fax work fine. When I try to scan I get the message "MFC-8460N cannot be found. Please make sure your device is ON and...
Try re-installing the scanner software - if you don't have the disc you can download it. The scanner is a very delicate mechanism so is easily damaged - if the software fix don't work maybe it is kaput
Oct 03, 2017 | Brother MFC-8460N All-In-One Printer
i found this while i had the same error msg... apparently its actully the USB cable where its does not suffice
here is the link : http://www.fixyourownprinter.com/forums/printer/49111
Thanks
Sanjieev
Jan 13, 2009 | Office Equipment & Supplies
Dcp-115c usb cannot be found (CC027)
Nov 21, 2008 | Brother DCP 115C All-In-One InkJet Printer
Brother dcp-7020 can't scan and get cc027 error
Mar 18, 2008 | Brother DCP-7020 All-In-One Laser Printer
Scanner wont scan
I have an Epson Perfection scanner and it has always worked perfectly. Then, out of the blue, it completely stopped working. I cannot recall the error codes, but the solution I found was to uninstall/reinstall. I still don't know what occurred to create the problem, but it has worked flawlessly since the reinstallation.
Good luck.
Dec 22, 2007 | Epson Perfection 3590 Photo Flatbed...
Getting error code Code[ffff:0024]while scanning
while i am trying to scan the images .. i am getting the error code like Code[ffff:0024] while warming up the scanner, besides a sound from the scanner making it power off (light inside the scanner goes off ) so that i could not get scanned anything ... what will be the reason ? please suggest me the trouble shoot kaarthik
Apr 14, 2007 | Acer Scan to Web 3300U Flatbed Scanner
Brother MFC-7820N Printer Logo
752 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
