Question about Cameras
I was working with taran-2005. I paid $20 and got good advice. When I finished gooiing through all his tricks to make my zoom lens come out and my camera stay on I was able to do that. However, after went through his tricks and tried to take a picture I discovered another problem. When I tried gto take a picture the LCD. said no card available. I spent another six bucks to see if I could get an Email answer to that problem. But somebody voided it. So here I am with a camera that does not work. Can I get some help on this. Thanks David
  • 5 more comments
  • caulfield32 Jan 04, 2011
    I unloxcked the card, inserted it, turned on the camera and the LCD read cannot read card. Is there more than one way to insert the card?
    I can't do the set day date time year clock because as soon as the LCD reports "the card is unreadable the camera shuts off. I do not understand the formatting thing. How do you format a card. Isn't that done in the factory?
    I tried a card from another camera that worked. I took a picture with it just to be sure. The LCD screen still read "card is unreadable."
    The card must be formated because it took a picture in my other camera and even when I tried to use the card that was in the working camera, I got the same message then the camera shut off. It is frustrating to have gone through the tricks I got and thought we had solved the problem and the camera would work only to have this to deal with. I feel like I am close to a solution but need one more step to make the camera work. Do you agree?
    My expert seems to have disconnected and gone home. Can someone look at the messages I have sent and give me a response? Thanks
  • caulfield32 Jan 08, 2011
    I downloaded the manual and it said the camera would not take a card higher than two mg. I was trying to use a four mg. When I went back to a two mg. the camera took a picture. It showed up on the LCD. I have not transferred it to my computer yet but I do not foresee any problem. So the problem is solved. But the FixYa team gave me the advice to fix the stuck lens so I am very pleased with the help I received. So thanks I will accept your solution.
    I was working with taran-2005. and he was very patient and very helpful.
  • 3,083 Answers
The camera isn't detecting the memory card, and the internal memory is probably full, so it's giving that message. Do you have a card in it? If not, get one and put it in the memory slot (they will only go one way, so make sure you have it right). If you do have a memory card in, you might have some bent pins inside the camera, not detecting the memory card, or there could be a problem with the card, so try another one.
Look inside the memory slot, and try to see if all the pins look good...and lined up. If everythings ok, make sure the copper fingers on the memory card are clean (use a qtip and alcohol, or a pencil eraser).
Not sure what brand camera or model you have, but some digital cameras are expensive, and worth fixing, but a lot are not spending much money on, since you can get a new one for the cost of repair, often.
If you can't get it working, you can run it by a camera repair shop, and get an estimate, or contact the manufacturer's support site for help.
Good luck, and hope this helps.
Posted on Jan 06, 2011
  • 747 Answers
I hate getting into the middle of something like this but, are you using an SD type card? If so is the lock in the correct position here is a diagram. Also the memory card must be formatted for the camera it is being used in. Something else the day date time years "clock" on some cameras needs to be set before anything works those are only a few things.
here is the diagram for an SD card lock.
Posted on Jan 04, 2011
  • Robert Taylor
    Robert Taylor Jan 04, 2011
    We have a couple of problems, well maybe three. First off taking a card from one camera to another without formatting is just asking for trouble. No formatting isn't just done at the factory it's done each time pictures are downloaded to the computer. Formatting cleans the card and makes it ready to accept new pictures. Formatting a card is done to the memory card for the specific camera it will be used in. Also as said before on some of these camera types the day, date and time function must be set for the camera to work.
    Make sure the card lock is in the correct position go back and look at the slider switch hold it writing up as in the picture so the switch is in the top left corner and slide that switch away from you towards the top edge of the card towards the gold contacts.
    The biggest thing here is you haven't included the make or model of the camera you have and I'm working blind and on assumptions, it's also becoming obvious you don't have the manual for it.
    By constantly deleting the pictures I suspect the old card is just so corrupt and dirty the camera just can't read it to even allow the camera to come on. As much as I dislike formatting camera memory cards in a computer I think this is one time you need to do this and format the card in the computer.
    Okay backing up a little are you taking the card out of the camera and putting it in a card reader that's connected to the computer to download your pictures?
    Or are you using the camera connected to the computer through a cable to download pictures?
    I'm back to work today so our correspondence will be slowed down quite a bit.
    I'm having a feeling I know what has happened or what is happening with this camera and if so there is a long way to go before getting it back up and working.
    I'd like to know what I'm working with tell me what make, model the camera is and if you have a manual or not.
When using the zoom control, why does the lens zoom out but will not zoom back in with the zoom control?
hi,
your camera's zoom is faulty, there is some sensors with which controls the lens retraction, if the lens's position is wrong the sensor cutting edge will not get in the proper position.
open the camera, take out the lens, open it carefully, if the position of the lens is not in proper position, you can see some marks on the lens barrel fix it in the correct position.
Feb 25, 2016 | Nikon COOLPIX Cameras
Tip
Digital Cameras
Since I have been a expert on Fix ya, I have seen many people write about the auto-focus of the digital zoom lens. Here are a few tips and tricks that will help you in the future.
The Right Lens for the Job
There is another reason for using zoom lenses, especially when you are taking pictures of people. Lenses can alter the appearance of your subject, and wide angle lenses can distort people’s faces – especially if you are taking our advice and getting in close. So, by all means, get close, but if you are doing a portrait, use your zoom as well. Longer lenses are more complimentary and should be used even if you are actually physically close to your subject
What Brand is your SLR?
This is important because every mounting brace for all the camera's are different for example, and Nikon will not fight on a Canon, Canon will not fit on a Pentax and so forth. Some may fit, but the auto focus will not work. So make sure you know your brand and model number before just going out and buying a lens for your camera.
Here are six steps to help you buy the best lens for your money and the camera.
  1. Determine the focal length you'll need
  2. Decide if you want a prime or zoom lens
  3. Select a maximum aperture
  4. Choose between first or third party lenses
  5. Evaluate any extra features
  6. Read reviews and narrow your options
on May 05, 2010 | Cameras
How to disassemble a Makinon mc zoom lens
first off, you need special tools to get at the inner elements of a zoom lens - i've been working on lenses for 20 years, and i still don't have every tool needed sometimes :-)
second, makinon lenses are not really worth anything, even if they are in perfect condition - my advice is to buy a better zoom used that is in perfect condition already, since you would have spent that money in tools to try and clean this one, and everyone screws up the first lens they ever try to take apart...
some good lens brand names are sigma, tamron, kiron or any with the same camera name as your camera (canon, nikon, etc)
stick with japan made optics - can't go wrong usually.
good luck...
Nov 30, 2014 | Cameras
I just got an answer fom Taran 2005 regarding my shorted thermistor. it was very helpful. However, he did not answer the last part of my question, which was... will the heater turn off at the preset...
Sorry but to get Taran 2005 to answer your question simply go to your previous question and add a comment. It is very unlikely he will see the new question.
Simply open the solution he provided before and click on add comment that will get to him and he would give you an answer.
But if your solar sensor is faulty the unit will keep running and not turn of at the preset temperature unless the unit has a backup sensor for turning off the unit as most units do have. To be absolutely sure leave the unit on for the same period of time as it would take to turn of usually and see if it automatically turns off. If not then you got your answer.
Hope this support has been helpful?
Thank you for visiting FixYa.
Jul 09, 2011 | Pentair Pool & Spa
Last night I was being helped by taran-2005. I have one more question for him. Is it possible to get connected to him now?
I haven't tried to reverse engineer something like this BUT, if you go into one of your last night posts and solutions you may be able to click of "taran-2005" Avatar icon and be carried to the persons profile or at least send the person a message. Now I'm going to have to try it myself Cheers hope it works for your Happy New Year
Dec 31, 2010 | Cameras
Fujifilm A345 keeps saying zoom error lens wont open and when i press shutter button it makes a short buzzing sound then zoom error comes up help
I recently came into this camera and after a day of testing it, it's doing the same thing. My work around is this. When it's on I press the zoom function and the lens then pops out. Then after it's out, I remove the batteries while it's still on. Put the batteries back in, and power it on (lens will be popped out) and then it starts working. I only paid $7 for it at a good will. So I was taking a chance it worked somewhat. This may work for you temporarily. Not sure how long this one will last.
Oct 11, 2009 | Fuji FinePix A345 Digital Camera
9 volt battery trick
If you don’t find a solution you may want to try fixityourself123@gmail.com. He was able to give me some great advice and he has used parts in good condition and at a good price. It worked for me.
May 22, 2008 | Casio EXILIM ZOOM EX-Z70 Digital Camera
Zoom Lens projects out and camera is shut down.
If you cannot find a solution to your problem you may want to email fixityourself@gmail.com. He has good advice and good used parts at a fair price.
Dec 18, 2007 | Casio EXILIM ZOOM EX-Z850 Digital Camera
I need to know how to remove the zoom lens to clean a water spot inside.
well u can, but u will need to know what are u doing, i repaired many lens when i worked in olympus, but gives lots of work.
Dec 14, 2006 | Olympus Camedia C-5500/C-55 Sports Zoom...
Cameras Logo
26 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
