Question about Samsung WF203ANW Front Load Washer
My washer will stop and nf displays and it beeps. what does this mean?
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
NF means no fill, their is a inbound water issue, water turned off, or clogged hose, etc
remove hoses and check little screens at hose ends..
if thats ok, you may have other issues in the machine.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Jan 04, 2011
I have an error code that says nf
Hello & Welcome to FixYa
NF error in your washer is displayed due to no fill condition, when the washer tries to fill but is unable to nf is displayed. Please check the water inlet valve for any clogs and obstructions, you can also clean the inlet to solve the issue. Please get back to me if you have any other questions.
Kevin
Mar 06, 2011 | Samsung WF337AA Front Load Washer
We start the washer and it runs for about 20 minutes. Then it stops and the letters nf come on the control panel and it wont run. Can you please what that means?
According to the user manual for your washer (which is available here, http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%202206687.pdf), "nF" means the washer is unable to fill with water. Make sure your water supply lines are free of obstructions or kinks, and also that the water valves are turned on all the way.
Jan 29, 2011 | Maytag Neptune MAH6500A Front Load Washer
I am getting an error NF during the washer cycle run. The cycle will not complete and has to be restarted. What does this error message mean?
Hello
NF error in your Maytag is displayed due to no fill condition, when the washer tries to fill but is unable to nf is displayed. Please check the water inlet valve for any clogs and obstructions, you can also clean the inlet to solve the issue. Please get back to me if you have any other questions.
Kevin
Nov 07, 2010 | Maytag Neptune MAH5500B Front Load Washer
It is displaying a nf and stopped working
NF means No Fill. Check inlet valve screens at the mix valve where hoses attach to machine. If there is nohumming noise at fill time, you will need to replace the inlet valve.
May 18, 2010 | Maytag Neptune MAH5500B Front Load Washer
My washer stops during the wash cycle and nf appears on the display screen
NF code is Washer does not turn on water valves to fill washer with water. You may need to replace your water valves, but I would first try removing your hot and cold water hoses to see if the screen on your valves is clogged. If they are corroded beyond repair, just pick up another set at the hardware store. Either that or you will need to do the valve replacement.
Mar 24, 2010 | Maytag Neptune MAH5500B Front Load Washer
What does nf mean?
NF = Not Full
Is displayed when machine does not fill with water in the allowed time. Could be low water pressure at the feed pipe. Could be dirt clogging the inlet hose screen. Could be that the faucet valve is not fully opened.
Let us know of your success!!
Oct 12, 2009 | Samsung WF337AA Front Load Washer
Washer stops with "nf" displayed on screen
nf is no fill
with samsungs most of the time its a bad resistopr on the cold water vale itself,
check your screens though
Oct 03, 2009 | Samsung WF337AA Front Load Washer
Hi... My washing machine... samsung front load. will stop in the middle of the wash and beep and flashes nF. We had bought the floor model and when we got it home realized we didnt have a manual... I can...
nf is the failure code for [no fill].check your water valve screens for a mineral buildup/blockage.they are where the fill hoses attach to your washer.make sure water is present at washer[run the water from each hose into a bucket].i live in ohio its 0 degrees out side now.i did't know it but there was an air leak near my dishwasher drain hose in the house and water froze in it blocking the drain.i hope this info helps you fix this washer, God bless ,tom
Jan 16, 2009 | Samsung WF337AA Front Load Washer
Samsung VRT washing machine
nF means that washer tried to fill but was unsuccessful. Water supply valves needs to be fully open. Lines may be kinked or screen by the hose hookup at the washer end may be restricting flow. Check to ensure the screens are cleaned by removing hose and pull screens and clean them then try the washer again
Nov 24, 2007 | Samsung WF337AA Front Load Washer
Samsung WF203ANW Front Load Washer Logo
221 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
