Question about Microsoft Xbox 360 Console
How do you connect your pc to your xbox 360? - Microsoft Xbox 360 Console
  • 492 Answers
Provided is a link to eHow which will show you step-by-step instructions on connecting your 360 to your PC. I like recommending eHow because it provides simple, easy to follow directions in situations which may seem difficult:
http://www.ehow.com/how_6130939_connect-360-computer.html
Posted on Jan 04, 2011
Not connecting to internet
I am not that much clear whether you can change your Ip adress, but any queries regarding Ip-detais can be solved here, http://www.ip-details.com/
Jun 07, 2010 | Video Game Consoles & Games
My xbox 360 controller will not connect to my xbox but it will connect to my friends xbox
See if any xbox controllers will connect to your 360. If you can't get any to connect to your xbox 360 then that means you have a bad controller board. If you can get other controllers to connect then that means you need to configure your xbox to accept that xbox controller.
Apr 28, 2010 | Microsoft Xbox 360 Controller
Xbox 360 controllers are slow to connect
check where you have the xbox located. try moving it to another place away from other eletronics see if this will speed connectivity.
Apr 23, 2010 | Microsoft Xbox 360 Controller
I have a Cayman 3347w wireless router and I am trying to use one of the wired slots to connect my xbox 360 to the internet. the xbox will not connect. is this router xbox compatable?
Please try the following steps below;
To make a router connection to Xbox LIVE:
  1. Before you connect any cables, turn off your router, modem, PC, and Xbox 360 console. (Unplug your modem from its power source to turn it off.)
  2. Connect one end of an Ethernet cable to the Ethernet port on your modem and the other end to the Ethernet input port on the back of your router.
  3. With another Ethernet cable, connect one end to one of the router's Ethernet output ports. Connect the other end to your PC's Ethernet port.
  4. With the third Ethernet cable, connect one end to another of the router's Ethernet output ports. Connect the other end to the Ethernet port on the back of the Xbox 360 console.
  5. Turn on your modem, then your router, then your PC.
  6. Make sure your PC can access the Internet. If not, you may need to configure the router for Internet access. For help configuring the router using your PC, check the instructions that came with the router.
  7. Turn on your Xbox 360 console and sign in with your profile.
  8. If this is the first time you've turned on your Xbox 360 console, see Create Your Gamer Profile to get started with both the Xbox 360 system and Xbox LIVE play.
If you're unable to connect to Xbox LIVE, you can try to diagnose the problem right on your console. Go to My Xbox and open System Settings, then select Network Settings (setup XBOX using Automatic Configuration DHCP), Test Xbox LIVE Connection.
Hope this helps!
Mar 28, 2010 | Netopia Cayman 3347W-Ent Wireless Router
Cant connect to internet using internet stick
The internet stick you have would be a USB device which is not supported by Xbox 360, you can connect to Xbox 360 wirelessly or through a wired connection
One way of connecting wireless internet is through the ethernet cable to a laptop paired with your wireless router, or you would have to buy a Wi-Fi adapter for Xbox 360 which retails around $90.
Since Xbox 360 does not have a software like a PC, it is unable to recognize the USB internet stick you have as a internet connection, it may probably end up showing it up just as a USB device on the system settings menu on the Xbox 360 dashboard
Jan 22, 2010 | Microsoft Xbox 360 Console
HOW DO I CONNECT MY XBOX 360 TO INTERNET THRU MY DIAL UP MODEM?
Hello Brian
Using Xbox Live on Dial up Modem would be a big pain, still listing the steps for you, hope you have a stable connection to successfully connect
Required Items
- Windows ME, XP, Vista
- PC with dial-up connection working
- Ethernet Cable (RJ45) cable or CROSSOVER CABLE
- Xbox 360
Let's Get Started
1. First connect the Xbox 360 and the PC using the Ethernet cable.
2. Double Click your Dial-up Network connection and wait for it to connect.
3. Choose "Start Menu" and then choose "Settings" then "Control Panel".
4. Select "Network and Internet Connections".
5. Open the "Network Setup Wizard" and then press "Next".
6. On the next screen Ignore the checklist and press "Next" again.
7. Select "This Computer connects directly to the internet." and press "Next".
8. Now Select your dial-up internet connection as your default connection to the Internet and press "Next".
9. Select "Local Area Connection" as your private connection and leave all other areas untouched and click "Next".
10. On the Workgroup screen leave all settings alone and click the "Next" button.
11. On the next screen Turn on "File and Printer Sharing" if you want to share your files, mp3's, divx files with your xbox 360 and click "Next".
12. Now review the settings and click "Next" to apply the changes.
13. You do not need to run the Network Setup Wizard on any other pc's so just click "Next" and continue.
Now that the wizard has completed you may need to reboot your PC and dial your internet connection again.
Xbox 360 Setup
Now we have configured your PC to share its internet connection and files to your Xbox 360 we need to configure the Xbox 360.
(Steps for old Xbox 360 Dashboard, in case you do not have NXE dashboard)
1. Go to the "Xbox 360 Dashboard".
2. Select the "System" Blade.
3. Select the "Network Settings" Option
4. Now choose "Test Xbox LIVE Connection".
Your Xbox 360 will now attempt to contact your home network. It will check to make sure it can assign itself a IP ADDRESS from your PC and then it will also check DNS server information and XBOX LIVE.
let me know if this helps
Nov 25, 2009 | Microsoft Xbox 360 Console
Network Issues - XBox 360
make sure you having network sharing enabled on your computers
Jan 22, 2009 | Microsoft Xbox 360 Console
My xbox live doesnt work
the reason for this part to fail differs along with the difference of the type of connection you are using to connect your Xbox 360 console as follows:
a. Direct connection to modem:
1. Make sure first no other devices connected to the modem at the same time as some modems has an Ethernet port along with a USB port so, you might think you can use both at the same time & connect the PC through USB with the console through Ethernet & that's incorrect so, we need to disconnect the PC first.
2. Turn the modem off then turn it back on after couple of seconds (by turning the modem off I mean to unplug it from the wall outlet even if you have a power button for it), then go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then "Restore to Factory Defaults" and when it ask you to Apply Settings select "Test Xbox Live". 3. If it's still not working we need to get the Physical Address of your PC to put it on the dashboard of your Xbox 360 console as some cable companies are preventing any unknown MAC Addresses from connecting, to get the Physical Address of you PC connect the PC only to the modem then follow these steps here, the physical address will look like this 00-E0-98-C1-88-C2.
4. Go on the dashboard of your Xbox 360 console to “System” area then “Network Settings” then “Edit Settings” then “Additional Settings” tab then select “Advanced settings” & put the Physical Address of your PC without the dashes on the “Alternate MAC Address” part and select "Done", when it asks you to Apply Settings choose “Test Xbox Live”.
b. Wired connection to router:
1. Go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then “Restore To Factory Defaults", when it ask you to apply settings select "Test Xbox Live".
2. Turn the router off then turn it back on after couple of seconds, then go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then "Test Xbox Live Connection".
c. Wireless connection to router:
2. Go on the Dashboard of your Xbox 360 console to the "system" area then "Network Settings" then "Edit Settings" then select your wireless settings part down there "Wireless Mode, Network Name,..." the console will automatically then search for your wireless network and when it find it and you select it, it will ask you to enter your wireless key which is called WEP or WPA key - you can find it written on your wireless router or then you need to contact your ISP (Internet Service Provider) to get it from them - when it ask you to apply settings select "Test Xbox Live".
3. Just a kind of higher security that some router may use than the WEP & WPA key, you have also to accept the Xbox 360 connection to your wireless network on the router settings, you have to access to your router settings as mentioned before to check on the wireless security part whether your router apply a MAC filtering option, which is an option that blocks any unknown MAC address (the ID of any device) from accessing to your wireless network, and if it applies that kind of security you’ll find your Xbox 360 MAC address on the list there so, allow the Xbox 360 to get connected to the network, or even you can just turn off the MAC access control option instead of that, then go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then "Test Xbox Live Connection".
4. If it's still not working, you can put the Xbox 360 console - as a trial - in a closer position to the router to see wither it's going to pick up an IP address or not.
5. If even after you turn off the MAC filtering option on your router settings your Xbox 360 can't still get connected to Xbox Live you need then to update your router firmware (The router software) and if you don't know how to do so then call your ISP (Internet Service Provider) to assist you with that, then go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then "Test Xbox Live Connection".
d. ICS (Internet Connection Sharing):
1. Go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then “Restore to Factory Default" when it asks you to Apply Settings choose “Test Xbox Live”.
2. Allow the ICS option on the PC as mentioned before, then test Xbox Live.
3. If it's still not working, set the IP Settings manually to be:
IP Address: 192.168.0.2
Subnet Mask: 255.255.255.0
Gateway: 192.168.0.1
Then go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then "Test Xbox Live Connection".
4. If it's still not working, you can get the IP address of your connection from the PC as mentioned before then set your IP manually on the Dashboard of your Xbox 360 console using this IP address, when it asks you to Apply Settings choose “Test Xbox Live”.
If you faced any other kind of troubles with this part failing even after you tried these steps please check me man
Jan 03, 2009 | Microsoft LIVE ONECARE 2.0 XP/Vista for PC
Unable to connect xbox 360 to Guitar HeroWT Wireless Drums/Guitar
pmac92,
Did you sync your guitar and drums first? They are just like a normal xbox 360 wireless controller, you need to sync them.
randy320sgi
Dec 31, 2008 | Activision Guitar Hero II for Xbox 360...
Why isnt my xbox connecting? i plugged the cble into the rouder and then put the other cable into the xbox and its not letting me connect.
To make a router connection to Xbox Live:
  7. Turn on your Xbox 360 console with no disc in the disc tray.
  8. If you've already used your Xbox 360 system for offline play, the Xbox Dashboard will open to the Xbox Live area. Select the Xbox Live banner. When you see the Xbox Live Marketplace you'll know you're connected to Xbox Live.
Jul 02, 2008 | Video Game Consoles & Games
Microsoft Xbox 360 Console Logo
151 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
