Question about Amana ACF4265 Electric Kitchen Range
Wheres the bottom heating element on the amana big oven?
aborcass
  • 2651 Answers
SOURCE: Oven not heating up
can you see the bottom element?? if so usually , its obvious when the element goes bad, youll see the damage.TURN OFF POWER. 2 screws remove elemnet from the front 2 wires, plug in aa new one and your good
Posted on Mar 01, 2008
aborcass
  • 2651 Answers
SOURCE: Amana Big Oven Will Not Heat
slow to preheat??? long cooking times??? smell gas while in operation???. all signs of a bad oven ignitor retails for about 60-65. easy enough to replace reomve the lower panle of the oven itself and you'll see the ignitor right there 2 ***** mount that to the bake bar and pull it out, unplug the wire harness, plug in the new one and remount.Start baking
Posted on Mar 10, 2008
SOURCE: JBP66G W1AD Oven won't get hot enough
the yellow may be the oven temp sensor?
Posted on Jul 01, 2008
fridgetech
  • 473 Answers
SOURCE: From where do I access the lower oven element on a Amana ACF4215A
There should be two screws at the rear of the bottom panel inside the oven. Remove those and lift out that panel. The element is under there. If there is not enough wire to pull thru you may have to disconnect and reconnect the wires to the element from the back of the oven by removing the back panel. Hope this helps.
Posted on Nov 18, 2008
aborcass
  • 2651 Answers
SOURCE: amana over
as far as the elementy working, if it glows red, its working. if the unit is preheating within 12-15 min, id say the elements are fine. as far as not maintaining temp, thats strange, if the elemnt turns on the control is sendinding power, and its shuttin off so its stopping power, sounds as if a relay is geting stuck on the control board, strange thngs happen when you short things out like that.
Posted on Nov 26, 2008
The heating element on the bottom of the oven will not heat up.
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
May 21, 2010 | Amana ARDS802 Electric Kitchen Range
My oven still doesnt work after replacing heating element
it could either be a hot spot in the element where it can no longer pass all the current needed for proper operation in heating(look for a discolored spot on it,it may be whitish and dimpled from heat) or secondly,it could be the oven thermocouple located on the inside top of the oven cavity
Feb 22, 2010 | Amana AEW3530DD Electric Single Oven
My amana oven will not heat up. Thought it was
More than likely your going to need a new thermostat or control. Likely when the element burned up it shorted out the control. Check that everything else is working good like the broil element and the top burners. If so there is only two other option the control for baking or the wiring from the control to the element you just replaced.
Jan 23, 2010 | Ovens
Amana range -the oven does not work, but rest of stove is working.
If the oven isn't working it is either the oven thermostat or the element. If the light and fan comes on to show it's heating but no heat appears, check the fan oven element on the back wall behind the panel. Usually 4 screws.
Dec 11, 2009 | Amana AER5725QA Electric Kitchen Range
Amana aco 1840 over stove micro wave. heating not working .
FIK IT THE HEATING ELEMENT IS STRIGHT FORWORD AND COST IS CHEAP, GO FOR IT .
Oct 24, 2009 | Amana ACM1580 Convection Microwave Oven
Oven will not heat until you turn the heat up to 400 degrees
Your "Bake" element may not be working properly. It's the one in the bottom of the oven. Place a couple drops of vegetable oil on the bottom pan, and turn the oven on. During pre-heat, you should start to see those oil drops generate some smoke, IF the lower element is working properly. If it isn't - voila'.!! Problem is with the lower element / associated circuit.
Oct 02, 2009 | Amana AOCS3040SS Electric Single Oven
The oven and broiler won't heat
It sounds like an incomplete circuit so be careful.
Now all this is coming form my assumption that your using a setting that has both elements on at 1 time. like Baking.
First the most common thing:A COMMON TIE POINT;
A main wire burned off will cause both elements to not heat at the same time. It could be at the back going to one element then jump off and go to the second element. Or some times the manufacturer runs the wiring to the front on the controls, and a 3rd area that they could have a common tie point is right where the power comes into the oven. When this usually happens you'll have ok burners on top and no power completed to the bottom.
OR
It could be a switch that's bad and not allowing power to carry on to your oven controls at the thermostat.
If you need more help please get back to me and I'll post back. If this helped you figure it out or decide you need a tech please rate me as high as you can and thank you for using Fix Ya.
Apr 07, 2009 | Amana ARDS802SS Electric Kitchen Range
Amana wall oven will not heat with new ERC
the heating element needs replacement.that the only solution.its common in this ovens as the heating element breaks down in between so it never heats up.
Mar 03, 2009 | Amana AOES3030 Electric Single Oven
Nov 18, 2008 | Amana ACF4215 Electric Kitchen Range
Bake oven element blew
Could be the oven selector switch or the thermostat that failed form thhe element shorting out. You will have to have a ohm meter to check these
Dec 15, 2007 | Jenn-Air SVE47100 Slide-In Electric...
Open Questions:
See all Amana ACF4265 Electric Kitchen Range Questions
Amana ACF4265 Electric Kitchen Range Logo
49 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Mike Carew
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
