Question about Polaris New Genuine Polaris Snowmobile Accessories / X Treme Sidecut / Out of Bound
Took my 1995 polaris 440 out, after 25 miles when taking off from a stop it had no power. replaced the plugs no change. then just start to drive it, it cleared out and ran good for awile again. a few stops later thating off from a stop sign, same thing. checked it over, started to drive with it and it cleared up and had good power. this problem only happened when taking off from a stop, but not every time.
  • 46 Answers
COULD BE A CLUTCH ISSUE, WORN BELT OR FUEL ISSUE. CHECK YOUR BELT AND CLUTCHES FOR SIGNS OF WEAR, THAN CLEAN AND SYNC YOUR CARBS.
Posted on Jan 07, 2011
You asked: My car was running find, a little rough. Took it to a friend to have the spark plug changed and wires. Degreaser was sprayed on motor then rinsed with water when done driving home about 1 mile,...
Try cleaning the throttle valve and idle speed control motor with throttle valve cleaner and then diconnect the battery for 5 minutes and drive it for a few days.
Apr 21, 2013 | Ford Escort Cars & Trucks
What cause the car die after i change the spark plug
-Not the spark plug that you just replaced.
-It could be bad crank, Cam., broken timing belt, bad ignition module or blown fuses.
-Check it out.
Good luck
Mai
Sep 17, 2017 | 1995 Nissan Maxima
My Polaris Sportsman 90 ATV has 70lbs of compression on the engine is that enough ? It does not start .
70lbs for a 90cc should be good, but 80-85 is better. Compression drops from piston rings wearing out, most of the time. Piston rings wear out from old oil...every time. Rule of Thumb: 5 tanks of gas, change your oil !!! It's not a car !!! A car has 5 quarts of oil which takes about 3 months to break down (2,000 miles or so), 90 cc engine has a half a quart, which takes about 3 weeks to break down (based on everyday use) SO...5 tanks of gas, change your oil..
as for the not starting thing, check for spark (should be a blue spark ONLY, any other, replace plug, orange won't ignite gas) if you haven't been riding for a while, open the drain screw on the bottom the carburetor and drain the water out. Ethanol turns to water when the gas sits too long...
Apr 09, 2010 | Polaris ATV
Timing chain replacement how many miles should it be changed
chains are changed - usually.
If it was belt - 50k miles (but I took mine to 100k even though the manual said 60k but I don't drive hard)
Feb 24, 2010 | 1995 Buick Riviera
1995 mustang 3.8 v6 sputters on take off and at a stop in drive but not in nutural no sputer and when it gets going it runs great
ford had 3.8 engines one with distributor cap .and one with distributorless.so if you got distributor engine change distributor cap and rotor spark plugs and wires.also coil.if you got distributorless change plugs and wires .replace coil packs if they have alot of miles on them.replace fuel and air filter.also run good gas.like exxon -shell -marathon - texoco- good gas make car run better.
Jun 22, 2009 | 1994 Ford Mustang
I have a 1995 maxima with hickup or hesitation
Try replacing spark plug wires. Probably one grounding out sometimes.
May 26, 2009 | 1995 Nissan Maxima
Check engine light on 95 lexus es 300
i have a es300 95 check engine light on sometimes it blinks car putts in park,in drive,when ac on the putts worst
Feb 03, 2009 | 1995 Lexus ES 300
1995 Ford Ranger Splash 4x4 4.0L V6
John, I will save you some money, I just took my 94 ranger with the same problem to the dealer and they fixed it. They replaced the ignition sensor and the fuel pump sensor and a O2 sensor. The ignition and fuel pump sensor is in a fuse box right behind the battery. They are a 1 in. black pull out cubes. Ask a parts store which ones they are. Numbers are stamped on the cube. John in Oregon
Oct 31, 2008 | 1995 Ford Ranger Supercab
Polaris New Genuine Polaris Snowmobile Accessories / X Treme Sidecut / Out of Bound Logo
175 people viewed this question
Top Polaris Winter Sports Experts
Larry Fostano
Larry Fostano
Bill Boyd
Are you a Polaris Winter Sport Expert? Answer questions, earn points and help others
