Question about Bush Audio Players & Recorders
I bought a bush surround sound system and got the dvd player with it to and i have plugged the six coloured cables and all the speakers to the back of the subwoofer yet the surround speakers and the center speaker dont work when i play a dvd or a cd i used the test tones and all the speakers make a buzzing noise but i dont understand why they wont work when i want to watch a film, can you help please?
3 Suggested Answers
  • 5 Answers
SOURCE: loud humming buzzing sound coming from subwoofer
make sure you have the speaker connection right if you do then it is a ground problem try plugging it in a different outlet
Posted on Dec 16, 2008
SOURCE: HELPP!! How to connect ''bush dvdav11k'',to TV without DVD Player
HI,
I TOO HAVE BOUGHT THE AV11K. I TOTALLY HATE IT. ITS LIKE ITS BEEN CO-DESIGNED BY THE EUROPEAN SPACE AGENCY AND THE PLAYER AND WOOFER/AMP DONT FIT TOGETHER.
ID LIKE TO SAY THIS THING IS SO POORLY DESIGNED IT REALLY WOULD BE WORTH SENDING IT BACK FOR A REFUND.
ON THE BACK OF THE PLAYER, AND THE WOOFER YOU'LL FIND LETTERS. IE LF,LB,,,,RF, RB. (LEFT FRONT , LEFT BACK ECT). USING THE 'TULIP CABLES SUPPLIED YOU NEED TO CONNECT THE WOOFER AND THE PLAYER TOGETHER MAKING SURE THE LETTERS CORRESPOND.
DO THIS FOR ALL THE CONECTIONS ON BOTH THE PLAYER AND THE WOOFER. THERE SHOULD BE NON LEFT OVER.
THE LETTERS CORROSPOND THE THE POSSITION OF THE SPEAKER IN THE ROOM. SO ( I ADVISE YOU GET A REAL OF EXRTA SPEAKER CABLE FROM EBAY FOR A COUPLE OF POUNDS ) AND PLACE THE SPEAKERS IN ALL THE FOUR CORNERS OF THE ROOM THEN FILL IN THE NEEDED CABLE TO MAKE IT REACH THE WOOFER, WHICH MOST LIKELY YOU WILL HAVE BESIDE OR BEHIND THE TV AS ITS MOST CONVENIENT THERE ( WOOFERS ARE BASS MAKING SPEAKERS AND DONT REALLY CARE WHERE THEY ARE PLACED IN A ROOM.)
YOU SHOULD BE READY TO GO NOW.
THAT IS IS YOU CAN GET ANY SOUND TO COME OUT THE SURROUND SOUND SYSTEM ( LIKE I COULDNT).
THE SMALLER REMOTE IS FOR THE SOUND. THIS CAN BALANCE LEFT AND RIGHT AND VOLUME. AS WELL AS SELECT A AUX INPUT SUCH AS AN IPOD ECT. ( FOR THIS YOU WILL NEED A SIMPLE 3.5 > STEREO PHONO PLUGS. SIMILAR TO THE ONES USED BY THE AV11K.)
WHY IN HELLS NAME THIS SYSTEM IS ON THE MARKET I DONT KNOW. GOD PLEASE RE-ANIMATE MY LAST, AND TRUSTY PHILIPS DVD PLAYER..
HOPE THIS HELPS ALL UNFORTUNATE AV11K BUYS.
YOURS SINCERELY,
ALEX
Posted on Jun 05, 2010
I can hear the music when playing dvd's on my Spectoniq dvd player, but can't hear when people talk. Can anyone help me?
Yes, I can help you. Your DVD player should have output connectors in the back of it to plug your amplifier or receiver into. If you have a Stereo system (no surround sound speakers, or front center speaker) connect the DVD Audio Cables on the back of the DVD player to the STEREO Output Jacks. If it is connected to the Left Front and Right Front jacks of the "Surround Sound" output jacks instead of Stereo is that the dialog on is sent to the CENTER channel output. If you have no center channel speaker you will not hear it.
If you have a surround sound system with two speakers in front and two speaker in back. Then you need to make a change in the Receiver Setup (Which may be set up for 3 speakers in front) so that it is set up for 2 speakers in front.
The last thing my simply be that you have a center channel front speaker that is not completely connected because of a wire falling off, etc.
Hope this helps,
Best,
Mark
Jan 13, 2011 | Spectroniq PD-3000HD
Tip
How to set up a seven-speaker home theater system
Set up a home theater
How to connect your speakers
In order to deliver surround sound, home theater systems require 5, 6, or even 7 speakers--and that's not even counting the subwoofer. Connecting all those speakers together can be quite a challenge, so here's a quick overview of the basics.
If you don't have an all-in-one, home-theater-in-a-box system, you'll probably need to supply your own speaker cables. There are several different types available--they vary in terms of wire size (or gauges) and termination types. Make sure you pick cable that's a good match for your speakers and receiver. And make sure they're long enough; the rear-channel cables in particular will be stretching all the way around the room.
Once you've selected your system and have all your speakers ready to set up, begin by placing each speaker at or near its intended location. Then, attach the cables to them one by one. After securely fastening one end of the cable to the speaker, connect the other end to the appropriate speaker output on the back of the A/V receiver. Be sure to connect the cable to the correctly labeled output.
For instance, the front-right speaker wire needs to go to the terminal labeled front-right. Also, make sure that each speaker connection is in phase, meaning negative to negative and positive to positive. Otherwise, your system's sound will sound out of whack. Repeat the process for every speaker in your system. Note that the subwoofer uses a coaxial-style RCA cable instead of standard speaker wire.
Once all the wires are connected, you should test the system with several DVDs and CDs, to ensure that everything is in working order.
For our first example, we used an elaborate 7.1-channel system, so it may have 1, 2, or several more speakers than your system. Some systems even employ wireless rear speakers, or virtual surround-surround modes that simulate multichannel experience from 3, 2, or even 1 speaker. And some listeners still prefer good old stereo sound from 2 speakers. No matter what type of speaker setup you prefer, however, the wiring basics remain the same.
How to position surround-sound speakers and a subwoofer
To get the best performance from a surround-sound speaker system, you must install each speaker in the correct location. There are three basic types of surround-sound speaker systems.
  • The 5.1-channel system has five satellite speakers and a subwoofer.
  • 6.1-channel systems have six satellites and a subwoofer.
  • And 7.1-channel systems have seven satellites and a subwoofer.
Start by placing the center speaker either directly above or directly below your TV. The center speaker can be perched atop a direct-view TV or mounted on the wall. Aim the center speaker at ear level.
In most cases, the front-left and front-right speakers can be wall mounted or placed on stands. However, if your speakers have rear-panel bass ports, they should not be wall mounted. Space your front-left and front-right speakers the same distance apart as the distance between your center speaker and your listening position. Position the front-left and front-right speakers no more than two feet above or below the front-center speaker. The tweeters in the front-left and front-right speakers should be roughly at ear level relative to your seating position.
Ideally, the surround-left and surround-right speakers should be mounted on the side walls of your room, slightly behind or parallel to your listening position. If your speakers have rear-panel bass ports, place them on stands instead. If installing the speakers on the side walls isn't practical, you can mount them on the room's rear wall or place them on stands behind your listening position. The surround speakers can be installed up to two feet above the front speakers.
Also, 6.1 surround systems have a back-center speaker. You'll typically mount this on the rear wall of your room, centered behind your seating position. Position the back-center speaker no more than six feet behind the surround-left and surround-right speakers. If your speaker has a rear-panel bass port or if the rear wall is too far behind your seating position, place the back center speaker on a stand instead. The back-center speaker should be installed at the same height as the surround-left and surround-right speakers.
Instead of a single back speaker, 7.1 surround systems use a back-left and a back-right speaker. These, too, are typically mounted on the rear wall of your room. Position the back-left and back-right speakers so that each is approximately aligned with the left and right edges of your listening position. Place the back-left and back-right speakers no more than six feet behind the surround-left and surround-right speakers. If your speakers have rear-panel bass ports,or if the rear wall is too far behind your seating position, place the speakers on stands instead. Install the back-left and back-right speakers at the same height as the surround-left and surround-right speakers.
A subwoofer is the last component of a 5, 6, or 7.1 system. Because bass frequencies are nondirectional, you can place the subwoofer in various locations. You may get the best performance by installing the subwoofer in the front of the room, approximately six inches from the wall. If you want more bass, try placing the sub near a corner in the front of the room.
Connect your DVD player to your A/V receiver--digitally
To hear a movie's soundtrack in surround sound, you must first connect your DVD player to an A/V surround-sound receiver. You'll need to make what is called a multi-channel-compatible connection.
The easiest way to do this is to use a cable that carries a digital signal. There are two digital options: optical and coaxial.
An optical digital connection, also called TosLink, uses pulses of light to deliver a digital signal. According to some experts, one advantage of optical digital connections is that optical cables don't pick up noise, while lower-quality coaxial cables can. Many, but not all, DVD players have an optical output. Most A/V receivers have at least one and usually multiple optical inputs. Plug one end of the optical cable into the DVDs player's optical-out jack. Plug the other end into the receiver's optical input.
Finally, you need to tell your receiver to use the optical connection whenever you switch to the DVD input. This is called assigning the input. Information about this simple process can be found in your A/V receiver's manual.
A second option is a coaxial digital connection. This type of connection is also used for cable TV, but the connectors are different. This type of coaxial cable has an RCA connector. Coaxial cables are less expensive than optical ones. In fact, you can use any old RCA cable to make a coaxial digital connection, and you won't lose any audio quality.
Most, but not all, DVD players, have a coaxial output. Some have coaxial and optical outputs, so you get a choice. Audiophiles argue over which connection is better, but it's very hard to hear the difference. Most A/V receivers have at least one and usually multiple coaxial inputs. Plug one end of the coaxial cable into the DVD player's coaxial-out jack. Plug the other end into the receiver's coaxial input.
Finally, tell your receiver to use the coaxial connection whenever you switch to the DVD input. Again, your A/V receiver's manual will have instructions for assigning an input.
on Aug 13, 2010 | Audio Players & Recorders
HI,
YOURS SINCERELY,
ALEX
Jun 04, 2010 | Audio Players & Recorders
I just bought a Blue Ray player but my surround sound has a dvd player built in and only one input which I have my new Sharp TV plugged into. How can I hook up my Blue Ray . I have the HDMI cables
Depending on if your surround system has a hdmi input or not. if it does you can connect the blu-ray player to it. If it doesn't have an hdmi input you will have to run the hdmi cable from the blu-ray to the tv then run a set of rca cables (red and white plugs) from the tv audio out to the surround systems' audio input jacks to get sound through the surround system. Most surround systems don't have an auxiliary input for another video device.
Nov 21, 2009 | Onkyo TX-SR606 Receiver
I bought a paramax p-510 I want to setup connect it to my tv, what cable do I need
i have no idea to connect it either. Specially since the AV has only 2 jacks instead of three. I connected the two jack with DVD, and the front 2 speakers work and the sub too, however i have no idea how to make the surround and center speakers work. I have tried various variations, but i think the thing is a fake made for only 20 bucks speakers without much juice.
I might be wrong but this is the first av with only two jacks instead of three, even the cable they provide has three jacks
Sep 22, 2009 | Audio Players & Recorders
I have a JVC DVD player that doesnt come with surround sound but i have surround sound speakers is there something I can buy so that I am able to use the speakers
If you have surround speakers with a surround system, then connect the Player to the surround system using for example RCA cables (White and Red).
If you have speakers only, connecting many speakers to a non-surround system won't give you surround.
In surround systems the sound is controlled, elaborated and distributed through the speakers by a circuit.
If you wnt surround sound the alternatives are :
  1. Connecting a surround system (eg.Home theater, receiver) to the player (amp+speakers)
  2. Upgrading the DVD to one with surround.
Let me know if you need more help.
bye.
G.
Jul 17, 2009 | JVC KD-DV7300 Car DVD Player
Need help hooking up my duraband surround system to my tv and dvd,tv has 1 set of holes in front and dvd player has in and out
plug the dvd audio into the amp and video to the tv if you have an output on your tv plug it in too.the amp. plug cable in back of tv
Jun 24, 2009 | Durabrand 5.1 Surround Sound Computer...
No sound from rear speakers of Bose V20
Are you useing a digital coaxil cable? or optical cable?(you will need one of these connections to get 5.1 surround!) the white /red rca jacks will not do the 5.1 surround! (back speakers)
Please rate response!
Jan 07, 2009 | Bose Lifestyle 12 System
Help getting sound from New Sony LCD Television Model XV HTD520 DVD Player with Surround Sound S HTD520
While I could not find it in the manual, I found that you must
go to the menu, open Sound Options and set Speakers to "Fixed".
Note: If you turn off the Surround Sound or DVD player combination you must then go back to the menu and turn the speakers back to Televsion.
Jul 21, 2008 | Audio Players & Recorders
90 people viewed this question
Top Bush Audio Players & Recorders Experts
 Grubhead
Grubhead
STEVEN MAYAMBALA
Level 1 Expert
Are you a Bush Audio Player and Recorder Expert? Answer questions, earn points and help others
