Question about Toshiba TN50X81 50" Rear Projection Television
I am trying to hook up an antenna instead of using cable. Cannot get the tv to work
  • 53 Answers
Make sure the source of input has been switched to "Antenna" within the input options within the onscreen menu
Posted on Jan 04, 2011
How do I set up my TV to work with an antenna instead of cable?
on your remote go to input select antenna ,making sure that the antenna cable is plugged into the back of the tv , and you may have to
tune the TV in using the menu tv set up option
Oct 05, 2014 | Emerson LD195EM8 19 in. LCD TV
Antenna hook up
The antenna hooks up at the antenna in coaxel hook up in the back. Same place your cable would hook up to. If you use this for your cable box instead of hdmi then you'll need a cable splitter to attach both.
Feb 05, 2014 | Samsung LN46C650 TV
Can I use an antenna on my sharp tv catv? If so, what kind works for this tv
Hook up your rabbit ears and auto tune the TV and see what happens.
Jul 24, 2012 | Sharp Televison & Video
Advent tv indoor antenna hook up
If the antenna has a cable like cable wire--hook it direct to the cable fitting on the set.
If the antenna uses the flat type wire (called 300 ohm twin wire) use an adapter that will connect to the end and have screws for the flat wires and a cable slide on the other side to slide onto the cable fitting on the rear of the TV
Mar 28, 2012 | Recoton Advent Advent DV1418A 14 in....
When I hook my tv up to cable I get no signal, if I just hook it up with antenna it works fine. How do I get my tv to work with my cable cord? Would be nice to view cable channels instead of just 3...
nialbert,
It sounds like you are hooking the cable to the wrong input (digital instead of analog) or you do not have an analog input. If you do not have an analog input you could run the cable through a VCR to convert the signal to a separate audio/video signal and send it to the TV via an auxillary input. Without the model number I can't give you much more help.
Thanks for using FixYa and for the great rating.
hardrocko
May 09, 2011 | Televison & Video
I have an LG47LG70 tv which has recently started flashing the screen on and off when hooked up to the local antenna. It works fine when hooked up to the Dish Network cable. I have replaced the antenna...
Tries hook up to a roof antenna or a better antenna like a digital antenna.Than rescan ur tv again,for those DTV free air channels again.Ur tv now,should get all those DTV free air channels.
Nov 05, 2010 | LG 47LG70 42 in. LCD TV
How to un-Dish a t.v.
In the USA broadcasts are not analog any longer they are digital. So if you have an antenna hooked up to your TV you will need a digital converter hooked up to your input wire (from antenna) and then an output from the converter to the TV. Most satellite and cable companies use RG56 cable which will work fine with an antenna set up as well, so cabling should not be a problem.
Make sure you set your TV mode (input or source) to the proper input where you have hooked up the cable to the TV as well. It is unimportant which input you use, but the TV has to have it set to the same one.
If you are outside of the USA, the above should be the same because broadcast over the air and antennas set ups are universally the same in nature and design. I hope this helps and good luck!
Feb 02, 2010 | Televison & Video
Says unusable signal when trying to hookup my Nintendo 64.
Here are a couple of things to try. Go into the menu and make sure that you have the "ANTENNA" selected instead of "CABLE". Also make sure that the channel that you are using (3 or 4) is programmed into the memory of the tv. If not, use "auto program" in the menu to program the channels.
These newer tv's are not the same as older tv's. If none of that works, put a antenna amp on the output of the nintendo and then plug it into the tv. This should fix it.
Nov 17, 2008 | Televison & Video
Connecting VCR/DVD combo to TV
If that is the only input that the tv has it's still usable. Just plug the Cable TV or antenna cable into the DVD/VCR coaxial input labeled "in" (instead of the TV's) and hook one from the DVD/VCR's "out" to the "in" on the tv. Turn the TV to channel 3 or 4 (depends on DVD/VCR settings) and use the built in TV tuner on the DVD/VCR to change channels.
Sep 20, 2007 | Televison & Video
Toshiba TN50X81 50" Rear Projection Television Logo
57 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
