Question about NetGear RangeMax WPN824 Wireless Router (WPN824NAR)
If I unplug the internet wire from the netgear and plug into the modem the internet works the minute I plug back into the netgear the internet does not work any suggestions
    Problem Solver:
  • 10 Answers
Most likely your router is not configured correctly. you did not indicate which ISP you have but since you can get on line when connected directly to the modem I would assume that one of two things is happening:
your ISP provided a static IP which is in your computer and the the modem is configured as a bridge.
- this option is very unlikely as most IPs are assigned dynamically.
option two your modem is configured as a router and is getting its information assigned dynamically from the ISP. In this case you will need to log into the web interface of your router (typically 192.168.0.1 if not try 192.168.1.1) with login of admin and password for the password.
make sure the WAN interface (Internet interface) is configured for automatic configuration (DHCP)
save the settings in the router.
reconnect the modem to the router and power off the modem first and then the router.
power cycling the modem and router will clear out the arp cache in the modem.
after they power back up you should be able to go back in to the router and verify that the router has obtained an IP from the modem.
Posted on Jan 04, 2011
I cant get internet from my rouder
Wired or wireless? Shut down the computer. Unplug the NetGear. Unplug the ISP modem, remove battery, if applicable, Check ALL cables and connections, reseat ALL connections. plug in the ISP modem, wait for selftest. Plug in the NetGear, wait for selftest. Reboot the computer. Try connecting with a Ethernet cable if you are trying to connect wirelessly to verify. If that fails, contact your ISP to verify signal comming in. Have a ISP tech come out to analyze the signal.
Jan 06, 2013 | NetGear Computers & Internet
When i installed modem i an able to connected through wired connection via router however i could not able to connect through wireless link
Most likely you will need to disconnect the power cord from your modem for 15 to 20 minutes in order to clear the MAC address of the computer that was previously connected to it.
After the modem has been unplugged from power for 15 to 20 minutes, plug it back in and it should then recognize the router as its new MAC address to assign an IP address.
This will restore your access to the Internet.
Jan 02, 2011 | NetGear WGR614 Wireless Router
Netgear router is not connecting to internet but i can connect if i plug Ethernet directly into computer from modem
Unplug the modem and router for at least two minutes and till all the lights go off . Then plug the modem back in. Then plug the router back in and it should work. Hope this helps :)
Dec 27, 2010 | NetGear WGR614 Wireless Router
I have At&T internet a motorola modem from them and a neatgear router rangemax WNR834B. AT&T helped me setup the wireless network. I think my router is bad since the power light does not light....
No solid power light = NO internet. Check and make sure router is plugged in. Try unplugging router for half a minute and plug it in again check and make sure the outlet works where you are plugging the router in and if still no power light you can contact Netgear support at 888-638-4327.
Apr 18, 2010 | NetGear RangeMax NEXT WNR834B Wireless...
My router is not connecting to my cable internet modem
Power off your PC, then completely unplug the power for your cable modem, and then unplug the power for your router. Wait about 1 minute, then plug the power for your cable modem back in, wait for it to be completely connected, and then plug the power for your router. Also make sure you have your router connected to the cable modem correctly too.
Feb 05, 2010 | NetGear WGR614 Wireless Router
How to connect Netgear to Time Warner internet modem? I have Netgear installed on my computer, and I have the internet modem plugged in to my computer.
Just disconnect the ethernet cable from the computer and put it into the slot called internet on the router then run ehernet cable from port 1 to computer.
Dec 05, 2009 | NetGear WGR614 Router
Motorola Surfboard 4220 not working with my Netgear WGT624 router
Make sure that you have the ethernet cord from your modem plugged into the WAN/Internet port on your router. Then unplug the power cord from your cable modem and plug it right back in. After the modem fully comes back online, unplug the power cord on the wireless router and plug it back in. wait 30 - 60 sec and then try and connect.
Most cable companies only allow one active"CPE" at a time for internet access. All this means is when you change what is connected to the cable modem you must always reboot the cable modem to allow access.
Hope this helps. Let me know if it does not work.
Please rate.
Mar 23, 2009 | Arris SURFboard SB4220 Modem
Antenner sign on my netgear not flashing carnt get my laptop or my other p.c to conect to internet?
Be sure the cable from the modem is plugged into the "WAN" port on your router.
Unplug the router, wait a minute, then plug it back in. If that doesn't resolve it, contact Netgear support for a possible replacement.
http://kbserver.netgear.com/kb_web_files/n100005.asp
Jul 18, 2008 | Computers & Internet
Lost intall disk
Well, i have set up several routers and they actually run better without the setup disk. as long as you know how to set it up, you it will work fine. (Setup disks tend to be over controlling of your network.)
To setup:
-Unplug your modem of all plugs.
-plug in your cable wire to the back of the modem.
-Plug in the ethernet wire from the modem to your router.
-Turn on the power(plug in) to your modem and give 2 mins.
Plug in ethernet cord from router to your computer.
-Plug in power to your router and give 30 seconds.
-power on your computer and give 1 min after start up.
-Make sure your internet is working and you are good 2 go.
Mar 23, 2008 | NetGear WGR614 Router
NetGear RangeMax  WPN824 Wireless Router (WPN824NAR) Logo
345 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
