Question about Insignia NS-R2000
My Insignia NS-R2000 Stereo Receiver will no longer come out of standby mode. It has been working fine for nearly two years and now, upon turning it on, it simply waits a few seconds and then goes back to standby mode. I tried unplugging and replugging it back in, checking all my wiring and well as simply unplugging all my speakers to see if there was a short in either them or the wiring but am still unable to power it on. If there is any way to fix this without resorting to an electronics repair store I would be ever so grateful. Sincerely -Cole.
Me too. I'm having the same exact problem. E- mail me if you find a solution. okyoujumpfirst@yahoo.com. Toby.
Posted on Feb 26, 2011
Where can I get a remote control.
I believe that you want the INSIGNIA KOR3551. You can find the remote using the following website.
http://ezremotefinder.com/results.php?mfg=INSIGNIA&mdl=KOR3551&keywords=&page=1
Jan 29, 2016 | Insignia Ns-r2000 200w 2ch Stereo Receiver
My Insignia NS-R5100 receiver goes into standby mode a couple of seconds after turning it on.
This happens because of internal overheating - clean the air vents and if you have covered the receiver with a cloth please remove the cloth your problem could be resolved
Jun 21, 2015 | Insignia Audio Players & Recorders
No sound from my speakers
Make sure your source is properly assigned and switched to respected input. Your speakers should also be engaged.
Mar 11, 2014 | Insignia Ns-r2000 200w 2ch Stereo Receiver
How do you hook up an mp3 player to insignia ns-r2000
You will need an Dual RCA to 3.5mm stereo cable. One similar to this: http://www.dcables.net/Dual-RCA-to-3_5-mm-Stereo-Cable-5-Feet.aspx
It would probably be easier to pick one up at your local Wal-Mart or Radio Shack.
Just connect the RCA connectors to one of the audio line inputs and the 3.5mm to your mp3 player. Set your insignia to receive the source you just connected.
Hope this helps
Apr 07, 2011 | Insignia NS-R2000
Can't run tv sound from my Vizio M190VA tv through my Insignia NS-R2000 receiver so it will play through my speakers in the ceiling which are connected to the receiver. Is it possible to do what I am...
I have no idea why manuafacturers or users think a TV is a good place to originate sound in this Cable Box age. The Cable/SAT box is for all intents and purpose a hi-fi multichannel audio source like any other audio component, where the TV's audio was probably an afterthought.
With that in mind, source the TV-related audio directly to the NS and skip all that zig-zagging of audio all over the room before it gets to your ears.
I also recommend taking all high-end video directly to the TV/monitor from whatever sources you have. Added cabling (and cost) doesn't help. Let the specialty devices each handle what they master.
Does that help?
Mar 18, 2011 | Insignia NS-R2000
Hello, We have had our receiver for over a year now, with no problems. Recently we have noticed that the receiver does not save the radio presets in memory if we have turned it off using the main...
if you are switching it off at the mains or unplugging it from the wall and leaving it without power for more than a short period of time (over 1 minute), yes it will loose any "saved" information.
Some more advanced processors do have a back up cell(like a cr2020) mounted on the board as they have multiple settings for speakers and complex I.P data set ups that can be kept alive and remebered in the memory for a good ammount of time until some form of power is restored.
Your receiver though, would not have such a thing and although it may store the presets briefly (up to about 30secs to maybe a minute) if there is a power interuption, there is nothing inside to help it store anyhting once it is unplugged.
So in short, if you don't want the hassle of programming stuff all the time, just leave it in standby.
Jan 07, 2011 | Insignia NS-R2000
I have Suddenlink cable and an Insignia NS-R2000 receiver that I need remote codes for, please. Thank you, G
I went to Suddenlink website and they had the code that I needed for Insignia receiver.
Thank you
Nov 09, 2009 | Insignia Audio Players & Recorders
Receiver stays on standby mode
Receiver either just stuck or held or having problem in amplifier output area.
Try to unplug it from AC outlet for couple of minutes and replug back in and power up, if works, fine and if does not, take it to local repair shop as it might requires some parts replacement in amplifier out area.
Feb 10, 2009 | Insignia Audio Players & Recorders
I have a fm-am receiver #ns-R2000, I push the power button & it shuts down immediatly, What could be the salution?
The receiver is going into a protection mode. This happens because there is a failure either inside the unit itself or in something attached to it (such as the speakers).
A quick and easy thing to try is to disconnect all of the speaker wires. If your NS-R2000 now stays on, carefully examine all of the speaker wiring to be sure it is not shorted. Also check the speakers to be sure they work properly.
Oct 20, 2008 | Insignia Audio Players & Recorders
Check the impedance ratings of your speakers. Sherwood, the actual manufacturer of the NS-R2000 receiver, suggests that you use speakers with an eight ohm impedance if you have only one pair attached. If you have two pairs of speakers attached, the impedance rating of each pair should be sixteen ohms.
This is because Sherwood wired the receiver such that an additional pair of speakers is placed in a parallel circuit to the first set. When this is done, the impedance (resistance) of the load seen by the amplifier drops. As resistance drops, you get closer to a short circuit (no appreciable resistance).
Many other receivers wire the speakers in series, which causes the impedance to go up.
Personal experience seems to suggest that the amplifier is OK with a four ohm load on it. It does run warmer with a four ohm load, which is what you'd expect. It's when you have multiple sets of four ohm rated speakers that you will get into trouble, as this means the receiver only sees a two ohm load. This will cause overheating and shutdown.
At this point the power transistors in the amplifier may have been damaged. It may require repair. Fortunately, replacement parts are readily available (though not from Sherwood or Insignia). If it continues to shut down, stop using it. You could end up burning out your speakers.
Jan 09, 2008 | Yamaha RX-V2400 Receiver
Insignia NS-R2000 Logo
392 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Curt Larson
Level 1 Expert
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
