Question about Microsoft Xbox 360 Console
How to fix xbox 360 "red rings of death"?? - Microsoft Xbox 360 Console
    Guru:
  • 91 Answers
How to Fix Red Ring of Death - A Step by Step Action Plan
Remember to rate me a 4 out of 4 thumbs up thanks
1) Disassemble Xbox 360 Case
Obtain your case separately. By a fine tip screwdriver, poke the grayed out holes and back of poke the small rectangle holes. Get the Faceplate Off and move the latch up on the DVD drive up as you remove it. Unscrew metal case which is under the plastic case.
Following is the image of video (How to disassemble xbox 360 case) which comes with James Dean's Professional Xbox 360 repair guide. If you are not comfortable with instruction you can use this video to disassemble your Xbox 360 case.
Click On Above Video Image To Watch Video On How To Your Repair Xbox 360
2) How To Remove Motherboard Safely
Unplug all cables connected to motherboard and associated small devices and take DVD drive out. After DVD, get the fan and motherboard out of the xbox 360 case. Make sure you do this gently.
Following is a quality video which can show how you can remove motherboard safely.
3) Crucial Motherboard Disassembles.
Turn the mother another side, using the screwdriver snoop off the X-clamp which you can find under heat sink. Check out following an image of a video which came with Xbox 360 repair guide which will make your process easy of "snoop off the X-clamp".
I will suggest you to do this step very gently if you are not comfortable doing this refer following video which comes with James Dean's 360 repair guide.
4) Heat Sink Unscrewing.
After snoop of X-clamp you have to unscrew heat sink to obtain CPU and GPU.I will advice you don't hurry to finish this work, please follow all steps else it will damage your xbox 360. If you are not confident do use Professional Xbox 360 repair guide.
5) GPU And CPU Cleaning.
Next step is to clean GPU (graphic processing unit) and CPU (central processing unit) If you do this step right it will help to stop xbox 360 freezing. This is very important and critical step so just make show to fix xbox 360 - 5.jpgou do it right.
6) Appling Arctic Silver
Now you have to apply arctic silver thermal compound gently over GPU.
You will get this arctic silver thermal compounhow to fix xbox 360 - 6.jpgany computer hardware shop for $1-$2.
Set it for 15 to 20 minutes then place 2 nylon washers on each screw on the heat sink then place the screws back in motherboard then add two more nylon washers to screws.
Then,
Place the heat sink on the peak of screws then push them down slight, finally screw them up. Try to make it reasonably tight.
Get everything back together and see everything is fitted properly. Now, Turn your Xbox 360 on.
I always like to educate people so I tried to describe a whole process in my words, Videos can make this whole process lot easier. I will suggest you to check out James Dean's Xbox 360 repair guide(Click Here To Visit) which will surely help you out to fix your XBOX 360. Also I have done a detail review of James Dean guide below, so don't forget to check it out if you need a pro help. please rate me high thanks
Posted on Jan 04, 2011
  • 34 Answers
SOURCE: 360 Xbox problem Three red rings
Unfortunately there is nothing that you can directly do to fix this problem.
You have a hardware failure. Microsoft will repair your unit for you under warranty / recall.
http://support.microsoft.com/kb/907534
Sorry to be the bearer of bad news.
If my solution was helpful, please vote for me!
Posted on Nov 16, 2007
benwabnick
  • 2404 Answers
SOURCE: Xbox 360 Red Ring Of Death
Only way would be to open up the xbox 360, get the heatsinks off of the board and use a heatgun and reheat the two chips that are underneath the heatsinks that you take off.
Problem with the 360's is that they use crappy solder to put the video chips on the board and the solder underneath breaks apart after a while cause of the heat that is generated by the machine. Reheating the two video chips allows the solder to reflow properly and then you can turn on the machine and get video again.
Posted on Mar 14, 2009
jennifer0607
  • 50 Answers
SOURCE: how do you fix two red rings on xbox 360?
just let it cool down,
two red light means that the internal temperature for the console just exceeded..
let it cooldown for a day..
when you use it, make sure there is no appliance near it...
Posted on Jun 27, 2009
t1m130
  • 86 Answers
SOURCE: how do you fix an xbox 360 red lights?
depending on the age microsoft had extended the warranty of the 360 you will have to contact xbox and send your unit in to get repaired
Posted on Jul 26, 2009
time_addict
SOURCE: how to fix the 3 red rings of death on the xbox 360
I tried to follow some video tutorials from youtube but none of them worked. So I realised I'd have to spend some money on real tutorials and tools. I was a little sceptical but I bought it any way and it worked just fine.
Eventually you'll have to spend some money on it. I recommend you get your hands on this set, you'll get your guides and tolls and it's all you need to fix it at home.
http://74f064-ykk5jh88anp4wf45wch.hop.clickbank.net/
Posted on Oct 11, 2009
Microsoft Xbox 360 Console Logo
129 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
