Question about Whirlpool Washing Machines
My washing machine won't spin on the spin cycle. It just makes a noise. I checked to see if anything was stuck and there wasn't anything there.
  • 153 Answers
Bad belt and possibly the idler pulley bearing is shot cost about $100.00 to fix yourself appliance repair person charges $75.00 / hour plus service call plus parts. Any appliance store will have replacement parts take model# and make with you
Posted on Jan 04, 2011
Washer stays in wash cycle will not spin out i changed control board no help
Isyour washing machine displaying an error code? If so, try using the owner's manual to decipher the code and you may beable to easily diagnose the problem. The problem could be as simple as the doorbeing slightly ajar, the machine is in pause mode, or the spin selector isstuck. Checkthe handy chart in the article Washingmachine won't advance to washer spin cycle for more possible reasons why your washingmachine won't advance to washer spin cycle-and some tricks for getting itworking again.
Aug 01, 2012 | Electrolux Washing Machines
Washing machine gets stuck in the rinse cycle
try cleaning the valve filter on the cold inlet
Apr 21, 2012 | Washing Machines
WM2016CW will not go into spin cycle. Makes slight vibration / buzz sound, but won't do anything
I'm having the same problem with mine. The washing machine was given to me because the people who had it kept getting this problem. If the tub clean cycle isn't ran on a normal basis then this will happen and I would assume you have seen the LE code pop up on the display. If the normal maintenance is run and the problem is still present then the problem could be a bad tub bearing. First thing to do is run the tub clean cycle with very little bleach and make sure to use normal bleach and not anything like ultimate care bleach as to avoid suds. Just make sure to use a small amount and let it run.
Oct 13, 2010 | LG WM2016C
My Maytag HAV2557AWW Loud Noise
pull hoses off the pump and see if there is anything stuck in it
Jun 12, 2009 | Maytag HAV2557 Top Load Washer
In spin cycle machine makes squeaky noise.
Your bearings could be going out, causing excess stress on the belt. Take the back off of the washer and check the belt tension. If there IS something stuck back there, you'll be able to see it.
May 21, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Kenmore model 22432100 - it won't drain or spin
sounds to me that something is stuck in your pump check the pump if you open the pump have lots of towels on hand the machine will not spin if it does not drain
Dec 29, 2008 | Kenmore 24032\24036 Top Load Washer
Whirlpool Duet Sport not running it makes clicks and it grinds
A common problem with noises from washing machines has been the under wire that may come out of small clothes. In the washer they can get stuck in one of the inner basket holes and make a scrapping noise, they can actually make there way into the pump and jam the pump, or make a terrible noise when the pump is running. Grab a flash light and have a peek inside the washer for this. Front load washers seem very common to this happen! If the tiny cloth is showing signs of fraying, may be best not to wash it in the washing machine, replace the cloth.=======
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Dec 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Water does not drain, strange noise while in spin cycle
sounds like something is stuck in your drain system. Most likely just in front or even in the pump
Please check this
Apr 22, 2008 | Kenmore 94812 Top Load Stacked Washer /...
Washing Machines Logo
48 people viewed this question
Dan Webster
Dan Webster
Sal De
