Question about Health & Beauty
How to get out dead NiCd battery from Norelco Maveric T2000 Beard trimmer- need to replace the battery- how do you get it out!
  • 3 Answers
Remove the screw from the bottom. The on/off switch snaps off.
Then gently work a thin bladed screwdriver in the bottom next to
the screw hole. Pry gently - the top (with the charge light and
the name written on it) slides downward about 3/16 of an inch
and lifts off. Unsolder the old battery from the board and solder
the new one in. Then snap it back together and put the screw
back in. The switch takes a little patience, but it'll snap back on.
Posted on Feb 02, 2011
  • 466G Feb 02, 2011
    In addition to the above, the battery leads where they go through the board are folded over before they're soldered. Solder wick or a solder ****** make it easier to remove all the solder before the battery can be removed. It can be done without it, but it's a bear.
  • Moe Rubenzahl Feb 11, 2012
    Thanks -- this one is tricky! Note that it's a Norelco Maverick T-2000 takeapart. I am noting that to make this article more findable for the next guy!
How do I replace the battery on my Norelco D-finer D350?
try checking on placement of the batteries where it is screwed outside. you unscrew it and open the cover then change the batteries.. you can also sneak into the manual for sure..
Apr 28, 2011 | Norelco D-Finer D350 Beard Trimmer
How to remove battery from norelco t 800 can not get to come apart after removing 1 screw on grip
Disassembling the Norelco T800 is quite easy -- once you know what to do!
* Remove the single small Philips screw that you can see near the power connector
* Twist (hard) the cutter depth ring past 9 and it will come loose.
* Now remove both the ring and the guide piece that it moves up and down
* Now pry off the cutter head (black piece of plastic)
* Now remove the metal clip that you find under the head -- press down on the two free ends and pry the other end of the clip loose.
* Now release two plastic tabs that we under the rotating ring.
* Now I just pried the two parts apart by inserting a small screwdriver and twisting. I'm not sure if there are any more tabs that can be released at this point.
* Now you can remove the circuit board (which is held in my a couple of plastic tabs).
Now you can replace the *single* NICD 600maH battery (AA size). The longest bit of this step was heating up the soldering iron!
Reassembly is the reverse.
Philip
Nov 08, 2010 | Norelco T 800 Beard Trimmer
My t860 will not hold a charge, and now I can't get it to work while plugged into the charger, can the battery be replaced?
The battery can be replaced. There is a single AA NiCd battery soldered into the main circuit board.
To open up the trimmer, first take the silver screw out (located near the lower back side). Then pull the trim guard off the top (should come off easily). Next, the rubber-like ring used for adjusting the trim height needs to be pulled off -- this can be difficult but just work your way around and ease it off. Finally, the metal clip on the end of the trimming head needs to be removed, and the plasic case can then be popped open, revealing the circuit board.
If you're not comfortable soldering or disassembling it, it can likely be done at a local Batteries Plus store.
Mar 14, 2010 | Norelco T870 Beard Trimmer
How to open case on Norelco T-3000 beard trimmer
Remove the bottom screw. Next, the on/off slide switch has to be lifted off carefully with a small flat screw driver. Its kept in place with a small spring steel clamp. After you've removed it lift off the steel clamp and remove the slide mechanism by carefully twisting it out of position. Once that's done it will twist open easily.
Jul 25, 2009 | Norelco Health & Beauty
How do I change the Battery in My Norelco T3000 Beard Trimer
Remove Phillips head screw at bottom of trimmer. Separate body in two being careful to notice how on/off switch is assembled. Unsolder the ni-cad battery from circuit board. Install new ni-cad battery of the same physical size that has solder tabs on it and solder it to the circuit board. I used a ni-hi (nickle metel hydride) instead of ni-cad which had different charging requirements so I limit charge time to no more than 16 hours for a discharged battery. It had been working fine for over a year. Don't forget to apply a few drops of light oil to the cutting blades to extend cutting life. Replacement blades are about $30.00
Jul 06, 2009 | Norelco T770 Beard Trimmer
I just got done doing the same thing
Can the charger charge your NiMH batteries? I was thinking of doing the same thing, but didn't think the NiCd charger would be able to charge the NiMH.
Norelco t860 how to take apart to replace battery
The battery can be replaced. There is a single AA NiCd battery w/ tabs soldered into the main circuit board.
Jun 27, 2009 | Norelco T870 Beard Trimmer
Health & Beauty Logo
1,042 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
