Question about Haier HWR08XC7 Air Conditioner
Hi. my room air conditioner model: hwr12xc8 timer is not working
  • 2,133 Answers
Switch on a/c and then set timer. You will get beep sound. If no sound communication error between unit and remote.Replace remote.
Posted on Jan 04, 2011
Room temperature senor not working
Hi Karl,
I hope the following links is helpful to you
Good luck
http://errorcodeairconditioning.blogspot.com.au/2010/10/fujitsu-air-conditioner-error-codes.html
Jan 24, 2015 | Fujitsu ASU30CLX1 Single Zone Wall...
I need to know what the voltage for this unit
Model: REG-123H
  • UPC: 855326002968
  • Product Type: 12,000 BTU Window Air Conditioner & Heater
  • Product Dimensions: L: 24.00" x W: 24.00" x H: 16.00"
  • Product Weight: 88.00 lbs.
  • Product Color: White
  • Application: Used to cool individual rooms
  • Type: Window Air Conditioner
  • Warranty: 1 year; 5 years sealed system
  • Coverage Area: 550 square feet
  • Voltage: 230 volts
  • Heater: Yes
  • Air Flow: 266 CFM
  • Amps: 5.5 amps
  • Heating Capacity: 11000 BTUs
  • Frequency: 60 Hz
  • Cooling Capacity: 12000 BTUs
  • Dehumidifying Capacity: 3.6 pints
  • EER: 9.8
  • Heat Pump: No
  • Number of Fan Speeds: 3
  • Programmable Timer: Yes
  • Timer Length: 24 hour
  • Refrigerant Type: R-410A
  • Air Conditioner Type: Cool/Heat
  • Energy Star Rated: No
  • Air Filter: Yes
  • Built-In Air Purification System: No
  • Display Type: Digital
  • Remote Control: Yes
  • Adjustable Louvers: Yes
  • Adjustable Side Panels: Yes
  • Compatible Window Size: Min. Window
  • May 31, 2014 | Comfort-Aire RED-123 Air Conditioner
    Haier air conditioner won't cool the room anymore
    i bought the air conditionor new and it will not cool what can i do
    Jul 05, 2012 | Haier ESA406K 6,000 btu ECO-Friendly...
    I bought the HWR12XC8 0nly 2 years ago brand new from WalMart. I just turned it on and sparks fleww out where the cord gos in to it. Pretty sure I sent in the registration card, but not sure about how long...
    Your model had a one year parts and labor warranty. The first place to start is with Haier's Customer Support 1-877-337-3639.. They're good folks and will try to work with you, if you approach the issue calmly. As far as a Recall is concerned, I am not aware of any for your model AC or any other model, for that matter.
    Hope this helps you and thanks for choosing FixYa..
    Jul 27, 2011 | Haier HWR12XC8 Air Conditioner
    I have to install a new cord . i need to know where to hook up the power line inside my unit .thank you
    To get the best information (because, I can't see the unit) call Haier Customer Support 1-877-337-3639 and ask for Technical Service.
    Jun 29, 2011 | Haier HWR12XC8 Air Conditioner
    Ihave a fujitsu air conditioner model asta18lcc about 2 yrs old when I turn it on fan works but room wont get cold or hot,red operation light does not stay on but green timer light flashes on. thanks...
    The lights on the front panel indicate fault codes dependent on the amount & intervals of the flashes. Fujitsu units carry a 5 year warranty so check with your local Fujitsu store for the agent in your area.
    Aug 13, 2010 | Fujitsu 24C1 Air Conditioner
    Mt timer butoon is stuck on timer so unit wont work
    All LG room air conditioners should be able to be operated without using the remote, by just using the controls on the unit. Replacement remotes are available from an LG service provider.
    Jun 05, 2010 | LG Electronic Window Air Conditioner
    The timer light keeps flashing and unit does not respond to the on by cooling the room when the on button is pressed
    timer button keeps flashing and no heat coming from unit. cool air works, but absolutely no heat.
    Oct 13, 2009 | Daewoo DSA-122L Air Conditioner
    Not turning on
    Hi
    Try to reset the unit by disconnecting the power supply for 10sec. and operate the unit. If it wont work replace your Room Air and Coil Thersmistor or test the thersmistor with mulitester. The resistance reading of thermistor is 10 kilo ohms @25deg. C room temp. If it is shorted or open the unit wont operate.
    Hope this can help :)
    Dec 30, 2008 | Carrier 36KCARMS Air Conditioner
    Haier HWR08XC7 Air Conditioner Logo
    315 people viewed this question
    Top Haier Heating & Cooling Experts
    Tom Chichester
    Matt
    Matt
    Level 1 Expert
    Michelle Balcom
    Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
