Question about Microwave Ovens
The oven stopped working...doesn't heat up. The stove top works fine, the oven has light, but the heating elements just stopped working last week.
  • 2,841 Answers
Remove the heating element and inspect them for a bulge or break. If you seen any bulge or burnt spot the element is defective. Normally they are held in place with one or two screws you remove end then pull the element out. If they look good then check for continuity with an ohm meter. Set the ohm meter to 1000 ohms and place red probe one one end and black probe on other end. If the meter does not move then the element is defective and must be replaced.
Posted on Jan 04, 2011
May Spacemaker XL1800 stop heating food. Was working fine. Then just stop
Is this an over the stove type unit? I have had a few problems with my over the range spacesaver. I think the heat from cooking gets up into the microwave and damages it. The steam from me boiling things on the stove had mine quit heating and I purchased a new one. The parts to replace the faulty ones can be quite expensive over $150.00, so its better to purchase a new microwave.
Feb 24, 2013 | GE Microwave Ovens
My GE gas oven won't heat up. The stove top and broiler work fine but when I turn the oven on, nothing.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jul 03, 2011 | Microwave Ovens
While pre heating oven, heard a sort of explosion. The bake element was definitely broken. A new one was purchased, installed, but it does not heat up. The broiler also does not work, but stove top does....
i have seen elements short out and cause the main board to fail. if eeverything else works you know you have proper power , so i would say the board is bad
May 12, 2011 | Microwave Ovens
I AM GETTING ELECTRICITY TO THE 220 PLUG AND THROUGH THE 220 PLUG WIRE TO THE STOVE JUNCTION BOX. THE STOVE TOP AND OVEN HEATING ELEMENTS ARE NOT HEATING UP BUT THE INDICATOR LIGHTS FOR BOTH ELEMENTS SHOW...
The indicator lights operate on 120 volts whereas the elements operate on 220 volts.
Using an electrical test meter go between the two hot legs and see if you are getting 220 volts. If not you have an open or non completed circuit.
Do not test from one leg to ground as you will probably read 120 volts for each leg. By reading across both legs you should get 220 volts.
May 03, 2011 | Microwave Ovens
We turned on our oven last night and it heated up to 345, wanted to get to 400, then my wife saw smoke form the right hand front of the inside of the oven. I wanted to check the element, but can't figure...
I am assuming you are referring to a conventional stove. First shut off power to the stove at the breaker panel. (either a 40 or 50 amp breaker). Check to see if the elements come on before proceeding.
Slide out stove and unplug it. Look on the back. There will be a vertical piece of sheet metal with 1 to 3 screws or a large flat panel with several screws (1/4 Inch socket). Remove this panel to reveal the leads to the bake element.
remove the leads. Then remove the two screws inside the stove (1/4 inch socket) to remove element. The model and serial for the stove should be located by sliding the drawer out at the bottom of the stove on the left side.
You will need this number for the correct element. They run about 20 dollars typically. Hope this helps.
Feb 17, 2011 | Microwave Ovens
Amana aco 1840 over stove micro wave. heating not working .
FIK IT THE HEATING ELEMENT IS STRIGHT FORWORD AND COST IS CHEAP, GO FOR IT .
Oct 24, 2009 | Amana ACM1580 Convection Microwave Oven
MMV1153BA brand new, less than 2 weeks
The magnatron may need replaced..(this is what makes it cook)
Dec 10, 2008 | Maytag MMV1153A Microwave Oven
Microwave Ovens Logo
21 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
