Question about GE Microwave Ovens
Microwave does not have power. - GE Microwave Ovens
  • 254 Answers
If it's completely dead (no lights, no nothing) it probably blew the fuse.
Posted on Jul 09, 2008
My over the stove microwave starts continues for a few econds the f-7 appears and it stops
F7 means power to magnetron is interrupted.
I don't recommend that someone without experience and an understanding of the safety procedures undertake troubleshooting this.
You can find manuals and helpful exploded view diagrams for your model here and my favorite parts supplier is here. There is a technical sheet hidden behind the controls that has helpful technical and troubleshooting information. It will say something like this:
F7 Power to magnetron interrupted
1. Unplug microwave oven or disconnect power.
2. After 40 seconds, check to see whether this solves the problem.
3. Unplug microwave oven or disconnect power.
4. Check cooling fan operation
5. Check the magnetron.
6. Check P65 connection on the relay control board.
7. Check the P56/P66 connection between relay board and relay control board.
8. Check wiring to the 1200W inverter and control system. See "Checking Inverters."
9. Check operation of all interlock switches.
10. Replace all parts and panels before operating.
11. Plug in microwave oven or reconnect power.
12. Check voltage at 4903-1 on relay board. If it is 120, unplug microwave oven or disconnect power.
13. Replace inverter.
14. Replace all parts and panels before operating.
15. Plug in microwave oven or reconnect power.
16. If problem persists, unplug microwave oven or disconnect power.
17. Replace relay control board.
18. Replace all parts and panels before operating.
19. Plug in microwave oven or reconnect power.
20. If problem persists, unplug microwave oven or disconnect power.
21. Check for reversed plug connection on controls or loose wiring.
22. Replace all parts and panels before operating.
23. Plug in microwave oven or reconnect power.
William E. Miller, AS-EET
http://www.MicrowaveControl.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Oct 05, 2016 | Kenmore Microwave Ovens
How do I set Clock?
Disconnect the microwave from the power source while the power is still out. If the microwave is a built-in, turn off the circuit breaker. Otherwise, unplug the microwave from the wall outlet. This prevents a power surge from damaging the magnetron tube when the power is restored.Turn on the circuit breaker or plug the microwave into the outlet only when you are sure that the power is permanently restored. If there are still storms in the area, the power may be disrupted again. Reset the clock on the microwave. Microwaves vary slightly on how to set the clock, but usually there is a clock button you press. Use the number pad to input the correct time and press the clock button again to set it. Test the microwave by heating some water to ensure that it is still in good operating condition.
Jun 20, 2012 | Emerson Fans MW8995B Microwave Oven
Jenn air microwave JMV 916 BAS won't power up
The magnetron has probably shorted, and in rare cases the power transformer will fail, "but unlikely"
Mar 27, 2012 | Jenn-Air JMV8000 Microwave Oven
My microwave want cook
Hello
and/or circuit breakers, particularly in the case of recent power failure, and reset if necessary.
Unplug the microwave, wait 30 seconds and plug back in to the power supply to reset the microcomputer.
Open and close the microwave door firmly and press "Stop/Reset." Select a new cook time and press "Start."
Ensure a proper cooking temperature and/or time is chosen, as low cooking temperatures or short cooking times may prevent the microwave from heating food appropriately. Press "Power Level" to ensure the microwave is cooking at 100 percent power.
Contact an authorized service technician if the problem is still unresolved.
Oct 04, 2011 | Sanyo Microwave Microwave Oven
Whirlpool Microwave error F3H
F3H Humidity sensor failure 1. Unplug microwave oven or disconnect power.
2. Connect a new sensor to the board (at P5).
4. If no failure code appears when starting sensor function:
 Replace old sensor.
5. If failure code appears when starting sensor function:
 Replace power supply board.
6. Plug in microwave oven or reconnect power.
Aug 04, 2010 | Whirlpool GH5184XPQ Microwave Oven
F7 code on Whirlpool Microwave model GH9185XLT - 1
Power to magnetron
interrupted
12. Replace inverter.
13. Replace all parts and panels before operating.
14. Plug in microwave oven or reconnect power.
15. If problem persists, unplug microwave oven or disconnect power.
16. Replace electronic control.
17. Replace all parts and panels before operating.
18. Plug in microwave oven or reconnect power.
19. If problem persists, unplug microwave oven or disconnect power.
20. Check for reversed plug connection on controls or loose wiring.
21. Replace all parts and panels before operating.
22. Plug in microwave oven or reconnect power.
May 23, 2017 | Whirlpool GH9185XL Microwave Oven
How do you set whirlpool microwave to 50% power
The microwave oven should be at a temperature above 50°F (10°C) ... microwave oven can be manually set to defrost. To defrost. manually, use 30% cook power. ...
www.whirlpool.com/assets/pdfs/product/ZUSECARE/8205987.pdf
Jul 03, 2009 | Whirlpool GH4155XP Microwave Oven
Microwave F-7 Code
F7 is q Power to magnetron
interrupted
5. Check resistance of the magnetron thermostat.
6. Check the magnetron.
7. Check P2, P4 and P27 connections.
8. Check wiring to the 1100W inverters and control system. See
“Checking Inverters.”
10. Replace inverter, if defective.
11. Replace all parts and panels before operating.
12. Plug in microwave oven or reconnect power.
13. If problem persists, unplug microwave oven or disconnect power.
14. Replace electronic control.
15. Replace all parts and panels before operating.
16. Plug in microwave oven or reconnect power.
17. If problem persists, unplug microwave oven or disconnect power.
18. Check for reversed plug connection on controls or loose wiring.
19. Replace all parts and panels before operating.
20. Plug in microwave oven or reconnect power.
Aug 08, 2008 | Whirlpool GH6177XP Microwave Oven
Whirlpool microwave combo - has not power - model RM286PXV2
check the control unit and highvoltagae areaand megnetron , related circuit..
Sep 10, 2007 | GE XL1800 1100 Watts Microwave Oven
Microwave Ovens Logo
46 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
