Question about Dynasty DGRSC 30 Gas Kitchen Range
RED LIGHT ON FRONT
Hi, I am housesitting and the oven has a red light which is glowing on the front. Does that mean the oven has been left on. How do I turn it off?
Thanks
  • 770 Answers
Yes you need to turn the contoller fropm the bake position to the off position most likely the temp is turned down so the oven wont heat up
Posted on Jul 09, 2008
Frigidaire oven FGB24L2ASA. Igniter glows red, gas turns on, but does not light.
I appreciate your inquiry, K Ogle!
From what you have described about your Frigidaire range the igniter glows red and the gas turns on but it will not light. It sounds like it could be a faulty burner or igniter and I would recommend having a professional come out to properly assess your range. This does not sound like a simple DIY job. Good luck. -Matt
Feb 17, 2015 | Frigidaire Kitchen Ranges
Should the lower oven heating element heat all the way around? The heating element in my oven only heats and glows red on the front and two sides, The rear part of the element never glows red.
This is probably normal. the element has a fine wire inside the tube that you see and depending on where it starts in the tube it will start glowing from there.
Nov 15, 2014 | Maytag MER6872BAS Gemini Electric Kitchen...
Left front range top burner temerture control issues
Good Morning Friend,
I understand that you are having trouble with the left front burner on your Frigidaire range, model# FEF355. I see that the burner heats up to a glowing red hot temperature, no matter what you set the dial to. I suggest resetting your appliance, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes.
When power is restored, the first thing you will need to do is set the clock. You will do this by pressing the "Clock" button, then within 5 seconds press and hold the up or down arrows until the correct time of day appears.
Once you have set the time, turn on the left front burner, on the lowest setting. If the burner is still glowing red hot, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your range and determine what is causing the burner to glow red hot on all settings. Hope this is helpful.
-Best Regards-
WP
May 15, 2014 | Frigidaire FEF355 Electric Kitchen Range
My oven ignitor is glowing red but my oven will not light. My broler will come on! What could be wrong?
It's going bad and not reaching the proper amperage to trigger the gas to let out. You need to replace it and turn off the oven until it's replaced.
Mar 15, 2012 | Kitchen Ranges
My la cornue oven not heating, turn 1st knob to function desired and then temperature knob to desired temp but oven does not heat up
First thing should be to make sure the top selector switch is not set to the optional Pizza element.
Make sure the power to the unit is OFF. Also keep in mind that the following tests should be done by a qualified appliance specialist. To find one near you, contact the La Cornue Service Center @ 877-522-6768
Is this the first time using the oven? If so, make sure the overall power to the range is 240 volts. This can be checked at the main terminal block.
If your model has three indicator lights and the red light is illuminated, then it is likely the hi-limit thermostat has tripped and you will need to reset it. The reset switch is located underneath the cycling thermostat. To access this, you will need to remove the front fascia. Please note: The original safety thermostat is no longer available. Use current safety thermostat (reference: 06ELTS01). If your model has only two indicator lights and the red light is illuminated, that means the oven is heating up. If the red light is not illuminated when the thermostat is set at the desired temperature, then check the hi-limit thermostat.
Power relay/contactor on the back of the unit should be checked. It
Jan 06, 2011 | La Cornue Grand Maman Dual Fuel (Electric...
Oven igniter glows red, but no gas fire.
The oven igniter is glowing so that tells me the circuit is sound, the oven control is working, and the oven safety valve is ok. That means only one thing. Weak igniter. The igniter must draw 3.2 amps in order to open the safety bi-metal inside the valve. Bumping or tapping on the stove will make the oven light off. Solution replace the igniter. I have repair photos HERE
Feb 03, 2010 | Hotpoint RGB535 Gas Kitchen Range
Burner on range will not turn off
Look at the back of your range there should be schemetic for your power control board. look for defective burner wire going into relay. There should be 5 relays in rows. Realy is the problem. I had the same problem with my front left burner stuck on high.
After replacing everything works okay.
Apr 07, 2008 | LG LRE30755 Electric Kitchen Range
Re:Whirlpool SF310PKE gas range
When the oven safety valve refuses to open and let gas through, it's almost always because not enough current is flowing through the ignitor. Often an aging ignitor will appear to be glowing pretty brightly but still won't draw enough current to make the valve open. The first thing to try replacing is the ignitor.
You describe your ignitor as "red and glowing" but oven ignitors normally get a lot brighter than "red" -- well into what I'd call yellow.
Dec 19, 2007 | Whirlpool SF310PEK Gas Kitchen Range
Maytag MGR4410ADW
You probably need to replace the the ignitor. Even though it glows red does not mean that it is working propery. If it does not draw at least 3.5 amps the gas valve will not open. This can be check with a amp meter.
Feb 20, 2007 | Maytag MGR5751AD Gas Kitchen Range
Dynasty DGRSC 30 Gas Kitchen Range Logo
83 people viewed this question
Top Dynasty Kitchen Ranges Experts
Ismael Rodriguez...
steve morris
steve morris
Are you a Dynasty Kitchen Range Expert? Answer questions, earn points and help others
