The sensor? The FG is a film camera and doesn't have an image sensor. Do you mean the lens? Viewscreen? Mirror? Something else?The sensor? The FG is a film camera and doesn't have an image sensor. Do you mean the lens? Viewscreen? Mirror? Something else?
You can't post conmments that contain an email address.
Light meter only works with the back door shut and the film counter is at frame 1 or more !!, Also if the camera is set at M90 or bulb (B) mode, Meter will not work there ether,
Take the lens off the camera and look inside. you should see a mirror angled at 45 degrees. If you do not see the mirrir, it is probably stuck in the up position and repair is necessary
Check the batteries first. The electromagnetic shutter requires power to function. To free up the shutter and advance lever, rotate the command switch to "M90" (if I recall). That should re-set the shutter and allow you to advance the lever mechanically.
try to set the itty ***** red dot to 0 again make sure the collar goes down its the compensation mode once its down try turning the speed dial again i haven't had a film camera for about 8yrs i had a nikon 6060 which is almost like a fg . hope this helps
