Question about Kenmore Side by Side Refrigerator
Refridgerator not getting cold - Kenmore Side by Side Refrigerator
  • Barrett Palumbo
    Barrett Palumbo Jan 04, 2011
    Sorry to read about your issues.
    But you really need to give us the model, of your unit. It kinda helps us to help you. and a more detailed explanation, of whats is going on..
  • Kenmore Master
  • 43,501 Answers
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Jan 04, 2011
Samsung rf267 series refridgerator not cold enougheverything else works fine its just that the milk goes off and things go bad because it doesn't get cold enough
this could be your stat has gone or you have an insulation leak gas leak you will need a fridge engineer believe me it will save you loads a call out should cost you around 25 to 30 but its cheaper then any thing else ok
Oct 22, 2012 | Refrigerators
Kenmore Refridgerator/Freezer does not work.
check your damper vent door located between the fridge and freezer and make sure its opening up to let cold air into the fridge,also check the evaporator fan motor and make sure its operating to blow the air around the inside of the unit
May 23, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refridgerator and freezer are not cold
hello sir/mam
if this is the problem please check the condensor of the refrigerator for its enough refrigrant.
Sep 14, 2009 | Whirlpool GB2SHKRLS Stainless Steel Bottom...
Fridge isn't cold
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
May 28, 2009 | Refrigerators
Top refridgerator does not get cold but the bottom freezer works fine
Most of these have a fan that blows the cold air for the freezer into the refrigiator section. If the fan quits running you will experience your problem.
May 08, 2009 | Refrigerators
Freezer in nice and cold but refridgerator is not
due to lots of moisture in the air or high humidity it creates extra frost in the freezing unit this creates blockage in the air flow once the ice crystals build up. the freezer is what keeps the fridge at the normal temperature if the air flow between the two are blocked in the ducting then the fridge temperature will rise the best way to solve this is to open the freezer take out the 4 screws in the back panel tilt the panel forward and blow it with a blow dryer till the ice chunk has melted its a good idea to use a towel and on the top self of the fridge to obsorb excess water this can be kinda messy. or you can unplug your fridge for about 6 or so hours. good luck hope i helped. :)
Mar 25, 2009 | KitchenAid KTRS22EM Top Freezer...
Marvel beverage refridgerator is not staying cold anymore
Make sure you have 3-5" of space all around, otherwise it keeps sucking its own hot air and reaches 'equilibrium' and won't get any colder. Ever
Jan 15, 2009 | Refrigerators
Fridgidare, freezer cold fridge warm
sounds like you may have gotten a refridgerant leak causing a low charge condition. some refridgerators have a evaporator fan if this quit working it will cause it to freeze up .thus the freezer does not use a fan and it will still get cold
Jan 05, 2009 | Frigidaire FRS26ZSG
Whirlpool side by side freezer ice cold refridge only at 55
My frigidaire has a flapper valve assembly that opens and lets the cold air in from the freezer as required. The frigidaires are known for the flapper breaking and staying open and allowing too much cold air in to the refridgerator side.. Check yours out. Mine has a shroud at the top of the refridgerator. Remove it and look around, I feel sure you have the same problem.
Dec 11, 2008 | Kenmore 57029 Side by Side Refrigerator
Kenmore Side by Side Refrigerator Logo
70 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
