Question about HP LaserJet 4000tn Printer
Error 13.1 paper jam but there is no paper jam
    Novelist:
    Scholar:
  • 111 Answers
Well... you've either got a bad sensor, or there is something stuck in there. It doesn't take much to signal the jam.
Assuming you've been using it for a while, and the same type of paper, you might try some canned air and blow out the paper travel areas. (stay away from the toner cartridge.. remove that when you start blowing air around). If you're lucky this will dislodge whatever is tripping the sensor or you may see a small piece of paper fly out.
Carefully check the entire paper path and even pull out the supply paper, ruffle through it back and forth then replace it and give it a try.
Hit clear and/or power it off for a minute then back on... hopefully you had it off when you did all the above.
If that doesn't clear it, again, may be a bad sensor, or something stuck you can't find. In either case you're going to need a technician to get further towards getting the machine back in working order.
8^)
Posted on Jan 04, 2011
Error 13 on epson dfx 9000 printer
Hi Good day!!
Error 13 is a printer error code that signifies that there is a paper jam. You need to check the jam in the entry if your system shows this error. Error 13 also indicates the need to replace the pickup roller in the printer.
Aug 29, 2012 | Epson DFX-9000 Matrix Printer
When printing an error "13" appear. what is the cause of the error and what could be the posiible solution. pls advise. thanks
Its a paper jam error. Check your printer properly, even a tiny piece of paper can make it to give error 13.
Mercedes Parts
Aug 01, 2012 | HP (2562C) Matrix Printer
HP p2015dn I can't find error 13.000 in the manual
13.XX error msg almost always refers to a paper jam. Paper jam can be an actual paper jam, can be a sensor that is broke or stuck in the wrong position, Could also be a false paper jam. Printer tries to feed paper, paper never feeds, causing the paper path sensor to say "hey, that sheet of paper never reached me, so it must have jammed somewhere. Check the paper path for a paper or piece of paper.
Jul 21, 2011 | Office Equipment & Supplies
Well, I did everything your steps said to do but that did not fix the problem. When all is done and turned back to online, the printer buzzes and flashes the 13 paper jam again; however, there is no paper...
If your printer makes a load clicking sound and then shows "paper jam" then the problem is a broken drive motor gear. This is a very common problem with this unit. The nylon gear on the drive motor becomes brittle due to the age of the unit and cracks. When this happens the gear teeth do not mesh with the other gears and you get the grinding and clicking sound, and no paper pickup. You can change the gear yourself. The drive gear is available here:
http://www.ccl-la.com/catalog/product_info.php?cPath=24_41_49&products_id=61
And here is a video showing how to install it:
Jan 28, 2011 | HP LaserJet 4p Printer
HP 3005dn Printer Tray 1 paper jam error
If message in display panel reads [13.XX PAPER JAM [LOCATION]]Media is jammed at the specified location (and possibly at other locations). If the message persists after all jams have been cleared, a sensor or sensor lever might be stuck or broken.
Soln.
For all jam messages, do the following: 1. Remove jammed print media from the specified location. Check the entire paper path for other pieces of media in the path. 2. Open and close the top cover to clear the message. 3. Check sensors and flags in the paper path for proper operation.
For message 3.0 PAPER JAM [LOCATION]
means
A non-specific paper jam occurred.
Soln
1. Remove jammed media from the specified location. 2. Verify the paper tray is fully closed. 3. Inspect and/or replace the feed and separation rollers. 4. Ensure there is no obstruction in the path, such as a torn piece of paper. 5. Open and close the top cover to clear the message. 6. Check sensors and flags for proper operation.
For more help check yhis site
http://www.printertechs.com/tech/error-codes/error-codes-0-19.php
Nov 26, 2010 | HP LaserJet P3005n Printer
New out of the box 13:20 error paper jam there has never been any paper in machine we're just setting up. open and close front, then theres a fuser jam lift and close top, front door again.We have paper in...
PAPER JAM [LOCATION] Media is jammed at the specified location (and possibly at other locations). If the message persists after all jams have been cleared, a sensor or sensor lever might be stuck or broken. For all jam messages, do the following: 1. Remove jammed print media from the specified location. Check the entire paper path for other pieces of media in the path. 2. Open and close the top cover to clear the message. 3. Check sensors and flags in the paper path for proper operation.
Jun 24, 2009 | HP LaserJet 3600n Printer
Error 13-jam paper HP Laser 4+
HP LaserJet 4, 4m, 4 Plus and 4m Plus Series Printers - False Error Message 13 PAPER JAM ISSUE: After clearing all jammed paper from the HP LaserJet 4, 4m, 4 Plus, or 4m Plus series printer, the display still reads 13 Paper Jam . Even after cycling the power off and then back on, the error remains. SOLUTION: Open the rear door of the printer. There is a paper sensor near the upper right hand corner of the fusing assembly (just below the right edge of the long yellow warning sticker on the fuser) that can cause paper jam error messages even when there is no jammed paper in the printer. Toggle the thin black plastic lever up and down to make sure it is not stuck or sticky. The lever should be in the down position before closing the back of the printer. If the lever is stuck or missing, the printer will generate a false paper jam message. Hope it will help you !
Apr 02, 2008 | HP LaserJet 4 plus Printer
HP LaserJet 4000tn Printer Logo
132 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
