Question about Whirlpool AWM9000 Front Load Washer
Whirlpool duet sport frontloader washer, door wont open, locked up.
What can i do to get the door to open?
  • 1 more comment
  • suzsezok Jul 10, 2008
    Thank you very much Lumpy. You saved my day!
  • Toby Norton
    Toby Norton May 11, 2010
    Have you tried the manual release to open the door? If you remove the 1/4" screws along the bottom most panel, the lower front panel will come down. If you reach up where the door switch is, on the bottom of the switch, there is a pull tab that will manually release the door.
  • Patty St Amand
    Patty St Amand Mar 15, 2014
    where is the door switch?
  • 246 Answers
Not a problem glad we could help.
Posted on Jul 11, 2008
Great!!! It was very simple, all I needed to do is open three screws and pull the fron cover and reach in you can feel a latch just pull it down (esy no need to use any force) and wow!!! it opened front door.
Hi, I live in Illinois and called service man from Ace Appliance Service, paid $65.00 and I was told by the repair person door can not be open nd he needs to break the latchwhich will be another $88.00 for the new lock/latch and $130.00 to replace... Wow!! it took less than 5 minutes and I was able to open it I am not a technical person but your instructions were simple and straight forward....
Thank a lot
Posted on Dec 12, 2010
Thanks I was able to take my clothes out with your instructions of the latch, but now I tried to run a cycle to clean machine to see if it would reset it, but it is not responding to any running cycle. Is it the motor?
Posted on Oct 15, 2012
  • 3 Answers
First thanks Lumpy816- second to his help, the size socket you need to use ( unless you have some torx head allen wrenches) is 9/32
Posted on Nov 23, 2009
Hi, I have model wfw8300sw04. I'm having trouble with it spining & draining. It won't drain and it spins once and stops. I have check the drain for any clogs and nothing.
Open the door and push the bottom front of the boot aside and look to see if an article of clothing as gotten in there. Post back your findings.
Nov 13, 2012 | Washing Machines
Whirl pool duet sport the door is locked and it wont let me open it
You can remove the lower panel. Have to drain the hose - water rushes out...and then reach up insie the washer where the door latch is, there will be a ring that you can pull on that releases the lock.. Got that much done...but the beeping continues... Be sure to unplug the machine first!
Nov 19, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Door won't open on whirlpool duet washer frontload
Press the cancel button twice to cancel the error code. There should be an error code flashing -- for example 'F02'.
Nov 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Front loadin washer says control locked!
The Control Lock is a designed safety feature that enables the us to lock the control panel to prevent small children from manipulating the controls and accidentally starting the appliance.
The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds to 10 seconds.
Please do refer this link for a detailed explanation for your knowledge.
http://www.fixya.com/support/t4186517-control_lock_light_machine
Apr 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The door on my Whirlpool duet sport won't close / lock ..
its best if you call whirlpool to set up service call. tampering with your washer could void the warranty
Dec 16, 2008 | Whirlpool GHW9400 Duet Washer
Whirlpool front loader duet sport washer door will not open
without complete f code hard to pin cause but suspect pump not pumping out remove bottom cover reach up to lock area pull small tab down to unlock door remove as much water as possible remove pump clean out by turning counterclockwise clean pump and connecting hoses reassemble and ck
Nov 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool doet washing machine
the door on any frontload whirlpool washer cannot be changed from side to side.only the dryer
Sep 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Water leaking from my whirlpool frontload washer
open the door and check between the drum and door frame. There is a large rubber bladder completely surrounding the drum. Pushing the drum further back into the machine will let you see the entire thing and unfold it. These often get small laundry like socks stuck there as well as sharp objects like nails. You may have a tear in it which will leak like that. Replacement parts run about $70.00.
May 24, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool AWM9000 Front Load Washer Logo
4,663 people viewed this question
Dan Webster
Dan Webster
Sal De
