Question about Samsung RF267AEBP (258 cu ft) Bottom Freezer French Door Refrigerator
After a brown out, the front panel shows 88 and 08 (flashing). Nothing happens when i press any of the buttons. The refrigerator seems to still be cooling.
Wow, Grumpit...your solution worked perfectly (Press the top left (Engery Saver) and top right (Alarm) buttons at the same time for about 10 seconds--it will beep and reset the panel.) What a racket both GE and local repair places have going...they both told me I needed to replace the entire contol panel!! GE needs to start telling people this along with unplugging the fridge when you call in and ask about the error code.
Posted on Apr 04, 2011
  • 1,531 Answers
Unplug the unit for about a minute and plug it back in and it should reset itself and be good to go
Posted on Jan 04, 2011
  • 2 more comments
  • Michael557 Jan 08, 2011
    I tried it tonite, did not work for me.....88 and 08. the 08 blinks. Wondering if worked for you
  • grumpit Jan 08, 2011
    Nope, but I found out the answer. Press the top left (Engery Saver) and top right (Alarm) buttons at the same time for about 10 seconds--it will beep and reset the panel.
  • Success Aug 16, 2013
    Thank you... searching all over on how to reset the panel from flashing 88 and OA. Pressing both Energy Saver and Alarm did the trick. I'm dealing with ice building up in the walls of my GE Profile side by side with a lower freezer. This error happened when I tried plugging the unit back in after defrosting the refrigerator.
  • Bill Haas
    Bill Haas Nov 04, 2013
    Had the same Problem and searched all over till found this and it worked.
Washing machine humming but nothing else :(
if you watch carefully, the end light flashes and then stops, and then flashes again... how many times flashes?
Dec 22, 2013 | Zanussi FS1455W Front Load Washer
AMP ERROR DISPLAY NO VOLUME
This is how to reset the receiver to factory default- not sure if it is the same reset you would do for an amp error:
Resetting the system
Use this procedure to reset all the receiver's settings to
the factory default. Use the front panel controls to do this.
1 Switch the receiver into standby.
2 While holding down the front panel STEREO/A.L.C
button, press and hold
u STANDBY/ON for about two
seconds.
The display shows RESET?.
3 Press the front panel AUTO SURR/STREAM DIRECT
button.
The display shows OK.
4 Press HOME THX to confirm.
OK appears in the display to indicate that the receiver
has been reset to the factory default settings.
Note that all settings will be saved, even if the
receiver is unplugged.
Unfortunately, amp errors are usually not fixable and require you to bring the receiver on for repairs or just buy a new receiver.
THANK YOU AGAIN SO MUCH! I basically got through the 1st step or so and the thing came right back on like nothing had ever happened. Although, I think what ended up working for me was actually pressing and holding the STANDBY/ON button with the AUTO SURR/STREAM DIRECT button together for a few seconds....I didn't have to reset to factory settings, nor did I have to do step 3 or 4.
Now the receiver is working just fine like nothing ever happened. All of the input AND output speaker channels all seem to be functioning normally and in peak form, and I've made sure that I have the area around the receiver well ventilated. So....thank you, again...for getting back to where I really wanted to be without having to go through the hassles of disconnecting everything and having it serviced with possible $ and time expenses.
Oct 16, 2013 | Pioneer DEH X3500UI - radio / CD / MP3...
On my GE Profile Microwave the led is lighted and shows the time correctly and displays the led buttons. When I press on the led buttons nothing seems to happen. Also, after some idle time, the led panel...
The touch panel has malfunctioned, Suggest replacing microwave unless you want to attempt repair. If so you will need a replacement touch panel for it.
Jun 14, 2017 | GE Microwave Ovens
My 7 year old GE Profile Side by Side will not get
Self Diagnostics
To enter Self Diagnostic mode, both temperature control panel displays must be illuminated. A display
can be illuminated by pressing an adjacent temperature adjustment button. When both displays are
illuminated, set the freezer and refrigerator temperature settings to 5. Simultaneously press and hold all
4 temperature adjustment buttons for approximately 3 seconds. A flashing 0 in the refrigerator and
freezer displays will indicate that the refrigerator is in Self Diagnostic mode.
For temperature control panels with single-digit displays, the COLDER temperature adjustment button
will increment the numbers up and the WARMER temperature adjustment button will increment the
numbers down. Use the freezer temperature adjustment buttons to enter the test code number in the
freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in
the refrigerator display. When a test code has been entered, the displays will flash to confirm the test.
Press the HOLD button for 3 seconds to begin the test.
For temperature control panels with 3-digit displays, the COLDER temperature adjustment button will
increment the numbers down and the WARMER temperature adjustment button will increment the
numbers up. Use the freezer temperature adjustment buttons to enter the test code number in the
freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in the refrigerator display. When a test code has been entered, the displays will flash to confirm the test
code. Press any button other than a temperature adjust button to begin the test.
When testing has been completed, do one of the following things:
• Enter code 1 5 to completely reset the system.
• Enter code 1 6 to exit diagnostic mode. GSS manual
May 15, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Pioneer deh 6700
hello, my front panel doesn't work. Only volume is working but nothing else. Any fix? Do I need to buy a new front panel? Thanks.
Jul 04, 2008 | Pioneer DEH-P6700MP CD Player
DVD Home Theatre System Panasonic xv htd-330 dvd won't play
From the manual:
Press STANDBY/ON to put the system in standby, then press and hold the front panel (stop) button for about 8 seconds until the display shows Mem.clr?.
Press the front panel I<<<< or the >>>>I button so that the display shows Interlace?.
Press the front panel >/II button to set to interlace & switch the system back on.
May 04, 2007 | Pioneer HTD-330DV System
Samsung RF267AEBP (258 cu ft) Bottom Freezer French Door Refrigerator Logo
697 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
