Question about Goldstar MV-1501 Microwave Oven
My Goldstar Microwave over the stove oven quit heating. (Today) I heated up a microwave meal, and my wife heated one right after me. Mine heated just fine, and my wife said hers took a little longer. The third meal would not cook at all. All the lights and controls seem to work properly. It makes noise as if it were working, but no matter what I do it will not heat. It won't defrost, nothing!
  • 833 Answers
SOURCE: Goldstar Microwave
Could be the relay, an internal fuse. With the power off, open up the key panel and search for a fuse. Also, there are thermo sensors black, diameter of a dime and 3/8 inch thick with two wires. Check the fuse and replace if necessary. The thermo can be jumped out to test. Remove the wires, use a paper clip between them and tape it up. Briefly turn the unit on. Replace if it works now. The thermo is generally clamped to the wall of the oven behind the key panel. Never run without the thermo sensor.
Posted on Dec 19, 2007
SOURCE: Goldstar MV1501W not heating or turntable, light/display does wrk
micro switch is bad .remove top vent cover 4 screws,after removing plastic vent panel you will see 1 screw above display time window,remove this screw and lift up the complete button time control panel slightly and pull towards you to remove.there are 2 connections on this panel 1 is a 12 pin connector and a 2 pin power connection remove both put control panel aside.now there are 3 micro switches where the door pins close into the oven lock,remove 2 screws that hold the micro switch housing,on the bottom of housing you will see a small clip gently pull to the right and push back to remove .there are 2 switches on bottom of it and 1 on top. the 1 on top is normally open and closes when door is shut but like mine it stayed open and resulted in (light s display but no turntable)soon as i replaced upper microswitch it runs perfect.i hope this helps .MODEL MV1501W GOLDSTAR
Posted on Jan 01, 2009
  • 109 Answers
SOURCE: Goldstar microwave
Open the cover and look for a fuse. If it's not blown then the power tube (klystron?) is probably fried.
Posted on Mar 27, 2009
heatman101
  • 43501 Answers
SOURCE: Have a Goldstar MV1501W above
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101]]\\]
Posted on Mar 27, 2011
heatman101
  • 43501 Answers
SOURCE: Goldstar GMV1540TB Microwave is not heating. Timer
heatman101=-=-=--
May Spacemaker XL1800 stop heating food. Was working fine. Then just stop
Is this an over the stove type unit? I have had a few problems with my over the range spacesaver. I think the heat from cooking gets up into the microwave and damages it. The steam from me boiling things on the stove had mine quit heating and I purchased a new one. The parts to replace the faulty ones can be quite expensive over $150.00, so its better to purchase a new microwave.
Feb 24, 2013 | GE Microwave Ovens
I have a Goldstar mvh1615ww series microwave that will not heat.Everything works but it will not heat.Please help
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Aug 24, 2010 | Goldstar MV-1615 Microwave Oven
Goldstar GMV1540TB Microwave is not heating. Timer works but the tray is not rotating. If pushing the door up the oven can heat but easy to stop heating.
heatman101=-=-=--
Jul 14, 2010 | Goldstar MV-1526 Microwave Oven
We have a Goldstar mv1310w microwave that the lights have quit working on. This is the light over the range that you can turn on while cooking on the stove. We put new bulbs in and I even show voltage on...
mcdevito75 here, It could be the light sockets are dirty from cooking fumes, oil etc, remove power from the sockets and clean them with alcholol and cotton swabs or paper towels etc.
Jun 28, 2010 | Goldstar MV-1310W/B Microwave Oven
My microwave onen is not heating anything
I would suggest that the overheat stat on the magnetron has blown. If you are happy it's a simple thing to do but just make sure you disconnect from the mains before removing the cover and make sure that the High voltage capacitor is discharged. If you are not sure a qualified service tech will be able to fix this for you at little cost.
Hope this helps
Jan 06, 2010 | Goldstar MA-1011 Microwave Oven
I have a MVH-1670ST IS NOT HEATING AT ALL EVERY
eh... i think it would be more expensive to fix it then buying a new one
Feb 18, 2009 | Goldstar MV-1526 Microwave Oven
Goldstar microwave oven stop heating
microwave ovens have a special Magntron fuse that is inside the body of the microwave its much bigger than a normal fuse, if its blown the microwave wont work.
Jul 30, 2017 | Goldstar Microwave Ovens
Goldstar MV-1501 Microwave Oven Logo
87 people viewed this question
Top Goldstar Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Goldstar Microwave Oven Expert? Answer questions, earn points and help others
