Question about BenQ Office Equipment & Supplies
I have a BenQ PB6100 that has served me well for a few years. I was on my third lamp when the projector suddenly stopped working after only a few hundred hours. Thinking that I had a dud lamp, I bought and installed a new lamp, but that didn't work. When I plug in the projector the power button and the menu/left/right/exit button lights up, but the LED indicators (power, temp, and lamp) don't light up. There is also a hum but it doesn't seem that the cooling fan is running. It doesn't seem that the lamp is getting power. Any ideas?
  • richardba872 Jan 11, 2011
    Thanks. Is there any other cause I should consider other than inverter failure?
    Thanks very much. Tough news to swallow but probably better than spinning my wheels trying to fix this thing.
  • BenQ Master
  • 11,800 Answers
The inverter - the system that generates the high voltage needed by the bulb - has failed due to normal wear. When that happened it has surely done some damage in the power source also.
The projector is fixable, the inverter/ballast board will have to be replaced and the power source tested and repaired if necessary. But on an such old device, age related failures will be common from now on and in the end fixing them will cost you more than a new one - it's time to accept that this one has done its duty and it's time to retire.
Just cut your losses and buy a new one.
Posted on Jan 07, 2011
  • Azrael SRL Jan 11, 2011
    The power source, but the damage would have to be very extensive for it to fail without a warning from the status light. And in that case the entire projector would be clearly and definitely dead, no way of fixing it.
  • Jose Rommel Racimo
    Jose Rommel Racimo Jul 02, 2013
    regulator ic on the power source maybe
I'm looking for some instructions for a hanimex super 8 zoom projector. Can't find them anywhere.
User manual is available on www.aboutprojectors.com/pdf/benq-pb6100-manual.pdf
Service manual is available on
http://www.eserviceinfo.com/downloadsm/16426/BenQ_6100/6200.html
sonsunny
Jun 24, 2011 | BenQ (200NSH-LAMP) Projector Lamp for...
BENQ PB6110 - will not power on
Hi I am Vortash check the lamp housing is secure as most units have a safety switch on them to disconect the projector from the supply while a bulb is inserted .. I fthis is secure and the fuse is not blown I suspect the lamp or the ballast .. look for dry joints on the board for the lamp or unseated plugs other than that unless your friend can trace the psu switch mode power supply back to it's individual outputs and check that it is working correctly your going to have to take it to an engineer sorry .. hope this helps Regards Vortash
Apr 15, 2009 | BenQ PB6100 Multimedia Projector
My Benq PB6100 shut off after a few seconds
I had the same problem.
First thing to do is look up the owners manual, unless you happen to still have it, then verify the the sensor for the second (or rear something that sounds not like first) temp sensor is going off. If it is basically the fan that sends air into the lamps compartment may be clogged. I have had mine for several years and recently had the same problem. I almost went out to buy something new until I convinced myself that there was no harm in taking it apart and trying something. Good thing too, since all I had to do was clean the fan and reassemble. After that it stopped turning off by itself and I haven't seen any red lights.
Good luck to You!
Mar 19, 2009 | BenQ PB6100 Multimedia Projector
BenQ MP612c projector has three orange flashing lights
you can go to the BenQ website and download a manual for your particular projector. It should tell you what the lights indicate.
Feb 01, 2009 | BenQ (200NSH-LAMP) Projector Lamp for...
PB 6100 lamp
it is a very straightforward affair..just unscrew the flap, remove the securing screws of the lamp housing take hold of the lamp modle metal pulling bar and lift out.
Let me know if you would like a quotation for a lamp as we ship internationally. Regards Kevin Andreassend. http://www.iceav.co.nz iceavtech@gmail.com +64-9-4142348
Jun 20, 2008 | BenQ (200NSH-LAMP) Projector Lamp for...
886 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Electro Med Services...
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
