Hi... my "DPS-800GB A" power
  • 591 Answers
Verify if the voltage switch is in the correct position (110V/220V) in the back of the unit, verify if the power cord is OK, plug it in a different AC outlet
Posted on Jan 04, 2011
Defectice power supplies for ML350/370/380 is a known issue on HP G5 servers.
You need a new power supply.
Note that:
Power supplies with part number 379123-001, all REVISIONS are suspected.
Try to find the new one with part numebr: 379124-001.
Posted on Feb 12, 2011
  • aloner_4 Mar 21, 2011
    Hello, I also have the same problem I already try your suggests but still not works, what else i can try?
DPS-260lp
It could be your PSU(Power Supply Unit) or your motherboard
to test your PSU use a voltmeter
1-Unplug PSU from motherboard and all unit in the PC
2-Put a small wire between black(GND) and green(PSon) wire
3-Test voltage
Orange is 3.3V
Red and purple is 5V
Gray is PWRGOOD(or PWROK) it must be at 5V
Yellow is 12V
Blue is -12V
White(optional) is -5V
Nov 11, 2012 | Computers & Internet
No power at all
Check the capacitors in the power supply, check for any bulged tops. Your problem is most likely power supply related.
May 21, 2012 | Televison & Video
My laptop won't work on battery now!!
look at the bottom of the laptop where you install the battery, there's should be what looks like metal contacts where the battery connects to the actual computer. make sure that when you installed the battery you didn't accidentally bend 2 of them so they were touching eachother. you may have created a direct short which is what caused your heat and the smell. try to plug the battery back in and be careful that you don't bend the metal contacts.
May 18, 2012 | Apevia Acer Aspire 1670/1671 Notebook
HDMI/ DVI inputs failed approx. one month after connection of Denon home theater receiver with HDMI pass-through feature "on." Gear successfully re-connected via component video...
hi welcome to fixya
i want to clarify first the problem sir so as of now the problem with your tv won't power on then you are using again the old main board is that right ? when you use the new replacement main board the tv is functioning will the only problem is that the HDMI / DVI inputs doesn't work. and now you encountered power supply problem like won't start up or something that cut the supply in which the stand by indicator is turn off so as my idea it has a problem with the old board. but before you come up with the board making sure all the connectors coming from the power supply is properly connected to the main board as will as flexible and lvds cable for the T-con board is properly inserted.just let me know if is that what you are asking for so i can give you additional solution thanks for consulting the fixya.
Aug 30, 2011 | Televison & Video
We have a Samsung HL67A510 and when I turn it on, I can hear a click and the green LED light blinks and the "on" music plays and I can hear the fan blowing in the back. But after a couple of...
Hi Isnovero,
The main reasons of your problem is the bulb which is already came to its end. The unit will automatically shuts off when it sense a bulb failure. But before you replace the bulb I would advice you to work first on its power supply. Look for open fuse/fusible resistor and spot some bad solder joints. This will do the same symptoms like what it showing now. If you don't have necessary tools and test instruments, and can't do the job yourself, I would advice you to look for a professional to troubleshoot the problem. Don't attempt to work in the power supply if you don't know the safety precaution of handling it, there some stored electricity enough to hurt you with a little mistake only.
Hope I helped you.
Have a nice day! Thanks for using Fixya.
Feb 17, 2011 | Televison & Video
Hello. My Nec LT35 projector will not turn on. From standby mode, I hit the power button, the power LED turns green, the fan starts, but after two seconds it switches back to standby. The...
i have the exact same error with same projector. did you manage to solve this?
my status led blinked red 6 times indicating a "lamp error" which wasn't helpful. i also tried removing and replacing lamp but didn't work.
Dec 01, 2010 | NEC LT35 Multimedia Projector
DPS-210EP-2 power supply blew up
hi there the 8 pin ic in question is a Viper22a available from good electronic stores i got mine from
Cricklewood electronics for a couple of quid , also replace the capacitor c72 47uf
hope this helped
my board is DPS-210EP B REV 00
should be same
Jun 12, 2009 | Westinghouse LTV-32w3 HD Television
ATX Bestec 1956F Power Supply Failure
sounds like your power supplie has not been switched on by *********** board.the fan will not turn on until power supplie is turned on by mb.as far as what is wrong there are several things i can think of.i would try resetting bios. It sounds like your power supplie is working and your motherboard could have a short.but i have no way to be sure without testing. I can however tell you how to perform a test on your power supplie.unplug the 20 or 24 pin connector from your mb. look for a green wire,and then locate the grey one.short these two together(you can use a paper clip or something).if it dosnt power up. your power supplie is bad.also do not short any other wires,and only touch the grey and green for a few seconds as this is not how it was intended to be powered on.
Mar 03, 2009 | Bestec ATX-1956F (ATX1956F) 200-Watt Power...
Acer AL1716 Blank screen & blinking green power LED
Hi..there,
You've got a busted backlight inverter... Need to replaced a new one...
Dec 17, 2008 | Acer AL1716Bbd 17" LCD Monitor
Computers & Internet Logo
2,729 people viewed this question
David Payne
David Payne
