Question about HP PhotoSmart C5150 All-In-One InkJet Printer
Ink flow from Black cartridge is streaky and light.Have tried 2 new cartridges,same result. other colours seem to work.When other colours are used finished black has a red tinge. I have turned off printer,disconnected it from power source,removed all cartridges, re-connected power souce,re-installed existing cartidges. No change in poor black printing.
    Problem Solver:
  • 10 Answers
Check if your running in a draft mode printing. if the problem is not solve please visit your nearest hp service center, thank you
Posted on Jan 04, 2011
Printer is not registering new cartridge, which is full and an HP "02" . Printer was out of cyan blue for a while, printing in black and white, then replaced it. Ink is flowing, checked with...
Hello.
New cartridges that are not HP brand can sometimes give these errors. If they are HP brand then the issue is with the sensor that reads the cartridges "chip" The ink levels are not read like the fuel in your car, there is a page counter on the cartridge and when it hits 0 then it assumes there is no ink. So the issue seems to be it is not reading the chip correctly. Try removing all the cartridges. turn the printer off for 10 mins and replace the cartridges 1 by 1. This can sometimes correct the issue. If not the pins that read the cartridges chip can be checked for dirt of dry ink that may be interfering with the pins touching the cartridge. these pins are in the Cartridge holder for each colour, inside the printer. use a torch to see them properly.
Good Luck. Regards GM
May 26, 2011 | HP Office Equipment & Supplies
All colours except the black appear to be printing on my Epson C64 InkJet printer. What could be the problem?
On this printer, the black colour is a separate cartridge.
It is possible that is has run out of ink or maybe is blocked in some way.
Try removing the black cartridge and hold it up to a bright light to check the ink level.
Make sure the contacts where the ink flows out are clean and not blocked with dirt.
If there is plenty of ink but it still won't print then try a new black cartridge.
Please rate my answer if you find this helpful.
Many thanks,
Chris
Mar 05, 2011 | Epson C64 InkJet Printer
Hpdeskjet932c quit printing yellow & blue
Just try with replacing the color cartridges may be it is dry.
Sep 24, 2009 | Zebra 110Xi III Plus Thermal Printer
Can ip1300 print with just black ink cartridge?
AS far as I know you cannot put a black cartridge in the place of a colour cartridge it has to be a colour one. Check your printer properties to see if you can set your printer to work in black only, if you can then set it to black but leave the empty colour cartridge in place. This works for my 1800. Give it a try.
Aug 05, 2009 | Canon PIXMA iP1300 Printer
Canon ip 1880 - colour cartridge problem
no if ur filling the catridge more times the printer going to damage
May 27, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Streaky printing
At most cases of printer, especially which have done refill at cartridge, print quality is poor or streaky. Many factors influencing this printed result. To overcome print quality is poor, maybe following tips can usefull to prevent printed pages are missing lines or streaky.
First step is ordinary to be done many people when print quality is streaky that is doing cleaning. To get good printed result, sometime this facility is used more than once.
Use Ink Refill with Quality Nicely
For printer have refilled, sometime the quality of printing is also influenced by ink. If will fill your printer again, use ink which the was quality of nicely. I have tested some refill inks at cartridge which have been ascertained still nicely ( sorry: I do not want to publicize result of this attempt). In the reality result make me surprise, there ink of refill making the printed quality is crummy. To choose ink refill read following tips :
  • See viscosity of ink, every merk of ink refill have difference of viscosity. Don’t use Ink refill too jell. Difference of this viscosity is no measure reference viscosity of ink from factory maker of printer
  • Don’t fear to try some inking merks. Done this, you’d find refill ink fitt with your printer. I now only using one merk of refill ink ?.
  • This suggestion of forum, but I still not yet proved. May believe or not. Good ink aroma of soft usually.
Change Original Cartridge
This is last choice. A lot not like to do this ways, because price of original cartridge still costly. Alternative, you can use compatible cartridge which the was price of cheaper than original cartridge. At newest printer, usually there are two until four cartridge in one printer. And price four same cartridge almost at the price of printer even there are some costlier.
Let me know !
Thanks
Fame !
Apr 02, 2009 | Canon PIXMA MP130 All-In-One InkJet...
My printer will not accept a new black cartridge.
ITS NOT THE BLACK CARTRIDGE!!! Try changing the colour cartridge and see what happens. When a 9600 checks ink levels it does the black ink first, then the colour, if the colour is low it goes back and checks the black again but will constantly give an error message for the black cartridge. Sounds bizarre but try just the black cartridge in with no colour. print a test page in black only, if that does not print then it is a fault. Also make sure the driver is updated!!!
Feb 16, 2009 | HP DeskJet 9650 InkJet Printer
Does not print black
Most likely you have no black cartridge installed or it is empty causing your printer to use the colour cartridge for black. But if your colour cartridge has 1 colour which is less full than the others it causes black to become greenish or sometimes reddish depending on which colour is less. A new cartridge or a black cartridge will solve the problem.
Aug 08, 2008 | HP DeskJet 825c InkJet Printer
Printing photos
its ok I solved it! I didn't realise that all the photo cartridge does is gloss over the colour picture produced by the colour cartridge. I simply had to replace the colour cartridge which had run out, so now its all working perfectly!!
Apr 08, 2008 | HP DeskJet F380 All-In-One Printer
Wonky colour printing!!
you need to run a print alignment test.. this should correct the colour faults (unless you really do have blocked cartridges,
Sep 27, 2007 | HP DeskJet 5550 InkJet Printer
HP PhotoSmart C5150 All-In-One InkJet Printer Logo
146 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
