Question about Dell Latitude Cp, Cpi, Cpx, C600, C800, Inspiron 3800 8000 4000 601212 CD-ROM Drive
Dell laptop C600
  • fitty_15 Nov 11, 2008
    i am having the same problem with my dell latitude c600 i hope someone can find the solution to this problem
    Problem Solver:
  • 15 Answers
Hmmm, Typically safe mode overcomes most errors, You can make changes in MS-Dos, but if all else fails and you fear data loss, daisy chain the hard disk to another computer with matching OS and move the important files then wipe and re-format
Posted on Jul 26, 2009
I have an old Dell c600 and have just installed Windows 2000. My display is only taking up half the size of the total area - how can i expand it to fill the whole screen please?
Hi collywebs,
Go to this support site for the Dell C600 running Windows 2000. Not only can you download your video driver, but all drivers for your laptop, including all components. The video driver will be at the bottom of the page.
If you have moved your operating system to XP/XP Pro, this same driver should work also. This driver should allow your display to fill the screen in the proper aspect ratio.
I hope this helps your situation. Thanks.
Regards, Bill
Aug 21, 2010 | Dell Latitude C600 Lcd LCD Display
I have an old dell desktop computer, I believe it's an 1100 series. It looks as though it's going to start normally but then it says "Sorry for the inconvenience but windows could not start successfully it...
F10 on Acer 's is to reinstall Windows. Exactly the same thing you must do now, Windows is corrupted beyond repair. But in this case you must boot from the recovery disks that came with the Dell and follow the instructions on the screen.
Aug 03, 2010 | Dell Dimension 1100 PC Desktop
How do i restore my dell latitude c600 to its factory settings
The Dell Latitude C600 is an older Dell laptop computer. This particular model came with Windows XP pre-installed on it. If you are experiencing problems with your computer, or you want a fresh start with your Dell, you can restore the laptop to factory settings. This process removes all of the data saved on your computer and resets all of the settings back to the way they were when you first purchased the computer.
Step 1
Turn off your computer if it is currently on.
Step 2
Turn on your computer. When the Dell splash screen appears, hold down "CTRL" and "F11" on your keyboard. Release both keys at the same time.
Step 3
Click "Restore" in the "Dell PC Restore by Symantec" window. Click "Confirm" when you are warned that all data will be lost.
Step 4
Allow the system to restore and wait for the message that says "The system recovery process was successful." This can take about 8 to 10 minutes.
Step 5
Click the "Finish" button and your Dell Latitude D600 is restored to factory settings.
May 10, 2010 | Dell Latitude D600 Notebook
Acer aspire one will not start in safe mode or to last known good config. Nothing works.... F2, F8 F12.... all no good. Just keeps returning to the screen saying windows did not start successfully. ''a...
You are going to have to repair the Windows installation. If the boot up screen has an option to repair (some systems like Dell and HP provide an hidden partition with the software to allow you to restore the system), use that to repair the installation. If it does not, you will need the Windows disk or system restore disks to fix the installation.
If using a Windows disk, skip the first repair option and do an install. DO NOT FORMAT THE HARD DISK! During the install it will say it found a previous installation and ask if you want to repair, choose the repair option at this time. Using this method, all your applications should remain installed and working. You will need to run Windows Update till it is fully updated.
If using System Restore disks, follow the on screen prompts
Mar 12, 2010 | Acer Aspire One Netbook 8.9" Notebook
How do I get to the Command prompt on the dell
Sorry to say but actually your windows has become corrupted, may be due to improper shutdown or power failure. do one thing try to start your windows with previous known configuration that worked .(option already available on boot screen).if this does not work enter your windows cd and choose repair windows option when prompted.follow the instruction that will recover previous status of your pc.
Oct 20, 2009 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
Non-stop loading screen
Sounds like it might be a hard drive problem. First, you may want to try a reinstall of the operating system (booting just from the CD), or also attempt a diagnostic (F12 at Dell Logo). If the first does not work, or if the drive fails diagnostics, you will need to replace it
Apr 08, 2009 | Dell Inspiron E1505 Notebook
Dell latitude c600, battery not charging even charging sign is shown in windows (battery is ok and checked by another dell laptop) whats problem?
hi im josh in cebu phils.may i help you. friend try to check the small wire white near the batt.or check the connections if it is not shorted or disconnected. or try to replace new batt. good luck
Feb 22, 2009 | Dell C600 (002UH) Motherboard
Need a driver
access go to drivers and downloads. then pick choose by service tag. your service tag can be located at the bottom of your laptop. put in the service tag number and you'll get other options. most likely, you'll be able to see the device driver for your ethernet controller.
i hope this info helps.
Sep 10, 2008 | Dell Latitude C600 Notebook
C600 not starting
Check memory and CPU first, typically they cause shut offs. Try battery, AC to laptop and AC via port replicator. Borrow one if need be, but it's good to check these options
Aug 26, 2008 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
Computers & Internet Logo
73 people viewed this question
Alun Cox
