Question about Kenmore 20172 Top Load Washer
Washer standpipe was cut down approx. 12 inches and now I have overflowing. Standpipe is very old and almost impossible to remove and replace. What else can be done?
    President:
  • 3,113 Answers
The drain pipe must have a restriction in it. Sometimes the build up sludge inside the pipe and that will need to be replaced
Posted on Jan 04, 2011
Overflow standpipe
Lowes and Home Depot sell a generic standpipe. If it's too long it can easily be cut down to size.
Jun 03, 2010 | AdobeAir WisperCool MMB8 Portable Air...
Tip
How to Prevent Washer Siphoning
If you have ever experienced the problem where you washer continually fills but never reaches the proper level (not an overflow). Or, the wash tub water level cannot be maintained, because the water level keeps dropping. You may be experiencing what is known as “siphoning”. This occurs when there is no air gap for the drain line at the standpipe. The standpipe is the drain pipe at the wall where the washer drain line is placed. With no air gap, a vacuum is created, and water will begin to drain from the wash tub prematurely. To prevent this from occurring, follow this advice:
  • The standpipe should be 2 inches in diameter to allow a sufficient air gap between the top of the standpipe and the drain hose.
  • The standpipe should be a minimum of 34” from the floor, and should not exceed 72 inches in height.
  • DO NOT seal the top of the standpipe. Many consumers seal the standpipe in the belief that this will prevent overflows, or get rid of drain odors. This often creates more problems than solutions.
  • DO NOT place the drain hose too far down into the pipe. Water stays in the drain trap area of the standpipe. If the end of the drain hose rests in this area, no air gap is created, and this can also cause siphoning. 4 to 6 inches is sufficient.
  • The drain hose length must not exceed 10 feet in length. Excessive drain hose length can cause drain problems and back wash.
I hope these tips are informative and will help prevent some of the more common washer drain problems that can easily be mistaken for a more serious problem. You can save yourself a service call, just by double checking your installation.
on Dec 04, 2009 | Washing Machines
Tip
on May 12, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
My Inglis washer also gets stuck on rinse
If you have ever experienced the problem where you washer continually fills but never reaches the proper level (not an overflow). Or, the wash tub water level cannot be maintained, because the water level keeps dropping. You may be experiencing what is known as "siphoning". This occurs when there is no air gap for the drain line at the standpipe. The standpipe is the drain pipe at the wall where the washer drain line is placed. With no air gap, a vacuum is created, and water will begin to drain from the wash tub prematurely. To prevent this from occurring, follow this advice:
* The standpipe should be 2 inches in diameter to allow a sufficient air gap between the top of the standpipe and the drain hose.
* The standpipe should be a minimum of 34" from the floor, and should not exceed 72 inches in height.
* DO NOT seal the top of the standpipe. Many consumers seal the standpipe in the belief that this will prevent overflows, or get rid of drain odors. This often creates more problems than solutions.
* DO NOT place the drain hose too far down into the pipe. Water stays in the drain trap area of the standpipe. If the end of the drain hose rests in this area, no air gap is created, and this can also cause siphoning. 4 to 6 inches is sufficient.
* The drain hose length must not exceed 10 feet in length. Excessive drain hose length can cause drain problems and back wash.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 06, 2009 | Kenmore 24032\24036 Top Load Washer
All of the water filling my kenmore washer is flooding out bottom
Jun 15, 2009 | Kenmore HE2 Plus Front Load Washer
Washer is filling up to wash but water goes out of tub before
Mar 16, 2009 | Washing Machines
Kenmore washer 23801-loses water during wash/rinse cycle before cycle completes
* The standpipe should be a minimum of 34” from the floor, and should not exceed 72 inches in height.
Mar 12, 2009 | Kenmore Washing Machines
Kenmore elite clothes washer model 22952
Feb 01, 2009 | Kenmore 22422 Top Load Washer
Hot water comes, but does not fill the Washer, and therefore does not rotate the tumbler. It is a Maytag commercial washer
Jan 28, 2009 | Washing Machines
My washer doesn't wash.
Jan 26, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 20172 Top Load Washer Logo
24 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
