Question about Samsung SCX-4100 All-In-One Laser Printer
Print quality: streak/poor printing along one side of page.
I mistakenly posted this under another problem... sorry.
When I print there is an area towards the left side of the page where the printing is blurry/missing parts.
Example: I try to print a solid sheet of just black and I will have a somewhat spotty white stripe (about 1/2 inch thick) down the left side of the page.
I tried a "cleaning" sheet for laser printers from staples and it did not help. Any suggestions?
  • mjk4 Oct 07, 2008
    Same issue here! No matter what the cartridge (tried 2 brand-new ones) and no matter how I shake 'em- the left side is very light. Right side is fine.
  • 134 Answers
Shake the toner cartridge left to right, then try.
Posted on Jul 09, 2008
Streak along edge of paper, Canon MF8380Cdw
Print quality issues on these models is usually if not always down to the cartridges used. I bet you are using compatible cartridges. If so just buy a set of genuine ones and I bet the quality will be perfect again.
Jun 01, 2016 | Canon imageClass MF8380Cdw Wireless Color...
Will not print black...Joe
check the printhead.... print a print quality page from the settings button select print reports then print that page. there is a printhead health area as well as color blocks if there is streaks in the black yellow blocks or says poor the black/yellow printhead needs to be replaced. if it says good call hp for further troubleshooting and possible replacement under warranty
Mar 31, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
On my Test Pattern 2 the blue/light blue and green/yeallow have steeks in it. The documents that I print have streaks going across the page. I've cleaned everythign I can clean. The printer has 6,251...
SolutionFollow the given steps in the order presented to resolve the issue: Step one: Retry the print jobThe problem may occur only rarely. If you have not seen it in other printouts, try again. Step two: Increase the print quality modeIf reprinting did not help, try increasing the print quality mode.
  1. In the application you are printing from, click File , and then click Print .
  2. Make sure the printer is selected, and then click Properties .
  3. Select the Paper/Quality tab.
  4. In the Print Quality area, choose the next higher quality setting. If the current setting is Draft, choose Normal. If the current setting is Normal, choose Best.
Step three: Print in grayscale (black area streaking only) If the streaks are in a black area of a black and white printout, change to grayscale printing.
NOTE: This step does not apply to color printouts.
  2. Make sure the printer is selected and click Properties .
  3. Click the Color tab, and select Print Grayscale and High Quality .
Step four: Clean the printheadsIf the print quality is still bad, clean the printheads.
  1. Make sure the printer is loaded with unused white paper.
  2. Open HP Solution Center .
  3. Click Settings , Print Settings , and then select Printer Toolbox .
  4. Click the Service Tab .
  5. Click Clean Printhead , and then click Clean .
Step five: Align the printheads If the print quality is still bad, align the printheads.
  2. Open the printer Toolbox , and select the Printer Services tab.
  3. Click Align Printheads . The Align Printheads window opens. Click Align .
  4. The printer prints an alignment page. The lines in the patterns should appear to be straight. Click OK when the page finishes printing.
Step six: Calibrate the linefeed If the print quality is still bad, calibrate the linefeed:
  2. Open the printer Toolbox and select the Printer Services tab.
  3. Click Calibrate Advanced Linefeed . The Advanced Linefeed Calibration window opens. Click OK .
Step seven: Replace one or both printheads If the print quality is still bad after performing all the above steps, one or both of the printheads will have to be replaced. Print a PQ Diagnostic page to see which printhead should be replaced.
  2. Press the Setup button.
  3. Press 1 and * simultaneously.
  4. Look at the color blocks labeled Test Pattern 2. Some or all of them could show white horizontal streaks. If none of the blocks are streaked, the printheads are okay.
    • If the Black block has lines – replace the KY printhead.
    • If the Cyan block has lines – replace the MC printhead.
    • If the Magenta block has lines – replace the MC printhead.
    • If the Red block has lines – replace the KY printhead.
    • If the Green block has lines – replace the KY printhead.
Dec 21, 2009 | HP OfficeJet Pro L7580 InkJet Printer
On Canon iRC 3200 Laser Printer:: streaks of fainted print
if one side prints well its not the fuser,plus those fusers normaly make alot of noise when they start to act up. right above the bypass tray is a cover with a screw in the front of it. remove this and inside is the ITB belt(two blue handles) if you pull it out there is a metal plate on the bottom bending this up can solve this problem. the paper can drag across this plate causing streaks.hope this helps.
Aug 03, 2009 | Office Equipment & Supplies
Smasung ML2510 Laser print quality poor especially on graphics
Full isn't always the answer, in order to refill a cartridge properly you need to also replace the cleaning blade inside. The blade wears out and doesn't clean the drum properly and also lets toner leak all over. Your best bet is a new OEM cartridge, or put a new cleaning and Dr. blade in yours.
Jul 29, 2009 | Samsung ML-2510 Laser Printer
Printer has set for a while. The print quality is very poor. Black is grey, there are streaks across the page.
Take the cartridge out and shack it side to side a few times to move the toner around and reinstall it.
May 28, 2009 | HP LaserJet 8100N Printer - Refurbished
CLJ8550n poor print quality and wrinkled paper
this is usually not caused by the paper tray. this problem is usually caused by the fuser assembly. check your paper path. dead cycle the printer, shut the printer down before the paper enters the fusing area, check for wrinkles. remove all paper, print again, check the output, wrinkles, replace the fuser.
Feb 03, 2009 | HP Color LaserJet 8550n Printer
Zebra 110Xi III Plus Thermal Printer print quality degredation
You can try cleaning the print head with some isopropyl alcohol and a swab but be sure not to touch the element with your fingers that can get grease from your finger on it causing the oil to burn out the element very quickly. You can also check the Print head element its self. What you are going to be looking for are white spots or streaks on the print head. If you see white spots or streaks your print head has reached end of life and needs to be replaced. If instructions are needed on how to remove the Print head and or identify what DPI Print head you have installed please let me know I can post something up for you. If a Print head is needed please let me know as well. I currently carry them in stock new.
Thanks
Rory Cardenas
708-597-4222 x240
Dec 13, 2008 | Zebra 110Xi III Plus Thermal Printer
Streaks though the pages
Step one: Retry the print job The problem may occur only rarely. If you have not seen it in other printouts, try again. Step two: Increase the print quality mode If reprinting did not help, try increasing the print quality mode.
Step three: Print in grayscale (black area streaking only) If the streaks are in a black area of a black and white printout, change to grayscale printing. NOTE: This step does not apply to color printouts.
Step four: Clean the printheads If the print quality is still bad, clean the printheads.
Nov 25, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
HP L7680 Printer Head Problem
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Step two: Increase the print quality mode
In the application you are printing from, click File, and then click Print. Make sure the printer is selected, and then click Properties.
Select the Paper/Quality tab. In the Print Quality area, choose the next higher quality setting. If the current setting is Draft, choose Normal. If the current setting is Normal, choose Best.
NOTE:- This step does not apply to color printouts.
Make sure the printer is selected and click Properties.
Click the Color tab, and select Print Grayscale and High Quality.
Open HP Solution Center.
Click Settings, Print Settings, and then select Printer Toolbox.
Click the Service Tab.
Click Clean Printhead, and then click Clean.
Open the printer Toolbox, and select the Printer Services tab.
Click Align Printheads. The Align Printheads window opens. Click Align.
Click Calibrate Advanced Linefeed. The Advanced Linefeed Calibration window opens. Click OK .
If the Cyan block has lines – replace the MC Printhead.
If the Magenta block has lines – replace the MC Printhead.
Nov 08, 2008 | HP Officejet 5610 All-In-One InkJet...
Samsung SCX-4100 All-In-One Laser Printer Logo
413 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
CheckitRight
CheckitRight
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
