Question about Keurig B60 Coffee Maker
The LED has disappeared or is very faint - the letters & numbers are incomplete or incorrect. How can I fix this?
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
It sounds like you unit has a major malfunction.
Keurig does not make repair's or carries replacement parts for their units. you can contact Keurig at 1-866-901-2739 or Keurig.com
You do have a 1 year warranty, and if you are out of warranty. They will give a discount on a new unit.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Jan 04, 2011
How to fix a led tv that has vertical lines around 5 minutes after turning it on then disappears when the tv has warmed up?
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Sep 28, 2016 | Samsung Televison & Video
I need remote control for for kichler fan model # 35005
THIS ITEM NUMBER IS INCORRECT. THERE SHOULD BE ATLEAST 1 MORE NUMBER FOLLOWED BY A COUPLE OF LETTERS. IF YOU CAN POSSIBLY FIND THE CORRECT NUMBER I CAN HELP BY GETTING YOU A PART NUMBER FOR THE CORRECT REMOTE THAT WILL BE NEEDED. PART NUMBERS ON FANS ARE CONSISTENTLY FOUND ON THE CANOPY, THIS IS THE PART WHERE YOUR FAN MOUNTS TO THE CEILING. I CALLED OUR REP AT KICHLER AND SHE SAID THIS WAS AN INCOMPLETE NUMBER. HOW OLD IS THE FAN IN QUESTION? ITS POSSIBLE IT MAY BE DISCONTINUED IS WHY WE CANT COME UP WITH ANYTHING.
Dec 04, 2013 | Kichler Lighting Dryers
How to put off number keys on my laptop? my laptop has both numbers n letters on a few keys
most thinkpads use 'hold down shiftkey and press Numlk/Scrlk key' should also toggle a led off & on next to the caps lock led. looks similar to caps lock but the arrow has a 1 in it for number lock when the caps lock uses the letter 'A'
Dec 23, 2010 | Lenovo ThinkPad W500 Notebook
We purchased a used GE gas range with sealed burners and self cleaning oven. We are trying to find the model and serial numbers for it. They only numbers we can find are inside the oven door on the side...
How to find the MODEL NUMBER
  • Look for a silver or white label as shown in the drawing below
  • Zeros and ones often look like the letter "O" or lower case "L"
  • Model numbers from owner's manuals are often incomplete or incorrect
Sep 28, 2010 | GE Kitchen Ranges
My laptop screen is bright. Brightness control works but no picture. The picture is ok on external monitor. Sometimes a faint and incomplete picture appears on startup but disappears after a few seconds....
This might be a sign of a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp.
Aug 25, 2010 | Compaq Presario 700 470024-192 Notebook
No Power on the S700, but LED indicator use to blink.
Try disconnecting both of the amp board power supply cable (the green one from psu to amp board)
Jul 08, 2009 | Creative Labs Gigaworks S750 Computer...
I have a FPD 1830 flat screen monitor not displaying picture
Send the monitor. It's a power supply problem. My 15.4" LCD has the problem, too, whenever I move the monitor down, it powers off, and the menu disappears as well, but I'm going to fix the screen.
Jul 08, 2009 | Gateway Computers & Internet
Incomplete letters
Have you try to change the pitch setting?
Mar 23, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
When printing from the network. Alot of jumbled words.
It sounds like either a corrupt print driver installed on your pc or the incorrect one. Make sure you have the correct driver for your machine and download another one anyway in case your one is corrupt. Delete the one you are using first before installing the new one.
Jan 12, 2009 | OKIFAX 5400 Plain Paper LED Fax
Wong letters & numbers
I downloaded the manual from http://www.devicemanuals.com/downloadguide.php and then, following the instructions there, I removed then re-inserted the daisy wheel. This solved my problem. Perhaps it had somehow gotten out of adjustment. At least, it is something to try if you haven't tried it already.
Jul 15, 2008 | Brother GX-6750 Typewriter
Keurig B60 Coffee Maker Logo
189 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
