Question about Hampton Bay 36 In. San Marino in Brushed Nickel Fan
Can't find 40 watt c26 bulbs for ceiling fan - Hampton Bay 36 In. San Marino in Brushed Nickel Fan
Buffalo12980
  • 625 Answers
SOURCE: MAXIMUM WATTAGE FOR FAN LIGHTS??????
those bulbs are candelabra type. if they came with the fixture then I wouldn't go to a higher wattage bulb. the sockets are probably bakelite and mounted with the base up so any heat off the lamps would be directed upwards. higher wattage bulbs may shorten the lifespan of the sockets. bakelite is a modified plastic. it won't melt but it will get brittle.
Posted on Aug 22, 2007
  • 6 Answers
SOURCE: Bulbs burning out in Hampton Bay ceiling fan
I would suggest getting an electrician to check the current running through the wiring. I had installed a similar fan in my grandmother's house a couple of years ago and had the same problem. After a couple of months of constantly changing bulbs, I brought in an electrician to check the current and found that there was a short in the wire which kept causing just enough of a current surge to blow the bulbs.
Posted on Nov 29, 2008
  • 37 Answers
SOURCE: 40 watt just not bright enough?
60 watts could be fine and you may never have a problem, but it says 40 watts for a reason. So you don't burn your house down. See "To reduce the risk of fire....". The better option here would be to buy 23watt compact fluorescent light bulbs. They give off less heat than a 40 watt incandescent and the same light output of a 100watt incandescent. I'm guessing that you don't currently have the light on a dimmer, but if you wanted to, make sure you get cfl's that are made to be used on a dimmer.
Posted on Jan 24, 2009
  • 323 Answers
SOURCE: light kit has light bulb size that I cannot find bulbs for
Melanie, you must have gotten a bad batch of bulbs. I have installed over 100 Hampton Bay ceiling fans and I have dropped them from up the ladder and have them bounce across the floor with no damage. I think they must have allowed a substandard batch to go out.
Home Depot is where I buy my replacement bulbs. Hampton Bay make fans exclusively for HD.
You can easily change lighting bases, as the wiring is the same for all Hampton Bay. You may even appeal to Hampton Bay on the internet and they might send you the kits. But I don't think you'd have success in a store.
If you try replacing them with bulbs from another Home Depot you may find them much hardier. I wish you the best of luck, and if you need additional help please write back.
Sirwriter
Posted on May 25, 2009
  • 969 Answers
SOURCE: question about light bulb problem in ceiling fan
Check wiring @ ceiling. Should b a black, white, green & red wire coming frm fan. Green is ground. Black & Red is power. White is neutral. Black provides power to fan, red provides lat power 4 lights. Remove light assembly, blue wire provides power. B sure 2 turn off power 2 fan b 4 working on it w/switch & breaker. Maybe lose wire connection or pinched wire grounding out. Fans require vibration proof bulbs regular bulb elements will break after short time use. Fan bulbs have larger filiments inside bulb.
Posted on Aug 23, 2009
Hunter-ceiling-fan light wont work
Make sure your contact in the socket is touching the bulb.
Mar 27, 2014 | Dryers
Compact Flourescents won't work in ceiling fan
Simply use regular bulbs. It sounds like it is switched electronically probably via a dimmer. If the CFL lamps are not specifically labeled dimmable they won't work. I have seen the LED lights work where the CFL lamps will not. If you want to use CFL then replace the dimmer.
Dec 17, 2013 | Hunter 52" Ceiling Fan With Light And...
Wattage limiter hunter ceiling fan
As per the Energy Policy Act of 2005, all ceiling fans manufactured or imported into the United States must utilize a light bulb wattage limiter as of January 1, 2007. This limiter limits the capacity of the fan's light kit to a maximum of 40 watts per bulb. Not very bright at all!
Put in LED lamps and save a lot of work. Go to: http://www.youtube.com/watch?v=7WeWSKNe64A it will show you how.
Oct 18, 2013 | Hunter Ceiling Fan Light Switch Control
Newly installed Hunter remote will work light and fan if only 2 of the 3 bulbs are installed.
Did you install the correct wattage? If you put in 2-60 watt try 3-40 watt instead .
Dec 30, 2012 | Hunter 52" Ceiling Fan With Light And...
Can I replace the 3 40 watts bulbs that came with my Hampton Bay Hawkins 44" ceiling fan with 3 60 watt bulbs?
You would be better off getting 3 40watt daylight bulbs.. extreamly bright low cost and wont cause any harm to your fan.. hope this helps :)
Oct 21, 2011 | Dryers
I just replaced my bulbs on my ceiling fan light fixture with the compact flourescent bulbs 13 watt to replace the regular 60 watt bulbs but they are flickering now. Could there be a problem with wiring...
Your remote control I would assume includes a dimmer for the light. CFL bulbs are not compatible with dimmers. If it has a dimmer, you must use incandescent bulbs.
Feb 14, 2011 | Hampton Bay 52 In. White Redington...
Question about light bulb problem in ceiling fan
Aug 23, 2009 | Aloha Housewares (93645) Ceiling Fan
Jan 08, 2009 | Hampton Bay 24002 Ceiling Fan
Hampton Bay 36 In. San Marino in Brushed Nickel Fan Logo
275 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
