Question about Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener
Garage door go up every so often. Never happened before. Is there away I can stop it. It is 8:00 PM
  • 591 Answers
Try changing the security code/frequency of the wireless remote, also you could verify the adjusment of the door (when closed)
Posted on Jan 04, 2011
Garage door opener
Check photo eyes. Shut off power to units and try again
Aug 21, 2016 | Building Materials
We just installed a MyQ on our garage door, and the first time my wife used it (she tried it about 2 blocks away from home), it didn't open and she said she got a message that it wouldn&#3
Garage door openers can sometimes be triggered by (illegally) boosted CB or ham radios.
A passing vehicle pumping out high power might open the door (an acquaintance did this years ago annoying the neighborhood) and the 30 minute delay may serve to protect against unwanted opening of the door.
Sep 19, 2014 | Chamberlain 940EV Wireless Keyapd MyQ,...
My garage door will only open half way. It appears to be getting stuck when it is opening.
If you haven't gotten your issue fixed yet... I had the same problem (stopped opening half way when using the remote, went down fine, could lift/close manually fine as well) and this happened on our first cold weather day of the year which was very telling. Anyhow, there are two gauges/dials on your garage door opener unit itself (above, where the light is) which controls how much torque/strength your door uses to open or shut through resistance. I turned mine up some and it now works fine; what likely happened was that the metal tracks or the wood frame condensed in the cold and was providing just enough resistance to stop it when opening - as they have a security device built in to stop if they meet any resistance. Hopefully this helps!
Oct 27, 2012 | Sears Craftsman LiftMaster Chamberlain...
Door suddenly will not close without holding the button down continuously that is inside the garage. The remote button will open the door but not close it. The door starts to close and stops right away.
It definitely sounds like a sensor problem. In normal operation, one sensor will have an amber or yellow light on, indicating power to the sensing circuit. The opposite sensor should have a green light on. If the yellow light is not on there is no power to the circuit due to a broken wire or circuit board failure. If the green light is not on or is flickering, the sensors are not aimed at each other or the light path is blocked.
Aug 04, 2011 | liftmaster Garage Door 1/2 Hp
Craftsmand garage door will not close. It comes down to about an inch away from the garage floor and then returns to the open position.
If the main light flashes 10 times when this happens it is a door sensor problem. Make sure they are pointed at one another and the small light on each one is lit and not flickering. Tweak them to get the lights on.
Jun 10, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman garage door does not open all the way stops @12 inches
You most likely have a broken door spring. Release the door from the opener and try lifting it by hand. Look above the door for the springs.
Mar 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remotes don't work
I recently had Verizon FIOS equipment installed in my garage (for phone, internet and TV), which is plugged into a 110 volt electrical outlet. Thinking this equipment might be causing some RF interference, I unplugged the FIOS equipment, and both garage door openers immediately worked perfectly again!
After reconnecting the FIOS equipment, I then plugged the garage door opener into a different electrical outlet approximately 15 ft. away via an extension cord, and the openers continue to work fine. Fingers crossed, I hope the issue is permanently resolved.
Aug 03, 2008 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener Logo
456 people viewed this question
Top Chamberlain Car Audio & Video Experts
Glenn Mayer
Glenn Mayer
Vince Heuser
Are you a Chamberlain Car Audio and Video Expert? Answer questions, earn points and help others
